[MOAB-dev] r3857 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Thu May 6 18:06:29 CDT 2010
Author: kraftche
Date: 2010-05-06 18:06:29 -0500 (Thu, 06 May 2010)
New Revision: 3857
Modified:
MOAB/trunk/src/io/IODebugTrack.cpp
Log:
Fix bugs in code for debugging binary IO
Modified: MOAB/trunk/src/io/IODebugTrack.cpp
--- MOAB/trunk/src/io/IODebugTrack.cpp 2010-05-06 23:06:00 UTC (rev 3856)
+++ MOAB/trunk/src/io/IODebugTrack.cpp 2010-05-06 23:06:29 UTC (rev 3857)
@@ -1,4 +1,5 @@
#include "IODebugTrack.hpp"
+#include "moab/Range.hpp"
#include <iostream>
#include <vector>
#include <assert.h>
@@ -58,19 +59,44 @@
return;
- std::list<DRange>::const_iterator j, i = dataSet.begin();
- if (i->begin > 0) {
- ostr << PFX << tableName << " : [0," << i->begin-1 << "] : No Data Written!" << std::endl;
- ostr.flush();
+ std::list<DRange>::const_iterator i;
+ if (!maxSize) {
+ for (i = dataSet.begin(); i != dataSet.end(); ++i)
+ if (i->end >= maxSize)
+ maxSize = i->end + 1;
- j = i;
- for (++j; j != dataSet.end(); ++i, ++j)
- if (i->end + 1 != j->begin) {
- ostr << PFX << tableName << " : [" << i->end + 1 << "," << j->begin-1 << "] : No Data Written!" << std::endl;
- ostr.flush();
+ Range processed;
+ Range::iterator h = processed.begin();
+ bool wrote_zero = false;
+ for (i = dataSet.begin(); i != dataSet.end(); ++i) {
+ // ranges cannot contain zero
+ assert(i->begin <= i->end);
+ if (i->begin)
+ h = processed.insert( h, i->begin, i->end );
+ else {
+ wrote_zero = true;
+ if (i->end)
+ h = processed.insert( h, i->begin+1, i->end );
- if (maxSize && i->end + 1 < maxSize) {
- ostr << PFX << tableName << " : [" << i->end + 1 << "," << maxSize - 1 << "] : No Data Written!" << std::endl;
+ Range unprocessed;
+ if (maxSize > 1)
+ unprocessed.insert( 1, maxSize - 1 );
+ unprocessed = subtract( unprocessed, processed );
