[MOAB-dev] problems reading meshes in MOAB in the 'read_part' mode
Jason Kraftcheck kraftche at cae.wisc.edu
Thu Apr 1 14:00:05 CDT 2010
Dmitry Karpeev wrote:
> Yes, I think the file is "broken" in the sense you just described.
> The reason I mentioned it is that, I think, the way 'read_part' fails
> to read this file
> indicates a problem with 'read_part'.  Ordinarily, I would expect the
> failure to have
> something to do with the aforementioned bad partition (that's what
> 'bcast_delete'
> complains about). Instead, 'read_part' fails on this file the same way
> it fails on other,
> properly partitioned files.
"I conclude ... that the 'read_part' mode is currently broken" is a rather
strong way to express your dislike for way it reports errors.  In fact,
there might even be a bit or irony there :).
- jason
