[MOAB-dev] r3762 - MOAB/trunk/src/parallel
    kraftche at cae.wisc.edu
    Fri Apr  9 08:50:26 CDT 2010
Author: kraftche
Date: 2010-04-09 08:50:26 -0500 (Fri, 09 Apr 2010)
New Revision: 3762
Modified:
   MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
fix performance issue in ParallelComm
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp	2010-04-08 19:46:10 UTC (rev 3761)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp	2010-04-09 13:50:26 UTC (rev 3762)
@@ -3676,26 +3676,26 @@
   ErrorCode result = mbImpl->tag_get_data(pstatus_tag(), ents,
                                             &shared_flags[0]);
   RRA("Failed to get pstatus flag.");
-  Range::const_iterator rit;
+  Range::const_iterator rit, hint = tmp_ents.begin();;
   int i;
   if (op == PSTATUS_OR) {
     for (rit = ents.begin(), i = 0; rit != ents.end(); rit++, i++)
       if (((shared_flags[i] & ~pstat)^shared_flags[i]) & pstat) {
-        tmp_ents.insert(*rit);
+        hint = tmp_ents.insert(hint,*rit);
         if (-1 != to_proc) shared_flags2.push_back(shared_flags[i]);
   else if (op == PSTATUS_AND) {
       if ((shared_flags[i] & pstat) == pstat) {
   else if (op == PSTATUS_NOT) {
       if (!(shared_flags[i] & pstat)) {
@@ -3709,6 +3709,7 @@
     int sharing_procs[MAX_SHARING_PROCS];
     std::fill(sharing_procs, sharing_procs+MAX_SHARING_PROCS, -1);
     Range tmp_ents2;
+    hint = tmp_ents2.begin();
     for (rit = tmp_ents.begin(), i = 0; rit != tmp_ents.end(); rit++, i++) {
         // we need to check sharing procs
@@ -3720,7 +3721,7 @@
         for (unsigned int j = 0; j < MAX_SHARING_PROCS; j++) {
             // if to_proc shares this entity, add it to list
           if (sharing_procs[j] == to_proc) {
-            tmp_ents2.insert(*rit);
+            hint = tmp_ents2.insert(hint, *rit);
           else if (sharing_procs[j] == -1) break;
