[MOAB-dev] r3696 - MOAB/trunk/test
Rajeev Jain
jain at mcs.anl.gov
Tue Mar 23 11:29:36 CDT 2010
kd_tree test passes now. 'make check' fails because I don't include CGM and dagmc uses CGM, so I use configure:
./configure --prefix=/home/rajeev/FATHOM/lib/MOAB/ --enable-debug --enable-shared--disable-dagmc
and all the 'make check' works fine.
Rajeev
From: "kraftche at cae.wisc.edu" <kraftche at cae.wisc.edu>
To: moab-dev at mcs.anl.gov
Sent: Tuesday, March 23, 2010 10:55:31
Subject: [MOAB-dev] r3696 - MOAB/trunk/test
Author: kraftche
Date: 2010-03-23 10:55:31 -0500 (Tue, 23 Mar 2010)
New Revision: 3696
Modified:
MOAB/trunk/test/kd_tree_test.cpp
Log:
clean up kd_tree_test
o use TestUtil.hpp to run tests and verify results
o split one large test function into individual tests
o don't test save/restore if no HDF5 support
Modified: MOAB/trunk/test/kd_tree_test.cpp
--- MOAB/trunk/test/kd_tree_test.cpp 2010-03-23 01:57:56 UTC (rev 3695)
+++ MOAB/trunk/test/kd_tree_test.cpp 2010-03-23 15:55:31 UTC (rev 3696)
@@ -1,156 +1,192 @@
#include "moab/Core.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/Range.hpp"
+#include "moab/CartVect.hpp"
#include <math.h>
#include <assert.h>
#include <float.h>
#include <cstdio>
-#include "moab/CartVect.hpp"
+#include "TestUtil.hpp"
-#include <stdlib.h>
-#ifdef NDEBUG
-# undef assert
-# define assert(A) do { if (!(A)) abort(); } while(false)
-#endif
using namespace moab;
const unsigned INTERVALS = 4;
const unsigned DEPTH = 7; // 3*log2(INTERVALS)+1
const char* TAG_NAME = "TEST_DATA";
-void test_iterator_back( AdaptiveKDTree& tool, EntityHandle root );
-void test_point_search( AdaptiveKDTree& tool, EntityHandle root );
+EntityHandle create_tree( AdaptiveKDTree& tool, unsigned depth, int intervals, Tag* tag_handle = 0 );
+void validate_tree( AdaptiveKDTree& tool, EntityHandle root, int depth, double intervals );
+void test_tree_create();
+void test_leaf_merge();
+void test_tree_readwrite();
+void test_tree_delete();
+void test_iterator_back();
+void test_point_search();
int main()
- // Initialize MOAB & create tree tool
- Core moab;
- AdaptiveKDTree tool(&moab);
+ int err = RUN_TEST(test_tree_create);
+ if (err) // can't run other tests if can't create tree
+ return 1;
+ err += RUN_TEST(test_leaf_merge);
+#ifdef HDF5_FILE
+ err += RUN_TEST(test_tree_readwrite);
+#endif
+ err += RUN_TEST(test_tree_delete);
+ err += RUN_TEST(test_iterator_back);
+ err += RUN_TEST(test_point_search);
+ return err;
+EntityHandle create_tree( AdaptiveKDTree& tool, unsigned depth, int intervals, Tag* tag_handle )
// Create tree root
ErrorCode err;
EntityHandle root, leaf;
const double tree_box_min_corner[] = { 0, 0, 0 };
// Make each leaf box be 1x1x1.
