[MOAB-dev] AdaptiveKDTree.cpp: need to move mpi include out of moab	namespace
    Jed Brown
    jed at 59A2.org
    Mon Mar 29 13:49:46 CDT 2010
On Mon, 29 Mar 2010 07:27:18 -0500, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> Jed Brown wrote:
> > On Mon, 15 Mar 2010 10:29:32 -0500, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> >> Both issues should now be fixed.  The new way to disable fortran name
> >> mangling (for all C APIs) is to specify --disable-fortran.
> > The symbols are still mangled, config.log attached.
> I can't reproduce this.  If I configure w/ --disable-fortran, I see nothing
> about Fortran in any of the configure output (as expected), and src/FCDefs.h
>  contains no defines.
I don't know what to say, I have just pulled trunk again, deleted the
build directory and reconfigured with identical options to above.  I see
Fortran output from configure and and all the symbols have been mangled,
src/FCDefs.h attached.
Jed
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100329/e41440bb/attachment.h>
