[MOAB-dev] r3697 - MOAB/trunk/examples
kraftche at cae.wisc.edu
Tue Mar 23 11:03:16 CDT 2010
Author: kraftche
Date: 2010-03-23 11:03:15 -0500 (Tue, 23 Mar 2010)
New Revision: 3697
Modified:
MOAB/trunk/examples/KDTree.cpp
Log:
add comments to KDTree example
Modified: MOAB/trunk/examples/KDTree.cpp
--- MOAB/trunk/examples/KDTree.cpp 2010-03-23 15:55:31 UTC (rev 3696)
+++ MOAB/trunk/examples/KDTree.cpp 2010-03-23 16:03:15 UTC (rev 3697)
@@ -49,10 +49,12 @@
int main( )
+ // Ask user for file to read
std::string filename;
std::cout << "Hex mesh file name: ";
std::cin >> filename;
+ // Read file into MOAB instance
moab::ErrorCode rval;
moab::Core moab;
moab::Interface& mb = moab;
@@ -63,6 +65,7 @@
return 1;
+ // Get all hex elemeents
moab::Range elems;
rval = mb.get_entities_by_type( 0, moab::MBHEX, elems ); CHKERR(rval);
if (elems.empty()) {
@@ -70,10 +73,14 @@
return 1;
+ // Build a kD-tree from hex elements
moab::EntityHandle tree_root;
moab::AdaptiveKDTree tool( &mb );
rval = tool.build_tree( elems, tree_root ); CHKERR(rval);
+ // Loop forever (or until EOF), asking user for a point
+ // to query and printing the hex element containing that
+ // point.
for (;;) {
double point[3];
std::cout << "Point coordinates: ";
@@ -102,26 +109,38 @@
const moab::EntityHandle* conn; // hex connectivity
int conn_len;
+ // Get hexes in leaf
std::vector<moab::EntityHandle> hexes;
+ rval = mb.get_entities_by_type( set, moab::MBHEX, hexes ); CHKERR(rval);
+ // Check which hex the point is in
std::vector<moab::EntityHandle>::const_iterator i;
- rval = mb.get_entities_by_type( set, moab::MBHEX, hexes ); CHKERR(rval);
for (i = hexes.begin(); i != hexes.end(); ++i) {
rval = mb.get_connectivity( *i, conn, conn_len ); CHKERR(rval);
rval = mb.get_coords( conn, 8, &coords[0][0] ); CHKERR(rval);
if (moab::GeomUtil::point_in_trilinear_hex( coords, pt, EPSILON ))
return *i;
+ // Return 0 if no hex contains point.
return 0;
void print_hex( moab::Interface& mb, moab::EntityHandle hex )
+ // Get MOAB's internal ID for hex element
int id = mb.id_from_handle(hex);
- double coords[3*8]; // coordinates of corners of hexahedron
+ // Get vertex handles for hex corners
int conn_len;
mb.get_connectivity( hex, conn, conn_len );
+ // Get coordinates of vertices
+ double coords[3*8];
mb.get_coords( conn, 8, coords );
+ // Print
std::cout << " Point is in hex " << id << " with corners: " << std::endl;
for (int i = 0; i < 8; ++i) {
std::cout << " (" << coords[3*i]
