[MOAB-dev] r3761 - MOAB/trunk/test/parallel
    smithrm at mcs.anl.gov
    Thu Apr  8 14:46:10 CDT 2010
Author: smithrm
Date: 2010-04-08 14:46:10 -0500 (Thu, 08 Apr 2010)
New Revision: 3761
Modified:
   MOAB/trunk/test/parallel/uber_parallel_test.cpp
Log:
o Fixed Ticket #157.  Some of the tests were supposed to use BCAST_DELETE but they were using READ_DELETE.
Modified: MOAB/trunk/test/parallel/uber_parallel_test.cpp
--- MOAB/trunk/test/parallel/uber_parallel_test.cpp	2010-04-08 19:44:09 UTC (rev 3760)
+++ MOAB/trunk/test/parallel/uber_parallel_test.cpp	2010-04-08 19:46:10 UTC (rev 3761)
@@ -94,11 +94,11 @@
   num_errors += RUN_TEST( test_read, filename, option );
     //=========== bcast_delete, geom_dimension, resolve_shared
-  option = "PARALLEL=READ_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;";
+  option = "PARALLEL=BCAST_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;";
     //=========== bcast_delete, material_set, resolve_shared
-  option = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;";
+  option = "PARALLEL=BCAST_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;";
     //=========== read_delete, geom_dimension, resolve_shared, exch ghost
@@ -110,11 +110,11 @@
     //=========== bcast_delete, geom_dimension, resolve_shared, exch ghost
-  option = "PARALLEL=READ_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
+  option = "PARALLEL=BCAST_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
     //=========== bcast_delete, material_set, resolve_shared, exch ghost
-  option = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
+  option = "PARALLEL=BCAST_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
   MPI_Finalize();
