[MOAB-dev] r3709 - in MOAB/trunk: . tools
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Mar 25 11:56:32 CDT 2010
Author: kraftche
Date: 2010-03-25 11:56:32 -0500 (Thu, 25 Mar 2010)
New Revision: 3709
Added:
   MOAB/trunk/tools/mbmem.cpp
Modified:
   MOAB/trunk/configure.ac
   MOAB/trunk/tools/Makefile.am
Log:
add tool to read in a file and print moab memory usage stats
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2010-03-24 21:09:22 UTC (rev 3708)
+++ MOAB/trunk/configure.ac	2010-03-25 16:56:32 UTC (rev 3709)
@@ -470,6 +470,7 @@
 MB_OPTIONAL_TOOL([mbsize],       [yes])
 MB_OPTIONAL_TOOL([mbskin],       [yes])
 MB_OPTIONAL_TOOL([mbtagprop],    [yes])
+MB_OPTIONAL_TOOL([mbmem],        [yes])
 MB_OPTIONAL_TOOL([mcnpmit],      [no])
 MB_OPTIONAL_TOOL([mbcoupler],    [$ENABLE_mcnpmit] )
 MB_OPTIONAL_TOOL([spheredecomp], [yes])
Modified: MOAB/trunk/tools/Makefile.am
--- MOAB/trunk/tools/Makefile.am	2010-03-24 21:09:22 UTC (rev 3708)
+++ MOAB/trunk/tools/Makefile.am	2010-03-25 16:56:32 UTC (rev 3709)
@@ -53,6 +53,10 @@
   doc_DATA += README.mbtagprop
 endif
+if ENABLE_mbmem
+  bin_PROGRAMS += mbmem
+endif
 if ENABLE_spheredecomp
   bin_PROGRAMS += spheredecomp
   doc_DATA += README.spheredecomp
Added: MOAB/trunk/tools/mbmem.cpp
--- MOAB/trunk/tools/mbmem.cpp	                        (rev 0)
+++ MOAB/trunk/tools/mbmem.cpp	2010-03-25 16:56:32 UTC (rev 3709)
@@ -0,0 +1,435 @@
+#include "moab/Core.hpp"
+#include "moab/Range.hpp"
+#include "moab/CN.hpp"
+#include <iostream>
+#include <iomanip>
+#include <sstream>
+#include <string>
+#include <cstdio>
+#include <cstdlib>
+#ifndef _MSC_VER
+#include <sys/times.h>
+#include <sys/resource.h>
+#endif
+void usage( const char* argv0 )
+  std::cerr << "Usage: " << argv0 << " [-h|-b|-k|-m] <filename> [<filename> ...]" << std::endl
+            << "  -h : human readable units" << std::endl
+            << "  -b : bytes" << std::endl
+            << "  -k : kilobytes (1 kB == 1024 bytes)" << std::endl
+            << "  -m : megabytes (1 MB == 1024 kB)" << std::endl
+            << "  -g : gigabytes (1 GB == 1024 MB)" << std::endl
+            << std::endl;
+  std::exit(1);
+enum Units { HUMAN, BYTES, KILOBYTES, MEGABYTES, GIGABYTES };
+Units UNITS = HUMAN;
+  // The core functionality of this example
+void print_memory_stats( moab::Interface& mb );
+  // main routine: read any specified files and call print_memory_stats
+int main( int argc, char* argv[] )
+  moab::Core mbcore;
+  moab::Interface& mb = mbcore;
+  moab::ErrorCode rval;
+  bool no_more_flags = false;
+    // load each file specified on command line
+  for (int i = 1; i < argc; ++i) {
+    if (!no_more_flags && argv[i][0] == '-') {
+      if (!strcmp(argv[i],"-h"))
+        UNITS = HUMAN;
+      else if(!strcmp(argv[i],"-b"))
+        UNITS = BYTES;
+      else if(!strcmp(argv[i],"-k"))
+        UNITS = KILOBYTES;
+      else if(!strcmp(argv[i],"-m"))
+        UNITS = MEGABYTES;
+      else if(!strcmp(argv[i],"-g"))
+        UNITS = GIGABYTES;
+      else if(!strcmp(argv[i],"--"))
+        no_more_flags = true;
+      else
+        usage(argv[0]);
+    else {
+      rval = mb.load_file(argv[i]);
+        // if file load failed, print some info and exit
+      if (moab::MB_SUCCESS != rval) {
+        std::string message;
+        mb.get_last_error( message );
+        std::cerr << mb.get_error_string(rval) << ": " << message << std::endl