- const double tree_box_max_corner[] = { INTERVALS, INTERVALS, INTERVALS };
+ const double tree_box_max_corner[] = { intervals, intervals, intervals };
err = tool.create_tree( tree_box_min_corner, tree_box_max_corner, root );
assert(!err);
// Use iterator to create tree to fixed depth of DEPTH
AdaptiveKDTreeIter iter;
err = tool.get_tree_iterator( root, iter );
- assert(!err);
+ CHECK_ERR(err);
while(err == MB_SUCCESS) {
- if (iter.depth() < DEPTH) {
+ if (iter.depth() < depth) {
// bisect leaves along alternating axes
AdaptiveKDTree::Plane split;
split.norm = iter.depth() % 3; // alternate split axes;
split.coord = 0.5 * (iter.box_min()[split.norm] + iter.box_max()[split.norm]);
err = tool.split_leaf( iter, split ); // advances iter to first new leaf
- assert(!err);
+ CHECK_ERR(err);
// if current leaf is at desired depth, advance to next one
else {
err = iter.step();
- assert(MB_ENTITY_NOT_FOUND == err);
+ CHECK(MB_ENTITY_NOT_FOUND == err);
+ if (!tag_handle)
+ return root;
// define a tag to use to store integer values on tree leaves
- Tag data;
- err = moab.tag_create( TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, data, 0, false );
- assert(!err);
+ err = tool.moab()->tag_create( TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, *tag_handle, 0, false );
+ CHECK_ERR(err);
+ // iterate over tree setting data
+ int counter = 0;
+ for (err = tool.get_tree_iterator( root, iter ); !err; err = iter.step()) {
+ // store integer value on leaf
+ ++counter;
+ leaf = iter.handle();
+ err = tool.moab()->tag_set_data( *tag_handle, &leaf, 1, &counter );
+ CHECK_ERR(err);
- // iterate over tree, verifying leaves and setting data
+ return root;
+void validate_tree( AdaptiveKDTree& tool, EntityHandle root, unsigned depth, int intervals, Tag data )
+ ErrorCode err;
+ const double VOL = 1.0; // all leaves should be 1x1x1 boxes
+ int val;
+ // iterate over tree, verifying leaves
+ AdaptiveKDTreeIter iter;
int counter = 0;
++counter;
- leaf = iter.handle();
- err = moab.tag_set_data( data, &leaf, 1, &counter );
- assert(!err);
+ EntityHandle leaf = iter.handle();
+ CHECK(leaf != 0);
+ CHECK_EQUAL(MBENTITYSET, TYPE_FROM_HANDLE(leaf));
// check size of leaf
const double* min = iter.box_min();
const double* max = iter.box_max();
double dims[] = { max[0] - min[0], max[1] - min[1], max[2] - min[2] };
double volume = dims[0] * dims[1] * dims[2];
- assert( fabs(volume - 1.0) <= DBL_EPSILON );
+ CHECK_REAL_EQUAL( VOL, volume, DBL_EPSILON );
// check depth of leaf
- assert( iter.depth() == DEPTH );
+ CHECK_EQUAL( depth, iter.depth() );
+ // check tag value on leaf
+ err = tool.moab()->tag_get_data( data, &leaf, 1, &val );
+ CHECK_ERR(err);
+ CHECK_EQUAL(counter, val);
// check number of leaves
- const int num_leaves = INTERVALS*INTERVALS*INTERVALS;
- assert( num_leaves == counter );
+ const int num_leaves = intervals*intervals*intervals;
+ CHECK_EQUAL( num_leaves, counter );
+ Tag tag;
+ Core mb;
+ AdaptiveKDTree tool(&mb);
+ const EntityHandle root = create_tree( tool, DEPTH, INTERVALS, &tag );
+ validate_tree( tool, root, DEPTH, INTERVALS, tag );
+ ErrorCode err;
+ Core mb;
+ Tag data;
+ const EntityHandle root = create_tree( tool, DEPTH, INTERVALS, &data );
- test_iterator_back( tool, root );
- test_point_search( tool, root );
// reduce tree depth to DEPTH-1 by merging adjacent leaf pairs,
// make new "leaf" have smaller of two data values on original pair
// get data for first leaf
int data1;
- err = moab.tag_get_data( data, &leaf, 1, &data1 );
- assert(!err);
+ err = mb.tag_get_data( data, &leaf, 1, &data1 );
+ CHECK_ERR(err);
// tree traversal is always such that two leaves with same parent are consective
err = iter.step();
- assert(!err);
+ CHECK_ERR(err);
// get data for sibling
int data2;
- err = moab.tag_get_data( data, &leaf, 1, &data2 );
- assert(!err);
+ err = mb.tag_get_data( data, &leaf, 1, &data2 );
+ CHECK_ERR(err);
// as we stored increasing values, these had better be increasing
- assert( data2 - data1 == 1 );
+ CHECK_EQUAL( 1, data2 - data1 );
// merge leaf pair (iter can be at either one)
err = tool.merge_leaf( iter ); // changes iter to be new "merged" leaf
- assert(!err);
+ CHECK_ERR(err);
// store smaller of two values on new leaf
- err = moab.tag_set_data( data, &leaf, 1, &data1 );
- assert(!err);
+ err = mb.tag_set_data( data, &leaf, 1, &data1 );
+ CHECK_ERR(err);
- // write to file
- err = moab.write_file( "tree.h5m" );
- assert(!err);
- // clear everything
- moab.delete_mesh();
- // read tree from file
- err = moab.load_file( "tree.h5m" );
- assert(!err);
- // get tag handle by name, because the handle may have changed
- err = moab.tag_get_handle( TAG_NAME, data );
- assert(!err);
- // get root handle for tree
- Range range;
- err = tool.find_all_trees( range );
- assert(!err);
- assert(range.size() == 1);
- root = range.front(); // first (only) handle
// Iterate over tree, verifying leaves and checking data
// Initial leaves had volume of 1 : merged pairs of leaves so volume should now be 2.
