[MOAB-dev] r3912 - in MOAB/trunk/src: io io/mhdf/src parallel
kraftche at cae.wisc.edu
Mon May 17 15:50:31 CDT 2010
Author: kraftche
Date: 2010-05-17 15:50:30 -0500 (Mon, 17 May 2010)
New Revision: 3912
Modified:
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.hpp
MOAB/trunk/src/io/mhdf/src/util.c
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
Log:
o Add missing peices to enable collective IO during parallel write
o Better error handling when writing HDF5 files
o Fix failure to free HDF5 property object when doing collective IO
o More debugging output for parallel HDF5 writes
Note: collective IO for parallel writes still isn't entirly complete
It probably won't work for variable-length tags. But it is sufficently
complete to allow evaluation of any performance improvement.
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-17 20:44:55 UTC (rev 3911)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-17 20:50:30 UTC (rev 3912)
@@ -124,6 +124,13 @@
// This is the HDF5 type used to store file IDs
const hid_t WriteHDF5::id_type = get_id_type();
+// This function doesn't do anything useful. It's just a nice
+// place to set a break point to determine why the reader fails.
+static inline ErrorCode error( ErrorCode rval )
+ { return rval; }
// Some macros to handle error checking. The
// CHK_MHDF__ERR* macros check the value of an mhdf_Status
// object. The CHK_MB_ERR_* check the value of an ErrorCode.
@@ -139,7 +146,7 @@
do if ( mhdf_isError( &(A) )) { \
writeUtil->report_error( "%s\n", mhdf_message( &(A) ) );\
myassert(0); \
- return MB_FAILURE; \
+ return error(MB_FAILURE); \
} while(false)
#define CHK_MHDF_ERR_1( A, B ) \
@@ -147,7 +154,7 @@
myassert(0); \
mhdf_closeData( filePtr, (B), &(A) ); \
} while(false)
#define CHK_MHDF_ERR_2( A, B ) \
@@ -156,7 +163,7 @@
myassert(0); \
mhdf_closeData( filePtr, (B)[0], &(A) ); \
mhdf_closeData( filePtr, (B)[1], &(A) ); \
} while(false)
#define CHK_MHDF_ERR_3( A, B ) \
@@ -166,7 +173,7 @@
mhdf_closeData( filePtr, (B)[2], &(A) ); \
