[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Thu Mar 11 00:01:56 CST 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/93
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
WriteHDF5Parallel.cpp:1053: error: 'mhdf_message' was not declared in this scope
WriteHDF5Parallel.cpp:1054: error: 'mhdf_closeData' was not declared in this scope
WriteHDF5Parallel.cpp: In member function 'MBErrorCode WriteHDF5Parallel::get_remote_set_data(const WriteHDF5Parallel::MultiProcSetTags::Data&, RemoteSetData&, long int&)':
WriteHDF5Parallel.cpp:1164: warning: statement has no effect
WriteHDF5Parallel.cpp:1180: warning: statement has no effect
WriteHDF5Parallel.cpp:1240: warning: value computed is not used
WriteHDF5Parallel.cpp: In member function 'MBErrorCode WriteHDF5Parallel::set_shared_set_ids(RemoteSetData&, long int&)':
WriteHDF5Parallel.cpp:1379: warning: statement has no effect
WriteHDF5Parallel.cpp: In member function 'MBErrorCode WriteHDF5Parallel::negotiate_remote_set_contents(RemoteSetData&, long int*)':
WriteHDF5Parallel.cpp:1708: warning: value computed is not used
WriteHDF5Parallel.cpp: In member function 'virtual MBErrorCode WriteHDF5Parallel::write_shared_set_descriptions(hid_t)':
WriteHDF5Parallel.cpp:1887: error: 'mhdf_Status' was not declared in this scope
WriteHDF5Parallel.cpp:1887: error: expected `;' before 'status'
WriteHDF5Parallel.cpp:1911: error: 'status' was not declared in this scope
WriteHDF5Parallel.cpp:1911: error: 'mhdf_writeSetMeta' was not declared in this scope
WriteHDF5Parallel.cpp:1912: error: 'mhdf_isError' was not declared in this scope
WriteHDF5Parallel.cpp:1912: error: 'mhdf_message' was not declared in this scope
WriteHDF5Parallel.cpp: In member function 'virtual MBErrorCode WriteHDF5Parallel::write_shared_set_contents(hid_t)':
WriteHDF5Parallel.cpp:1926: error: 'mhdf_Status' was not declared in this scope
WriteHDF5Parallel.cpp:1926: error: expected `;' before 'status'
WriteHDF5Parallel.cpp:1949: error: 'status' was not declared in this scope
WriteHDF5Parallel.cpp:1949: error: 'mhdf_writeSetData' was not declared in this scope
WriteHDF5Parallel.cpp:1950: error: 'mhdf_isError' was not declared in this scope
WriteHDF5Parallel.cpp:1950: error: 'mhdf_message' was not declared in this scope
WriteHDF5Parallel.cpp: In member function 'virtual MBErrorCode WriteHDF5Parallel::write_shared_set_children(hid_t)':
WriteHDF5Parallel.cpp:1964: error: 'mhdf_Status' was not declared in this scope
WriteHDF5Parallel.cpp:1964: error: expected `;' before 'status'
WriteHDF5Parallel.cpp:1987: error: 'status' was not declared in this scope
WriteHDF5Parallel.cpp:1987: error: 'mhdf_writeSetParentsChildren' was not declared in this scope
WriteHDF5Parallel.cpp:1988: error: 'mhdf_isError' was not declared in this scope
WriteHDF5Parallel.cpp:1988: error: 'mhdf_message' was not declared in this scope
WriteHDF5Parallel.cpp: In member function 'virtual MBErrorCode WriteHDF5Parallel::write_shared_set_parents(hid_t)':
WriteHDF5Parallel.cpp:2002: error: 'mhdf_Status' was not declared in this scope
WriteHDF5Parallel.cpp:2002: error: expected `;' before 'status'
WriteHDF5Parallel.cpp:2025: error: 'status' was not declared in this scope
WriteHDF5Parallel.cpp:2025: error: 'mhdf_writeSetParentsChildren' was not declared in this scope
WriteHDF5Parallel.cpp:2026: error: 'mhdf_isError' was not declared in this scope
WriteHDF5Parallel.cpp:2026: error: 'mhdf_message' was not declared in this scope
WriteHDF5Parallel.cpp: In function 'void VALGRIND_MAKE_VEC_UNDEFINED(std::vector<T, std::allocator<_CharT> >&) [with T = long unsigned int]':
WriteHDF5Parallel.cpp:531:   instantiated from here
WriteHDF5Parallel.cpp:72: warning: value computed is not used
WriteHDF5Parallel.cpp: In function 'void VALGRIND_MAKE_VEC_UNDEFINED(std::vector<T, std::allocator<_CharT> >&) [with T = int]':
WriteHDF5Parallel.cpp:745:   instantiated from here
WriteHDF5Parallel.cpp: In function 'void VALGRIND_MAKE_VEC_UNDEFINED(std::vector<T, std::allocator<_CharT> >&) [with T = long int]':
WriteHDF5Parallel.cpp:876:   instantiated from here
sincerely,
 -The Fathomatic
