[MOAB-dev] disable-fortran [Was: Re: AdaptiveKDTree.cpp: need to move mpi include out of moab namespace]
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue Mar 30 14:56:19 CDT 2010
I think the problem is with the version of libtool that you have installed.
 Which version are you using?  It seems to be running the configure tests
for Fortran regardless of what we ask for in the configure script.  If this
is the problem, then the attached patch should work around the problem.  It
will disable FORTRAN name mangling regardless of whether or not a FORTRAN
compiler is configured.  Please let me know if this works.
- jason
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100330/52a954d9/attachment.bin>
