[MOAB-dev] disable-fortran [Was: Re: AdaptiveKDTree.cpp: need to move mpi include out of moab namespace]
    Jed Brown
    jed at 59A2.org
    Tue Mar 30 21:01:34 CDT 2010
On Tue, 30 Mar 2010 14:56:19 -0500, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> I think the problem is with the version of libtool that you have installed.
>  Which version are you using?  It seems to be running the configure tests
> for Fortran regardless of what we ask for in the configure script.  If this
> is the problem, then the attached patch should work around the problem.  It
> will disable FORTRAN name mangling regardless of whether or not a FORTRAN
> compiler is configured.  Please let me know if this works.
This works, I have libtool-2.2.6b.
Jed
