[MOAB-dev] r3870 - MOAB/trunk/tools
kraftche at cae.wisc.edu
Mon May 10 08:56:37 CDT 2010
Author: kraftche
Date: 2010-05-10 08:56:37 -0500 (Mon, 10 May 2010)
New Revision: 3870
Modified:
MOAB/trunk/tools/size.cpp
Log:
add new mode to mbsize that prints all tags and for each tag the count of each entity type with the tag set
Modified: MOAB/trunk/tools/size.cpp
--- MOAB/trunk/tools/size.cpp 2010-05-10 13:55:42 UTC (rev 3869)
+++ MOAB/trunk/tools/size.cpp 2010-05-10 13:56:37 UTC (rev 3870)
@@ -51,6 +51,7 @@
std::cerr << "Usage: " << exe << " [-g] [-m] [-l] [-ll] <mesh file list>" << std::endl
<< "-g : print counts by geometric owner" << std::endl
<< "-m : print counts per block/boundary" << std::endl
+ << "-t : print counts by tag" << std::endl
<< "-l : print counts of mesh" << std::endl
<< "-ll : verbose listing of every entity" << std::endl
@@ -172,6 +173,48 @@
return MB_SUCCESS;
+struct TagCounts {
+ TagCounts(std::string n) : name(n)
+ { std::fill(counts, counts+MBMAXTYPE, 0); }
+ std::string name;
+ int counts[MBMAXTYPE];
+ErrorCode gather_tag_counts( EntityHandle set,
+ std::vector<TagCounts>& counts )
+ std::vector<Tag> tags;
+ mb.tag_get_tags( tags );
+ for (size_t i = 0; i < tags.size(); ++i) {
+ std::string name;
+ ErrorCode rval = mb.tag_get_name( tags[i], name );
+ if (MB_SUCCESS != rval || name.empty())
+ continue;
+ counts.push_back( name );
+ for (EntityType t = MBVERTEX; t != MBMAXTYPE; ++t)
+ mb.get_number_entities_by_type_and_tag( set, t, &tags[i], 0, 1, counts.back().counts[t] );
+ return MB_SUCCESS;
+void add_tag_counts( std::vector<TagCounts>& counts,
+ const std::vector<TagCounts>& add )
+ for (size_t i = 0; i < add.size(); ++i) {
+ size_t j;
+ for (j = 0; j < counts.size(); ++j)
+ if (add[i].name == counts[j].name)
+ break;
+ if (j == counts.size()) {
+ counts.push_back( add[i] );