+                  << argv[i] << ": Failed to read file." << std::endl;
+        return 1;
+    // print summary of MOAB's memory use
+  print_memory_stats(mb);
+  return 0;
+  // struct to store memory stats
+struct MemStats {
+  unsigned long total_storage;
+  unsigned long total_amortized;
+  unsigned long entity_storage;
+  unsigned long entity_amortized;
+  unsigned long adjacency_storage;
+  unsigned long adjacency_amortized;
+  unsigned long tag_storage;
+  unsigned long tag_amortized;
+ // test if MemStats object indicates no memory
+bool is_zero( const MemStats& stats );
+  // populdate a MemStats structg by calling
+  // moab::Interface::estimated_memory_use
+void get_mem_stats( moab::Interface& mb,
+                    MemStats& data,
+                    moab::EntityType type = moab::MBMAXTYPE );
+  // Formatted string representation of memory size value
+std::string memstr( unsigned long val );
+  // Get string describing tag data type
+std::string tag_type_string( moab::Interface& mb, moab::Tag tag );
+  // Get string representation of tag storage type
+std::string tag_storage_string( moab::Interface& mb, moab::Tag tag );
+  // Center
+std::string center( const char* str, size_t width );
+  const char ANON_TAG_NAME[] = "(anonymous)";
+  const int TYPE_WIDTH = 10;
+  const int MEM_WIDTH = 7;
+  const int MEM2_WIDTH = 2*MEM_WIDTH+1;
+  const int MIN_TAG_NAME_WIDTH = strlen(ANON_TAG_NAME);
+  const int DTYPE_WIDTH = 12;
+  const int STORAGE_WIDTH = 8;
+    // per-entity-type table header
+  MemStats stats;
+  std::cout.fill(' ');
+  std::cout << std::left << std::setw(TYPE_WIDTH) << "Type" << ' '
+            << center("Total",MEM2_WIDTH) << ' '
+            << center("Entity",MEM2_WIDTH) << ' '
+            << center("Adjacency",MEM2_WIDTH) << ' '
+            << center("Tag",MEM2_WIDTH) << ' '
+            << std::endl << std::setw(TYPE_WIDTH) << " ";
+  for (int i = 0; i < 4; ++i)
+    std::cout << ' ' << std::left << std::setw(MEM_WIDTH) << "Used"
+              << ' ' << std::left << std::setw(MEM_WIDTH) << "Alloc";
+  std::cout << std::endl;
+  std::cout.fill('-');
+  std::cout << std::setw(TYPE_WIDTH) << '-';
+  for (int i = 0; i < 8; ++i)
+    std::cout << ' ' << std::setw(MEM_WIDTH) << '-';
+    // per-entity-type memory use
+  for (moab::EntityType t = moab::MBVERTEX; t != moab::MBMAXTYPE; ++t) {
+    get_mem_stats( mb, stats, t );
+    if (is_zero(stats)) continue;  // skip types with no allocated memory
+    std::cout << std::left << std::setw(TYPE_WIDTH) << moab::CN::EntityTypeName(t) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.total_storage) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.total_amortized) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.entity_storage) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.entity_amortized) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.adjacency_storage) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.adjacency_amortized) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.tag_storage) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(stats.tag_amortized) << std::endl;
+    // get list of tags
+  std::vector<moab::Tag> tags;
+  std::vector<moab::Tag>::const_iterator ti;
+  mb.tag_get_tags( tags );
+    // figure out required field with to fit longest tag name
+  unsigned maxlen = MIN_TAG_NAME_WIDTH;
+  for (ti = tags.begin(); ti != tags.end(); ++ti) {
+    std::string name;
+    rval = mb.tag_get_name( *ti, name );
