[MOAB-dev] r3739 - MOAB/trunk/tools
    kraftche at cae.wisc.edu
    Thu Apr  1 17:14:56 CDT 2010
Author: kraftche
Date: 2010-04-01 17:14:56 -0500 (Thu, 01 Apr 2010)
New Revision: 3739
Modified:
   MOAB/trunk/tools/mbconvert.man
Log:
update man page for mbconvert
Modified: MOAB/trunk/tools/mbconvert.man
--- MOAB/trunk/tools/mbconvert.man	2010-04-01 22:14:45 UTC (rev 3738)
+++ MOAB/trunk/tools/mbconvert.man	2010-04-01 22:14:56 UTC (rev 3739)
@@ -5,9 +5,17 @@
 .B mbconvert [-h|-l]
 .B mbconvert
-.B [-a
+.B [-f
+.I format
+.B ] [-a
 .I sat_file
-.B |-A] [-t] [-g] [-v
+.B |-A] [-t] [-g] [-o
+.I option
+.B ] [-O
+.I option
+.B ] [-I
+.I dim
+.B ] [-p|-P] [-v
 .I vol_id_list
 .B ] [-s
 .I surf_id_list
@@ -27,7 +35,9 @@
 .B mbconvert
 uses the MOAB library to translate between mesh file formats or
 to extract subsets of mesh files.  The type of the output file
-is determined from the file extension.  The
+is determined from the file extension if the
+.B -f
+flag is not specified.  The
 .B -l
 option can be used to list the file formats supported.
@@ -43,6 +53,14 @@
 union of all of the subset options.  If no subset options are specified
 the entire input mesh is written to the output file.
+String options for use with the
+.B -o
+and
+.B -O
+flags are documented in the
+.I README.IO
+file.
 .SH OPTIONS
 .IP -h
 Print help to stdout and exit.
@@ -51,11 +69,22 @@
