[MOAB-dev] r3871 - MOAB/trunk/tools
kraftche at cae.wisc.edu
Mon May 10 09:12:20 CDT 2010
Author: kraftche
Date: 2010-05-10 09:12:20 -0500 (Mon, 10 May 2010)
New Revision: 3871
Modified:
MOAB/trunk/tools/size.cpp
Log:
Quick fix-up of mbsize:
o correct help data
o make -m and -g flags work for -l and -ll modes
o don't list default size info if -l or -ll mode
o update readme
Modified: MOAB/trunk/tools/size.cpp
--- MOAB/trunk/tools/size.cpp 2010-05-10 13:56:37 UTC (rev 3870)
+++ MOAB/trunk/tools/size.cpp 2010-05-10 14:12:20 UTC (rev 3871)
@@ -48,7 +48,7 @@
void usage( const char* exe )
- std::cerr << "Usage: " << exe << " [-g] [-m] [-l] [-ll] <mesh file list>" << std::endl
+ std::cerr << "Usage: " << exe << " [-g] [-m] [-t|-l|-ll] <mesh file list>" << std::endl
<< "-g : print counts by geometric owner" << std::endl
<< "-m : print counts per block/boundary" << std::endl
<< "-t : print counts by tag" << std::endl
@@ -459,8 +459,9 @@
if (tag_count)
rval = gather_tag_counts( 0, file_counts );
- else
+ else if (!just_list && !just_list_basic)
rval = gather_set_stats( 0, file_stats );
if (MB_SUCCESS != rval)
fprintf(stderr, "Error processing mesh from file: %s\n", f->c_str());
@@ -472,6 +473,12 @@
print_tag_counts( file_counts );
file_counts.clear();
+ else if (just_list) {
+ mb.list_entities( 0, 1 );
+ else if (just_list_basic) {
+ mb.list_entities( 0, 0 );
else {
total_stats.add( file_stats );
print_stats( file_stats );
@@ -535,15 +542,20 @@
printf( "%s %d:\n", geom_type_names[dim], id );
if (tag_count)
rval = gather_tag_counts( *i, file_counts );
- else
rval = gather_set_stats( *i, file_stats );
else if (tag_count)
