[MOAB-dev] Reader/Writer filename extension access
Tim Tautges
tautges at mcs.anl.gov
Fri Apr 30 13:25:01 CDT 2010
Coupla comments:
- I can't think of why we'll want to pass back leaf-class pointers to readers/writers through the API; parent class
pointers should suffice in all cases, I would think
- In most cases I think names of the reader/writer would be sufficient, and you could get those from ReaderWriterSet.
- tim
Jason Kraftcheck wrote:
> Robert Smith wrote:
>> On Apr 30, 2010, at 9:05 AM, Jed Brown wrote:
>>> On Fri, 30 Apr 2010 09:01:09 -0500, Robert Smith <smithrm at mcs.anl.gov>
>>> wrote:
>>>> What do you mean by "not part of the MOAB API"? We can't dictate the
>>>> structure of the Readers/Writers?
>>> I think Jason's point was that it's unacceptable for client code to have
>>> a dependency on the implementations.
>> Do you mean the code that uses the Readers/Writers? I would agree, it
>> should not depend on the implementation. But does that mean no client
>> code can know which particular Reader/Writer it is using? If that's
>> true then the entire purpose of the ticket seems moot.
> No, the application needs to know the file format that it wants to
> read/write. It does not need to have a pointer to the Reader/Writer
> instance in MOAB that implements that file format. For example, why not
> instead have functions that return a list of string names for all the
> readers and writers, and then have functions that, given a string name,
> return the list of extensions or description.
>> If that's not what you mean then I don't see how my suggestions open the
>> implementation to the users. They are just new member functions.
> They require that we install headers for all the reader/writer
> implementations and that the app include those headers, effectively making
> all of the implementations part of the MOAB API.
> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
