[MOAB-dev] Reader/Writer filename extension access
Robert Smith
smithrm at mcs.anl.gov
Fri Apr 30 15:25:49 CDT 2010
I was not advocating passing back leaf-class pointers. I realize that
my 'A' option for finding extensions based on a ReaderIface*/
WriterIface* appears to do that but all of the code would be contained
within ReaderWriterSet. But on further inspection I see now that this
option would not actually work anyway.
My 'B' option was just another virtual function on ReaderIface/
WriterIface to return the list of extensions handled by the Reader/
Writer. This would not require the leaf-classes to be known in the
client. It just required another set of classes to contain the
information pertinent to a particular leaf class Reader/Writer
implementation set. And those classes are only known to that
particular Reader/Writer implementation set.
Either way, I don't think my solutions are the best given what I've
read today. Maybe I misunderstood the ticket. It seems that the
proposal of a way to get the actual format type used to read in the
file would be more useful along with the enhanced mechanism of
specifying format specific options to the load_file function.
--Bob
On Apr 30, 2010, at 1:25 PM, Tim Tautges wrote:
> Coupla comments:
> - I can't think of why we'll want to pass back leaf-class pointers
> to readers/writers through the API; parent class pointers should
> suffice in all cases, I would think
> - In most cases I think names of the reader/writer would be
> sufficient, and you could get those from ReaderWriterSet.
> - tim
> Jason Kraftcheck wrote:
>> Robert Smith wrote:
>>> On Apr 30, 2010, at 9:05 AM, Jed Brown wrote:
>>>> On Fri, 30 Apr 2010 09:01:09 -0500, Robert Smith <smithrm at mcs.anl.gov
>>>> wrote:
>>>>> What do you mean by "not part of the MOAB API"? We can't
>>>>> dictate the
>>>>> structure of the Readers/Writers?
>>>> I think Jason's point was that it's unacceptable for client code
>>>> to have
>>>> a dependency on the implementations.
>>> Do you mean the code that uses the Readers/Writers? I would
>>> agree, it
>>> should not depend on the implementation. But does that mean no
>>> client
>>> code can know which particular Reader/Writer it is using? If that's
>>> true then the entire purpose of the ticket seems moot.
>> No, the application needs to know the file format that it wants to
>> read/write. It does not need to have a pointer to the Reader/Writer
>> instance in MOAB that implements that file format. For example,
>> why not
>> instead have functions that return a list of string names for all the
>> readers and writers, and then have functions that, given a string
>> name,
>> return the list of extensions or description.
>>> If that's not what you mean then I don't see how my suggestions
>>> open the
>>> implementation to the users. They are just new member functions.
>> They require that we install headers for all the reader/writer
>> implementations and that the app include those headers, effectively
>> making
>> all of the implementations part of the MOAB API.
>> - jason
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
