[MOAB-dev] r3600 - in MOAB/trunk/examples: . SkinMesh
    bmsmith6 at wisc.edu
    Fri Mar 12 12:12:30 CST 2010
Author: bmsmith
Date: 2010-03-12 12:12:29 -0600 (Fri, 12 Mar 2010)
New Revision: 3600
Added:
   MOAB/trunk/examples/SkinMesh/
   MOAB/trunk/examples/SkinMesh/Makefile
   MOAB/trunk/examples/SkinMesh/SkinMesh.cpp
Log:
A simple example of skinning triangles to recover edges.
Added: MOAB/trunk/examples/SkinMesh/Makefile
--- MOAB/trunk/examples/SkinMesh/Makefile	                        (rev 0)
+++ MOAB/trunk/examples/SkinMesh/Makefile	2010-03-12 18:12:29 UTC (rev 3600)
@@ -0,0 +1,8 @@
+include ${MOAB_LIB_DIR}/moab.make
+SkinMesh : SkinMesh.o
+	${CXX} $< ${MOAB_LIBS_LINK} -o $@
+.cpp.o :
+	${CXX} ${MOAB_INCLUDES} -c $<
Added: MOAB/trunk/examples/SkinMesh/SkinMesh.cpp
--- MOAB/trunk/examples/SkinMesh/SkinMesh.cpp	                        (rev 0)
+++ MOAB/trunk/examples/SkinMesh/SkinMesh.cpp	2010-03-12 18:12:29 UTC (rev 3600)
@@ -0,0 +1,169 @@
+#include <iostream>
+#include <stdlib.h>
+#include "MBCore.hpp"
+#include "MBRange.hpp"
+#include "MBTagConventions.hpp"
+// Hold edges in an array of vertex handles.
+struct edge {
+  MBEntityHandle v0;
+  MBEntityHandle v1;
+// edge structure comparision function for qsort
+// If the first vertex handle is the same, compare the second.
+int compare_edge(const void *a, const void *b) {
+  struct edge *ia = (struct edge *)a;
+  struct edge *ib = (struct edge *)b;
+  if(ia->v0 == ib->v0) {
+    return (int)(100.f*ia->v1 - 100.f*ib->v1);
+  } else {
+    return (int)(100.f*ia->v0 - 100.f*ib->v0);
+// This skinner is fast partly because it assumes that no edges exist in the MOAB
+// instance. Checking to see if an edge exists before creating a new one is slow.
+MBErrorCode skin_tris( MBInterface *mb, MBRange tris, MBRange &skin_edges ) {
+  // Empty the output range and make sure that the input range is only tris
+  skin_edges.clear();
+  if(tris.empty()) return MB_ENTITY_NOT_FOUND;
+  if(!tris.all_of_type(MBTRI)) return MB_FAILURE;
+  // Remove edges from the instance.
+  int n_edges;
+  MBErrorCode rval = mb->get_number_entities_by_type( 0, MBEDGE, n_edges );
+  if(MB_SUCCESS != rval) return rval;
+  if(0 != n_edges) {
+    std::cerr << "skin_tris: failed because " << n_edges
+              << " edges exist in the MOAB instance" << std::endl;
+    return MB_FAILURE;
+  // Get connectivity. Do not create MBEdges.
+  edge *edges = new edge[3*tris.size()];
+  int n_verts;
+  int ii = 0;
+  for(MBRange::iterator i=tris.begin(); i!=tris.end(); i++) {
+    const MBEntityHandle *conn;
+    rval = mb->get_connectivity( *i, conn, n_verts );
+    if(3 != n_verts) return MB_FAILURE;
+    // points should not be degenerate
+    if(conn[0]==conn[1] || conn[1]==conn[2] || conn[2]==conn[0]) {
+      std::cerr << "skin_tris: degenerate triangle" << std::endl;
+    // make edges
+    edges[3*ii+0].v0 = conn[0];
+    edges[3*ii+0].v1 = conn[1];
+    edges[3*ii+1].v0 = conn[1];
+    edges[3*ii+1].v1 = conn[2];
+    edges[3*ii+2].v0 = conn[2];
+    edges[3*ii+2].v1 = conn[0];
+    ii++;
+  // Ensure that the first vertex handle is the lowest
+  for(unsigned int i=0; i<3*tris.size(); ++i) {
+    if(edges[i].v0 > edges[i].v1) {
+      MBEntityHandle temp = edges[i].v0;
+      edges[i].v0 = edges[i].v1;
+      edges[i].v1 = temp;
+  // Sort by first handle, then second handle.
+  qsort(edges, 3*tris.size(), sizeof(struct edge), compare_edge);
+  // Go through array, saving edges that are not paired.
+  for(unsigned int i=0; i<3*tris.size(); i++) {
+    // If the last edge has not been paired, create it. This avoids overrunning
+    // the edges array with i+1.
+    if(3*tris.size()-1 == i) {
+      const MBEntityHandle conn[2] = {edges[i].v0, edges[i].v1};
+      MBEntityHandle edge;
+      rval = mb->create_element( MBEDGE, conn, 2, edge );
+      skin_edges.insert(edge);
+    // If a match exists, skip ahead
+    } else if(edges[i].v0==edges[i+1].v0 && edges[i].v1==edges[i+1].v1) {
+      i++;
+      // test to make sure surface is manifold
+      while( edges[i].v0==edges[i+1].v0 && edges[i].v1==edges[i+1].v1 ) {
+        std::cout << "find_skin WARNING: non-manifold edge" << std::endl;
+        mb->list_entity( edges[i].v0 );
+        mb->list_entity( edges[i].v1 );
+        ++i;
+    // otherwise a skin edge has been found
+    } else {
+      skin_edges.insert( edge );
+  delete[] edges;
+  return MB_SUCCESS;
+// Skin triangles to recover edges.
+// Triangles are contained in surface sets.
+int main(int argc, char **argv) {
+  if (1 == argc) {
+  std::cout << "Usage: " << argv[0] << " <filename>" << std::endl;
+    return 0;
+  // get MOAB instance and read the file
+  MBCore *mb = new MBCore();
+  MBErrorCode rval = mb->load_file(argv[1]);
+  if(MB_SUCCESS != rval) return 0;
+  // this optimized skinner requires removing all MBEdges from the MOAB instance
+  MBRange edges;
+  rval = mb->get_entities_by_type( 0, MBEDGE, edges );
+  if( !edges.empty() ) std::cout << "Warning: deleting all MBEdges" << std::endl;
+  rval = mb->delete_entities( edges );
+  // get surface sets
+  MBTag geom_tag;
+  rval = mb->tag_create( GEOM_DIMENSION_TAG_NAME, sizeof(int), MB_TAG_DENSE,
+                         MB_TYPE_INTEGER, geom_tag, 0, true );
+  MBRange surf_sets;
+  int two = 2;
+  void *dim[] = {&two};
+  rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag,
+                                           dim, 1, surf_sets );
+  // skin each surface
+  for(MBRange::iterator i=surf_sets.begin(); i!=surf_sets.end(); ++i) {
+    // get triangles in the surface set
+    MBRange tris;
+    rval = mb->get_entities_by_type( *i, MBTRI, tris );
+    // call the skinning function
+    MBRange skin_edges;
+    rval = skin_tris( mb, tris, skin_edges );
+    // do something with the result
+    std::cout << "surface has " << skin_edges.size() << " skin edges" << std::endl;
+    // remove the edges for the optimized skinner
+    rval = mb->delete_entities( skin_edges );
