[MOAB-dev] problems reading meshes in MOAB in the 'read_part'	mode
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Thu Apr  1 14:14:08 CDT 2010
I guess it was somewhat strong, but what I really meant is this:
"For whatever reason I can't seem to make 'read_part' work with any mesh
or any machine with any number of procs I have tried recently, so
for the purpose of my task at hand -- benchmarking of parallel reads --
I will avoid using 'read_part', at least for now."
The reason I brought up the various reported errors was to marshal evidence
that the problem is probably with 'read_part' itself -- not the meshes
I feed it.
I can definitely be wrong here, however.
Dmitry.
On Thu, Apr 1, 2010 at 1:00 PM, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> Dmitry Karpeev wrote:
>> Yes, I think the file is "broken" in the sense you just described.
>> The reason I mentioned it is that, I think, the way 'read_part' fails
>> to read this file
>> indicates a problem with 'read_part'.  Ordinarily, I would expect the
>> failure to have
>> something to do with the aforementioned bad partition (that's what
>> 'bcast_delete'
>> complains about). Instead, 'read_part' fails on this file the same way
>> it fails on other,
>> properly partitioned files.
> "I conclude ... that the 'read_part' mode is currently broken" is a rather
> strong way to express your dislike for way it reports errors.  In fact,
> there might even be a bit or irony there :).
> - jason
