[MOAB-dev] Redundant -L/usr/lib causing problems
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Mar 1 16:31:19 CST 2010
Jed Brown wrote:
> On Mon, 01 Mar 2010 15:58:44 -0600, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
>> I haven't seen this error before. My first guess is that something on your
>> system changed with respect to the C++ compiler and you need to re-build MOAB.
> I did "make clean" and rebuilt.
>>> Perhaps this is due to the use of -nostdlib?
>> We don't use that. I grepped every file in the MOAB source and build
>> results. The only files that contain 'nostdlib' are generated by autotools
>> (aclocal.m4 and therefore configure).
> Well, it's creeping in
Libtool is also specifying the correct -L and -l arguments to link the same
libstdc++, so I'll assume for now that its use of -nostdlib is not the
problem. Basically, you have a compiler installed that uses a libstdc++
that is not in the default library search path. This seems like a broken
system configuration to me. However, you said that this configuration
worked when building other software with the C++ compiler. So what's
different? Are these other things you're building with this compiler also
shared libraries? What is the result of running ldd on them?
- jason