+      continue;
+    if (name.size() > maxlen)
+      maxlen = name.size();
+    // print header for per-tag data
+  if (!tags.empty()) {
+              << std::left << std::setw(maxlen) << "Tag Name" << ' '
+              << std::left << std::setw(DTYPE_WIDTH) << "Type" << ' '
+              << std::left << std::setw(STORAGE_WIDTH) << "Storage" << ' '
+              << std::left << std::setw(MEM_WIDTH) << "Used" << ' '
+              << std::left << std::setw(MEM_WIDTH) << "Alloc" << std::endl;
+    std::cout << std::setw(maxlen) << '-' << ' '
+              << std::setw(DTYPE_WIDTH) << '-' << ' '
+              << std::setw(STORAGE_WIDTH) << '-' << ' '
+              << std::setw(MEM_WIDTH) << '-' << ' '
+              << std::setw(MEM_WIDTH) << '-' << std::endl;
+    // print per-tag memory use
+    std::string name;
+    if (moab::MB_SUCCESS != rval || name.empty())
+      name = ANON_TAG_NAME;
+    unsigned long occupied, allocated;
+    mb.estimated_memory_use( 0, 0, 0, 0, 0, 0, 0, 0, &*ti, 1, &occupied, &allocated );
+    std::cout << std::left << std::setw(maxlen) << name << ' '
+              << std::right << std::setw(DTYPE_WIDTH) << tag_type_string(mb,*ti) <<  ' '
+              << std::right << std::setw(STORAGE_WIDTH) << tag_storage_string(mb,*ti) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(occupied) << ' '
+              << std::right << std::setw(MEM_WIDTH) << memstr(allocated) << std::endl;
+    // print summary of overall memory use
+  get_mem_stats( mb, stats );
+            << "TOTAL: (Used/Allocated)" << std::endl
+            << "memory:    " << memstr(stats.total_storage) << "/" << memstr(stats.total_amortized) << std::endl
+            << "entity:    " << memstr(stats.entity_storage) << "/" << memstr(stats.entity_amortized) << std::endl
+            << "adjacency: " << memstr(stats.adjacency_storage) << "/" << memstr(stats.adjacency_amortized) << std::endl
+            << "tag:       " << memstr(stats.tag_storage) << "/" << memstr(stats.tag_amortized) << std::endl
+            << std::endl;
+  std::FILE* filp = std::fopen("/proc/self/stat", "r");
+  unsigned long vsize, rss;
+  if (filp && 2 == std::fscanf(filp,
+                "%*d " // pid
+                "%*s " // comm
+                "%*c " // state
+                "%*d " // ppid
+                "%*d " // pgrp
+                "%*d " // session
+                "%*d " // tty_nr
+                "%*d " // tpgid
+                "%*u " // flags
+                "%*u " // minflt
+                "%*u " // cminflt
+                "%*u " // majflt
+                "%*u " // cmajflt
+                "%*u " // utime
+                "%*u " // stime
+                "%*d " // cutime
+                "%*d " // cstime
+                "%*d " // priority
+                "%*d " // nice
+                "%*d " // num_threads
+                "%*d " // itrealvalue
+                "%*u " // starttime
+                "%lu " // vsize
+                "%ld", // rss
+                &vsize, &rss )) {
+#ifndef _MSC_VER
+    rss *= getpagesize();
+#endif
+    std::cout << std::endl << "SYSTEM:"
+              << std::endl << "Virtual memory:    " << memstr(vsize)
+              << std::endl << "Resident set size: " << memstr(rss)
+              << std::endl;
+  else {
+#ifndef _MSC_VER
+    struct rusage sysdata;
+    if (getrusage( RUSAGE_SELF, &sysdata )) {
