[MOAB-dev] r3651 - MOAB/trunk/src/moab
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Wed Mar 17 16:10:11 CDT 2010
Author: kraftche
Date: 2010-03-17 16:10:10 -0500 (Wed, 17 Mar 2010)
New Revision: 3651
Modified:
   MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp
Log:
make OrientedBox function public again because it breaks too much stuff (used in other places within moab, in tests, etc.)
Modified: MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp
--- MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp	2010-03-17 21:09:22 UTC (rev 3650)
+++ MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp	2010-03-17 21:10:10 UTC (rev 3651)
@@ -397,18 +397,18 @@
     Interface* get_moab_instance() const { return instance; }
     struct SetData;
-  private:
-    friend class RayIntersector;
-    friend class TreeNodePrinter;
-    friend class RayIntersectSets;
     /**\brief Get oriented box at node in tree
      * Get the oriented box for a node in an oriented bounding box tree.
+     * NOTE: This function is provided for internal MOAB use only.
+     *       The definition of OrientedBox is not available as a part
+     *       of the MOAB API
     ErrorCode box( EntityHandle node_set,
                      OrientedBox& box );
+  private:
     ErrorCode build_tree( const Range& entities,
                             EntityHandle& set,
