[MOAB-dev] r3586 - MOAB/trunk/itaps/imesh
kraftche at cae.wisc.edu
Wed Mar 10 18:41:34 CST 2010
Author: kraftche
Date: 2010-03-10 18:41:34 -0600 (Wed, 10 Mar 2010)
New Revision: 3586
Modified:
MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp
Log:
Previous "fix" was still wrong. I'm sure I've got it right this time...
Modified: MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp
--- MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp 2010-03-11 00:30:43 UTC (rev 3585)
+++ MOAB/trunk/itaps/imesh/iMesh_MOAB.hpp 2010-03-11 00:41:34 UTC (rev 3586)
@@ -66,27 +66,27 @@
#define MBimesh reinterpret_cast<MBiMesh*>(MBI)
-static inline void
+static inline int
iMesh_processError( int code, const char* desc )
std::strncpy( iMesh_LAST_ERROR.description, desc,
sizeof(iMesh_LAST_ERROR.description) );
iMesh_LAST_ERROR.description[sizeof(iMesh_LAST_ERROR.description)-1] = '\0';
- iMesh_LAST_ERROR.error_type = (iBase_ErrorType)code;
+ return (iMesh_LAST_ERROR.error_type = (iBase_ErrorType)code);
-#define ERROR(CODE,MSG) do { iMesh_setLastError( MBI, *err = (CODE), (MSG) ); return; } while(false)
-#define IBASE_ERROR(CODE,MSG) do { iMesh_processError( *err = (CODE), (MSG) ); return; } while(false)
+#define ERROR(CODE,MSG) do { *err = iMesh_setLastError( MBI, (CODE), (MSG) ); return; } while(false)
+#define IBASE_ERROR(CODE,MSG) do { *err = iMesh_processError( (CODE), (MSG) ); return; } while(false)
-static inline void iMesh_setLastError( MBInterface*, int code, const char* msg )
- { iMesh_processError( code, msg ); }
-static inline void iMesh_setLastError( MBInterface* mbi, MBErrorCode code, const char* msg )
+static inline int iMesh_setLastError( MBInterface*, int code, const char* msg )
+ { return iMesh_processError( code, msg ); }
+static inline int iMesh_setLastError( MBInterface* mbi, MBErrorCode code, const char* msg )
std::string message(msg);
message += " (MOAB Error Code: ";
message += mbi->get_error_string(code);
message += ")";
- iMesh_processError( iBase_ERROR_MAP[code], message.c_str() );
+ return iMesh_processError( iBase_ERROR_MAP[code], message.c_str() );
#define CHKERR(CODE,MSG) \
