[MOAB-dev] r3792 - MOAB/trunk/test
iulian at mcs.anl.gov
Mon Apr 19 11:18:01 CDT 2010
Author: iulian
Date: 2010-04-19 11:18:00 -0500 (Mon, 19 Apr 2010)
New Revision: 3792
Modified:
MOAB/trunk/test/MBTest.cpp
Log:
some typos in mb_forced_adjacencies_test
Modified: MOAB/trunk/test/MBTest.cpp
--- MOAB/trunk/test/MBTest.cpp 2010-04-18 23:44:49 UTC (rev 3791)
+++ MOAB/trunk/test/MBTest.cpp 2010-04-19 16:18:00 UTC (rev 3792)
@@ -4342,21 +4342,21 @@
//! there should be only 1 entity adjacent to edge1
if (edge1_adjacencies.size() != 1)
- return error;
+ return MB_FAILURE;
//! and that entity should be quad1
if (edge1_adjacencies[0] != quad1)
- return error;
- //! try getting the adjacency of edge6 (should be none)
+ //! try getting the adjacency of edge6 (should be one)
std::vector<EntityHandle> edge6_adjacencies;
error = MB->get_adjacencies(&(edge6), 1, 2, false, edge6_adjacencies);
if (error != MB_SUCCESS)
return error;
- //! there should be only 1 entity adjacent to edge1
- if (edge1_adjacencies.size() != 0)
- return error;
+ //! there should be only 1 entity adjacent to edge6
+ if (edge6_adjacencies.size() != 1)
//! Now seal up the "gap" caused by edges 4 and 5. Remove edge5
//! from the adjacencies of quad2 and add edge 4 to quad2.
@@ -4369,6 +4369,8 @@
std::vector<EntityHandle> edge4_adjacencies(1, edge4);
error = MB->add_adjacencies(quad2, &edge4_adjacencies[0], edge4_adjacencies.size(), true);
+ if (error != MB_SUCCESS)
+ return error;
//! get the adjacencies of edge4 and it should return both quads.
std::vector<EntityHandle> quad_adjacencies;
@@ -4378,13 +4380,13 @@
//! there should be 2 entities adjacent to edge4
if (quad_adjacencies.size() != 2)
- return error;
//! and they should be quad1 and quad2. Note that we are not saying anything
//! about order in the array.
- if ( (quad_adjacencies[0] != quad1 || quad_adjacencies[1] != quad1) &&