+      std::cerr << "getrusage failed" << std::endl;
+    else {
+      unsigned long rss = sysdata.ru_maxrss;
+      std::cerr << std::endl << "SYSTEM:"
+                << std::endl;
+#endif
+bool is_zero( const MemStats& stats ) { return stats.total_amortized == 0; }
+                    MemStats& data,
+                    moab::EntityType type )
+  if (type != moab::MBMAXTYPE) {
+    moab::Range range;
+    mb.get_entities_by_type( 0, type, range );
+    mb.estimated_memory_use( range,
+                             &data.total_storage,
+                             &data.total_amortized,
+                             &data.entity_storage,
+                             &data.entity_amortized,
+                             &data.adjacency_storage,
+                             &data.adjacency_amortized,
+                             0, 0,
+                             &data.tag_storage,
+                             &data.tag_amortized );
+  else {
+                             0, 0,
+// rounded division
+unsigned long rdiv( unsigned long num, unsigned long den )
+  return (num + den/2) / den;
+  const unsigned long kb = 1024;
+  const unsigned long mb = kb*kb;
+  const unsigned long gb = kb*mb;
+  const unsigned long tb = kb*gb;
+  std::ostringstream s;
+  if (UNITS == HUMAN) {
+    if (val >= 10*tb)
+      s << rdiv( val, tb ) << "TB";
+    else if (val >= 10*gb)
+      s << rdiv( val, gb ) << "GB";
+    else if (val >= 10*mb)
+      s << rdiv( val, mb ) << "MB";
+    else if (val >= 10*kb)
+      s << rdiv( val, kb ) << "kB";
+    else if (val > 0)
+      s << val << " B";
+    else
+      s << "0  ";
+  else {
+    unsigned long den;
+    switch (UNITS) {
+      case BYTES: den = 1; break;
+      case KILOBYTES: den = kb; break;
+      case MEGABYTES: den = mb; break;
+      case GIGABYTES: den = gb; break;
+      case HUMAN: break; // handled above, list here to suppress warning
+    s << rdiv( val, den );
+  return s.str();
+  moab::DataType type;
+  rval = mb.tag_get_data_type( tag, type );
+    return std::string();
+  int typesize;
+  std::string typestr;
+  switch (type) {
+    case moab::MB_TYPE_INTEGER:
+      typestr = "int";
+      typesize = sizeof(int);
+      break;
+    case moab::MB_TYPE_DOUBLE:
+      typestr = "double";
+      typesize = sizeof(double);
+      break;
+    case moab::MB_TYPE_HANDLE:
+      typestr = "handle";
+      typesize = sizeof(moab::EntityHandle);
+      break;
+    case moab::MB_TYPE_BIT:
+      typesize = 1;
+      typestr = "bits";
+      break;
+    case moab::MB_TYPE_OPAQUE:
+      typesize = 1;
+      typestr = "bytes";
+      break;
+    default:
+      typesize = 1;
+      typestr = "???";
+      break;
+  int size;
+  rval = mb.tag_get_size( tag, size );
+  if (moab::MB_VARIABLE_DATA_LENGTH == rval)
+    s << "VAR " << typestr;
+  else if (moab::MB_SUCCESS == rval)
+    s << size/typesize << " " << typestr;
+  // else do nothing
+  return s.str();
+  moab::TagType type;
+  rval = mb.tag_get_type( tag, type );
+  switch (type) {
+    case moab::MB_TAG_DENSE: return "dense";
+    case moab::MB_TAG_SPARSE: return "sparse";
+    case moab::MB_TAG_BIT: return "bit";
+    default: return "(none)";
+  std::string text(str);
+  if (text.size() >= width)
+    return text;
+  width -= text.size();
+  if (1u == width) {
+    text += " ";
+    return text;
+  s << std::setw(width/2) << ' ' << text << std::setw(width/2 + width%2) << ' ';
+  return s.str();
