[MOAB-dev] r3724 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Mon Mar 29 16:06:55 CDT 2010
Author: kraftche
Date: 2010-03-29 16:06:55 -0500 (Mon, 29 Mar 2010)
New Revision: 3724
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
Fix bugs in ParallelComm:
o In exhange_tags, special case if range is empty because get_entities_by_type_and_tag
w/ Interface::INTERSECT does something quite different if input range is empty.
o Pass back only one copy of data for local proc from get_sharing_parts.
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2010-03-29 16:17:13 UTC (rev 3723)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2010-03-29 21:06:55 UTC (rev 3724)
@@ -4933,30 +4933,34 @@
result = filter_pstatus(owned_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT);
RRA("Failure to get subset of owned entities");
- for (size_t i = 0; i < src_tags.size(); ++i) {
- if (src_tags[i] == dst_tags[i])
- continue;
- Range tagged_ents(owned_ents);
- result = mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE,
- &src_tags[0], 0, 1, tagged_ents, Interface::INTERSECT );
- RRA("get_entities_by_type_and_tag(type == MBMAXTYPE) failed.");
- int size, size2;
- result = mbImpl->tag_get_size( src_tags[i], size );
- RRA("tag_get_size failed.");
- result = mbImpl->tag_get_size( dst_tags[i], size2 );
- if (size != size2) {
- result = MB_FAILURE;
- RRA("tag sizes don't match")
+ if (!owned_ents.empty()) { // check this here, otherwise we get
+ // unexpected results from get_entities_by_type_and_tag w/ Interface::INTERSECT
+ for (size_t i = 0; i < src_tags.size(); ++i) {
+ if (src_tags[i] == dst_tags[i])
+ continue;
+ Range tagged_ents(owned_ents);
+ result = mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE,
+ &src_tags[0], 0, 1, tagged_ents, Interface::INTERSECT );
+ RRA("get_entities_by_type_and_tag(type == MBMAXTYPE) failed.");
+ int size, size2;
+ result = mbImpl->tag_get_size( src_tags[i], size );
+ RRA("tag_get_size failed.");
+ result = mbImpl->tag_get_size( dst_tags[i], size2 );
+ if (size != size2) {
+ result = MB_FAILURE;
+ RRA("tag sizes don't match")
+ data.resize( size * tagged_ents.size() );
+ result = mbImpl->tag_get_data( src_tags[i], tagged_ents, &data[0] );
+ RRA("tag_get_data failed.");
+ result = mbImpl->tag_set_data( dst_tags[i], tagged_ents, &data[0] );
+ RRA("tag_set_data failed.");
- data.resize( size * tagged_ents.size() );
- result = mbImpl->tag_get_data( src_tags[i], tagged_ents, &data[0] );
- RRA("tag_get_data failed.");
- result = mbImpl->tag_set_data( dst_tags[i], tagged_ents, &data[0] );
- RRA("tag_set_data failed.");
@@ -5821,7 +5825,11 @@
// Count number of valid (positive) entries in sharedps_tag
for (num_part_ids_out = 0; num_part_ids_out < MAX_SHARING_PROCS &&
part_ids_out[num_part_ids_out] >= 0; ++num_part_ids_out);
- part_ids_out[num_part_ids_out++] = proc_config().proc_rank();
+ //part_ids_out[num_part_ids_out++] = proc_config().proc_rank();
+#ifndef NDEBUG
+ int my_idx = std::find(part_ids_out, part_ids_out+num_part_ids_out, proc_config().proc_rank()) - part_ids_out;
+ assert(my_idx < num_part_ids_out);
+#endif
// done?
if (!remote_handles)
@@ -5829,7 +5837,9 @@
// get remote handles
result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, remote_handles );
- remote_handles[num_part_ids_out-1] = entity;
+ //remote_handles[num_part_ids_out-1] = entity;
+ assert(remote_handles[my_idx] == entity);
return result;
