[MOAB-dev] r3710 - MOAB/trunk/src
kraftche at cae.wisc.edu
Thu Mar 25 12:58:56 CDT 2010
Author: kraftche
Date: 2010-03-25 12:58:56 -0500 (Thu, 25 Mar 2010)
New Revision: 3710
Modified:
MOAB/trunk/src/AEntityFactory.cpp
Log:
fix bugs in estimation of memory used for storing adjacencies
Modified: MOAB/trunk/src/AEntityFactory.cpp
--- MOAB/trunk/src/AEntityFactory.cpp 2010-03-25 16:56:32 UTC (rev 3709)
+++ MOAB/trunk/src/AEntityFactory.cpp 2010-03-25 17:58:56 UTC (rev 3710)
@@ -1451,14 +1451,14 @@
if (prev_data != (*i)->data()) {
prev_data = (*i)->data();
- memory_total += prev_data->size() * sizeof(AdjacencyVector);
+ memory_total += prev_data->size() * sizeof(AdjacencyVector*);
const AdjacencyVector* vec;
for (EntityHandle h = (*i)->start_handle(); h <= (*i)->end_handle(); ++h) {
get_adjacency_ptr( h, vec );
if (vec)
- entity_total += vec->capacity() * sizeof(EntityHandle) * sizeof(AdjacencyVector);
+ entity_total += vec->capacity() * sizeof(EntityHandle) + sizeof(AdjacencyVector);
@@ -1472,6 +1472,7 @@
unsigned long& amortized )
min_per_ent = amortized = 0;
+ SequenceData* prev_data = 0;
RangeSeqIntersectIter iter( thisMB->sequence_manager() );
ErrorCode rval = iter.init( ents_in.begin(), ents_in.end() );
if (MB_SUCCESS != rval)
@@ -1487,10 +1488,13 @@
->entity_map( iter.get_sequence()->type() )
.get_occupied_size( iter.get_sequence()->data() );
- amortized += sizeof(AdjacencyVector*)
- * iter.get_sequence()->data()->size()
- * count / data_occ;
+ if (iter.get_sequence()->data() != prev_data) {
+ prev_data = iter.get_sequence()->data();
+ amortized += sizeof(AdjacencyVector*)
+ * iter.get_sequence()->data()->size()
+ * count / data_occ;
array += iter.get_start_handle() - iter.get_sequence()->data()->start_handle();
for (EntityID i = 0; i < count; ++i) {
if (array[i])