// Initial leaves were enumerated in order : merged pairs so new leaves should
// have data incrementing in steps of 2.
- counter = 1;
+ int counter = 1;
int data1;
- assert(!err);
- assert( counter == data1 );
+ CHECK_ERR(err);
+ CHECK_EQUAL( counter, data1 );
counter += 2;
@@ -158,48 +194,73 @@
- assert( fabs(volume - 2.0) <= DBL_EPSILON );
+ CHECK_REAL_EQUAL( 2.0, volume, DBL_EPSILON );
- assert( iter.depth() == DEPTH-1 );
+ CHECK_EQUAL( DEPTH-1, iter.depth() );
- // check number of leaves
- // (num_leaves is original number of leaves, twice current number,
- // but counter is incremented by 2 for each iteration, so just
- // compare them.)
- assert( counter-1 == num_leaves );
- // Delete data from tree
- err = moab.tag_delete( data );
- assert( !err );
+ ErrorCode err;
+ Tag tag;
+ Core mb;
+ EntityHandle root = create_tree( tool, DEPTH, INTERVALS, &tag );
// write to file
- assert(!err);
+ err = mb.write_file( "tree.h5m" );
+ CHECK_ERR(err);
// clear everything
+ mb.delete_mesh();
+ err = mb.load_file( "tree.h5m" );
+ remove("tree.h5m");
+ CHECK_ERR(err);
+ // get tag handle by name, because the handle may have changed
+ err = mb.tag_get_handle( TAG_NAME, tag );
+ CHECK_ERR(err);
+ // get root handle for tree
+ Range range;
+ err = tool.find_all_trees( range );
assert(!err);
+ assert(range.size() == 1);
+ root = range.front(); // first (only) handle
- // check that tag doesn't exist
- assert( MB_TAG_NOT_FOUND == err );
- remove( "tree.h5m" );
- return 0;
+ ErrorCode err;
+ Core mb;
+ Tag data;
+ err = tool.delete_tree( root );
+ CHECK_ERR(err);
+ Range ents;
+ err = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &data, 0, 1, ents );
+ CHECK_ERR(err);
+ CHECK(ents.empty());
+void test_iterator_back( )
+ Core mb;
+ const EntityHandle root = create_tree( tool, DEPTH, INTERVALS );
ErrorCode rval = tool.get_tree_iterator( root, iter );
- assert( MB_SUCCESS == rval );
+ CHECK_ERR(rval);
CartVect min( iter.box_min() );
CartVect max( iter.box_max() );
@@ -207,14 +268,18 @@
// going back from first location should fail.
