[MOAB-dev] r3913 - in MOAB/trunk/src: io parallel parallel/moab
kraftche at cae.wisc.edu
Mon May 17 15:57:48 CDT 2010
Author: kraftche
Date: 2010-05-17 15:57:48 -0500 (Mon, 17 May 2010)
New Revision: 3913
Modified:
MOAB/trunk/src/io/WriteHDF5.hpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
fix some warnings
Modified: MOAB/trunk/src/io/WriteHDF5.hpp
--- MOAB/trunk/src/io/WriteHDF5.hpp 2010-05-17 20:50:30 UTC (rev 3912)
+++ MOAB/trunk/src/io/WriteHDF5.hpp 2010-05-17 20:57:48 UTC (rev 3913)
@@ -114,11 +114,6 @@
{ return MB_SUCCESS;}
virtual ErrorCode write_finished();
virtual void debug_barrier_line(int lineno);
-#ifdef __GNUC__
-__attribute__((format(printf,2,3)))
-#endif
//! Gather tags
ErrorCode gather_tags( const Tag* user_tag_list, int user_tag_list_length );
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2010-05-17 20:50:30 UTC (rev 3912)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2010-05-17 20:57:48 UTC (rev 3913)
@@ -126,7 +126,7 @@
const char* typenames[] = {"Block ", "Sideset ", "NodeSet", "Vertex", "Curve", "Surface", "Volume", "Body", "Other"};
for (Range::iterator riter = sets.begin(); riter != sets.end(); ++riter)
- unsigned dim, id, oldsize;
+ unsigned dim, id ; //, oldsize;
if (MB_SUCCESS == iFace->tag_get_data(bid, &*riter, 1, &id))
dim = 0;
else if (MB_SUCCESS == iFace->tag_get_data(sid, &*riter, 1, &id))
@@ -143,7 +143,7 @@
dim = 9;
- oldsize = typesets[dim].size();
+ //oldsize = typesets[dim].size();
typesets[dim].insert( id );
// assert( typesets[dim].size() - oldsize == 1 );
@@ -704,7 +704,7 @@
for (tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter) {
std::string name;
iFace->tag_get_name( tag_iter->tag_id, name );
- dbgOut.printf(2,"%18s %8lu %8lu %8lu %8ld 0x%7lx\n", name.c_str(),
+ dbgOut.printf(2,"%18s %8lu %8lu %8lu %8lu 0x%7lx\n", name.c_str(),
(unsigned long)tag_iter->range.size(),
(unsigned long)tag_iter->offset,
(unsigned long)tag_iter->varDataOffset,
Modified: MOAB/trunk/src/parallel/moab/ParallelComm.hpp
