[MOAB-dev] Getting ent set data when tag_size > 1
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Apr 19 09:51:08 CDT 2010
Yeah.  Believe it or not, that implementation predates the current sequence implementation in MOAB.
As a more general point, on this same subject, there needs to be a more accessible way of iterating over contiguous
blocks of handles, in MOAB's interface at least, and possibly in iMesh (or an extension).  This may have more to do with
documentation than anything else.
- tim
Jed Brown wrote:
> On Sun, 18 Apr 2010 14:04:23 -0500, James Porter <jvporter at wisc.edu> wrote:
>> There are also places where interleaved storage seems to be preferred,
>> e.g. iMesh_createVtxArr:
>> <http://trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp#L1254>
>> Whether the internal memory structure is interleaved or not, the blocked
>> versions of every function I see are more complicated than the
>> interleaved versions. It seems like the "default" really is interleaved,
>> even if it's organized differently in memory.
> This reminds me that it was seeing such things in the iMesh_MOAB source
> that suggested that INTERLEAVED was the native format.  If MOAB's
> internal storage is actually BLOCKED then presumably the iMesh
> implementation could be updated at some arbitrary point in the future
> (when someone is bored. ;-)).
> Jed
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
