[MOAB-dev] r3791 - MOAB/trunk/src
kraftche at cae.wisc.edu
Sun Apr 18 18:44:49 CDT 2010
Author: kraftche
Date: 2010-04-18 18:44:49 -0500 (Sun, 18 Apr 2010)
New Revision: 3791
Modified:
MOAB/trunk/src/Core.cpp
Log:
Move check for whether or not a file exists to a later point in load_file,
so that for a parallel read modes where not all processors read the file, the
file is only checked for on the node(s) that are actually reading it.
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2010-04-18 13:59:39 UTC (rev 3790)
+++ MOAB/trunk/src/Core.cpp 2010-04-18 23:44:49 UTC (rev 3791)
@@ -368,28 +368,6 @@
const int* set_tag_vals,
int num_set_tag_vals )
- int status;
-#if defined(WIN32) || defined(WIN64) || defined(MSC_VER)
- struct _stat stat_data;
- status = _stat(file_name, &stat_data);
-#else
- struct stat stat_data;
- status = stat(file_name, &stat_data);
-#endif
- if (status) {
- mError->set_last_error( "%s: %s", file_name, strerror(errno) );
- return MB_FILE_DOES_NOT_EXIST;
- else if (_S_IFDIR(stat_data.st_mode)) {
-#else
- else if (S_ISDIR(stat_data.st_mode)) {
-#endif
- mError->set_last_error( "%s: Cannot read directory/folder.", file_name );
FileOptions opts(options);
ErrorCode rval;
ReaderIface::IDTag t = { set_tag_name, set_tag_vals, num_set_tag_vals, 0, 0 };
@@ -468,6 +446,27 @@
int num_sets,
const Tag* id_tag )
+ int status;
+#if defined(WIN32) || defined(WIN64) || defined(MSC_VER)
+ struct _stat stat_data;
+ status = _stat(file_name, &stat_data);
+#else
+ struct stat stat_data;
+ status = stat(file_name, &stat_data);
+#endif
+ if (status) {
+ mError->set_last_error( "%s: %s", file_name, strerror(errno) );
+ return MB_FILE_DOES_NOT_EXIST;
+ else if (_S_IFDIR(stat_data.st_mode)) {
