[MOAB-dev] r3738 - MOAB/trunk/tools
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Apr 1 17:14:45 CDT 2010
Author: kraftche
Date: 2010-04-01 17:14:45 -0500 (Thu, 01 Apr 2010)
New Revision: 3738
Modified:
   MOAB/trunk/tools/convert.cpp
Log:
fix broken -P flag and add new, more powerful -p flag
Modified: MOAB/trunk/tools/convert.cpp
--- MOAB/trunk/tools/convert.cpp	2010-04-01 21:21:11 UTC (rev 3737)
+++ MOAB/trunk/tools/convert.cpp	2010-04-01 22:14:45 UTC (rev 3738)
@@ -25,6 +25,7 @@
 #include "MBTagConventions.hpp"
 #include "moab/ReaderWriterSet.hpp"
 #include <iostream>
+#include <sstream>
 #include <iomanip>
 #include <set>
 #include <cstdlib>
@@ -68,7 +69,8 @@
     << "\t-l             - List available file formats and exit." << std::endl
     << "\t-I <dim>       - Generate internal entities of specified dimension." << std::endl
 #ifdef USE_MPI
-    << "\t-P             - Append processor ID to file name" << std::endl
+    << "\t-P             - Append processor ID to output file name" << std::endl
+    << "\t-p             - Replace '%' with processor ID in input and output file name" << std::endl
 #endif
     << "\t--             - treat all subsequent options as file names" << std::endl
     << "\t                 (allows file names beginning with '-')" << std::endl
@@ -131,11 +133,14 @@
 void remove_entities_from_sets( Interface* gMB, Range& dead_entities, Range& empty_sets );
 void remove_from_vector( std::vector<EntityHandle>& vect, const Range& ents_to_remove );
 bool make_opts_string( std::vector<std::string> options, std::string& result );
+std::string percent_subst( const std::string& s, int val );
 int main(int argc, char* argv[])
+  int proc_id = 0;
 #ifdef USE_MPI
   MPI_Init(&argc,&argv);
+  MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
 #endif
@@ -143,15 +148,15 @@
   ErrorCode result;
   Range range;
-  int proc_id = 0;
   gMB = new Core();
   bool append_rank = false;
+  bool percent_rank_subst = false;
   int i, dim;
   bool dims[4] = {false, false, false, false};
   const char* format = NULL; // output file format
-  const char* in = NULL;    // input file name
-  const char* out = NULL;   // output file name