rval = iter.back();
- assert( MB_ENTITY_NOT_FOUND == rval );
+ CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval );
+ CHECK_ERR(rval);
// make sure iterator is valid
- assert( iter.box_min()[0] == min[0] && iter.box_min()[1] == min[1] && iter.box_min()[2] == min[2] );
- assert( iter.box_max()[0] == max[0] && iter.box_max()[1] == max[1] && iter.box_max()[2] == max[2] );
- assert( iter.handle() == leaf );
+ CHECK_REAL_EQUAL( min[0], iter.box_min()[0], DBL_EPSILON );
+ CHECK_REAL_EQUAL( min[1], iter.box_min()[1], DBL_EPSILON );
+ CHECK_REAL_EQUAL( min[2], iter.box_min()[2], DBL_EPSILON );
+ CHECK_REAL_EQUAL( max[0], iter.box_max()[0], DBL_EPSILON );
+ CHECK_REAL_EQUAL( max[1], iter.box_max()[1], DBL_EPSILON );
+ CHECK_REAL_EQUAL( max[2], iter.box_max()[2], DBL_EPSILON );
+ CHECK_EQUAL( leaf, iter.handle() );
while (MB_SUCCESS == iter.step()) {
// Get values at current iterator location
@@ -224,21 +289,29 @@
// step back to previous location
rval = iter.back();
+ CHECK_ERR(rval);
// check expected values for previous location
// advance iterator to 'current' location
rval = iter.step();
+ CHECK_ERR(rval);
// check that iterator values are correct
- assert( iter.box_min()[0] == next_min[0] && iter.box_min()[1] == next_min[1] && iter.box_min()[2] == next_min[2] );
- assert( iter.box_max()[0] == next_max[0] && iter.box_max()[1] == next_max[1] && iter.box_max()[2] == next_max[2] );
- assert( iter.handle() == next_leaf );
+ CHECK_REAL_EQUAL( next_min[0], iter.box_min()[0], DBL_EPSILON );
+ CHECK_REAL_EQUAL( next_min[1], iter.box_min()[1], DBL_EPSILON );
+ CHECK_REAL_EQUAL( next_min[2], iter.box_min()[2], DBL_EPSILON );
+ CHECK_REAL_EQUAL( next_max[0], iter.box_max()[0], DBL_EPSILON );
+ CHECK_REAL_EQUAL( next_max[1], iter.box_max()[1], DBL_EPSILON );
+ CHECK_REAL_EQUAL( next_max[2], iter.box_max()[2], DBL_EPSILON );
+ CHECK_EQUAL( next_leaf, iter.handle() );
// store values for next iteration
min = next_min;
@@ -247,8 +320,12 @@
+ Core mb;
ErrorCode rval;
EntityHandle leaf;
AdaptiveKDTreeIter iter, iter2;
@@ -259,56 +336,58 @@
// compare leaf search to iterator search
rval = tool.leaf_containing_point( root, left.array(), leaf );
+ CHECK_ERR(rval);
rval = tool.leaf_containing_point( root, left.array(), iter );
+ CHECK_ERR(rval);
// iterator should be at 'first' leaf
rval = tool.get_tree_iterator( root, iter2 );
+ CHECK_ERR(rval);
for (;;) {
- assert( iter.handle() == iter2.handle() );
- assert( iter.depth() == iter2.depth() );
- assert( iter.box_min()[0] == iter2.box_min()[0] );
- assert( iter.box_min()[1] == iter2.box_min()[1] );
- assert( iter.box_min()[2] == iter2.box_min()[2] );
- assert( iter.box_max()[0] == iter2.box_max()[0] );
- assert( iter.box_max()[1] == iter2.box_max()[1] );
- assert( iter.box_max()[2] == iter2.box_max()[2] );
+ CHECK_EQUAL( iter.handle(), iter2.handle() );
+ CHECK_EQUAL( iter.depth(), iter2.depth() );
+ CHECK_REAL_EQUAL( iter.box_min()[0], iter2.box_min()[0], DBL_EPSILON );
+ CHECK_REAL_EQUAL( iter.box_min()[1], iter2.box_min()[1], DBL_EPSILON );
+ CHECK_REAL_EQUAL( iter.box_min()[2], iter2.box_min()[2], DBL_EPSILON );
+ CHECK_REAL_EQUAL( iter.box_max()[0], iter2.box_max()[0], DBL_EPSILON );
+ CHECK_REAL_EQUAL( iter.box_max()[1], iter2.box_max()[1], DBL_EPSILON );
+ CHECK_REAL_EQUAL( iter.box_max()[2], iter2.box_max()[2], DBL_EPSILON );
rval = iter2.step();
- if (MB_SUCCESS != rval)
+ if (MB_ENTITY_NOT_FOUND == rval)
break;
+ CHECK_ERR(rval);
rval = iter.step();
+ CHECK_ERR(rval);
rval = tool.leaf_containing_point( root, right.array(), leaf );
+ CHECK_ERR(rval);
rval = tool.leaf_containing_point( root, right.array(), iter );
+ CHECK_ERR(rval);
// iterator should be at 'last' leaf
rval = tool.get_last_iterator( root, iter2 );
+ CHECK_ERR(rval);
for (;;) {
rval = iter2.back();
break;
+ CHECK_ERR(rval);
rval = iter.back();
+ CHECK_ERR(rval);
Get your preferred Email name!
Now you can @ymail.com and @rocketmail.com.
http://mail.promotions.yahoo.com/newdomains/aa/
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100323/99a3779b/attachment-0001.htm>
