[MOAB-dev] r3858 - in MOAB/trunk/src: io parallel
    kraftche at cae.wisc.edu
    Thu May  6 18:08:34 CDT 2010
Author: kraftche
Date: 2010-05-06 18:08:34 -0500 (Thu, 06 May 2010)
New Revision: 3858
Modified:
   MOAB/trunk/src/io/WriteHDF5.cpp
   MOAB/trunk/src/io/WriteHDF5.hpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
Log:
HDF5 writer bug fix and debug improvements
  o Don't create set contents table larger than necessary
  o Send all debug output through new DebugOutput utility
  o Instrument code with IODebugTrack
  o Add options to enable deboug output and use of IODebugTrack
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp	2010-05-06 23:06:29 UTC (rev 3857)
+++ MOAB/trunk/src/io/WriteHDF5.cpp	2010-05-06 23:08:34 UTC (rev 3858)
@@ -55,6 +55,7 @@
 #include "moab/WriteUtilIface.hpp"
 #include "FileOptions.hpp"
 #include "moab/Version.h"
+#include "IODebugTrack.hpp"
 #include "mhdf.h"
 /* Access HDF5 file handle for debugging
 #include <H5Fpublic.h>
@@ -63,13 +64,6 @@
 #undef DEBUG
 #ifdef DEBUG
-#  define DEBUGOUT(A) fputs( A, stderr )
-#  include <stdio.h>
-#else
-#endif
-#ifdef DEBUG
 # include <H5Epublic.h>
   extern "C" herr_t hdf_error_handler( void*  )
@@ -250,14 +244,12 @@
   Range::const_pair_iterator pi;
   for (pi = entities.const_pair_begin(); pi != entities.const_pair_end(); ++pi) {
     const EntityHandle n = pi->second - pi->first + 1;
-#ifdef DEBUG
-    printf( "Assigning %s %lu to %lu to file IDs [%lu,%lu]\n",
+    dbgOut.printf( 3, "Assigning %s %lu to %lu to file IDs [%lu,%lu]\n",
       CN::EntityTypeName(TYPE_FROM_HANDLE(pi->first)),
       (unsigned long)(ID_FROM_HANDLE(pi->first)),
       (unsigned long)(ID_FROM_HANDLE(pi->first)+n-1),
       (unsigned long)id,
       (unsigned long)(id+n-1));
-#endif
     if (!idMap.insert( pi->first, id, n ).second)
       return MB_FAILURE;
     id += n;
@@ -299,7 +291,8 @@
     writeSetContents(false),
     writeSetChildren(false),
     writeSetParents(false),
-    writeProp( H5P_DEFAULT )
+    writeProp( H5P_DEFAULT ),
+    dbgOut("H5M ", stderr)
