[MOAB-dev] Redundant -L/usr/lib causing problems
Jed Brown
jed at 59A2.org
Mon Mar 1 15:47:51 CST 2010
On Mon, 01 Mar 2010 15:22:59 -0600, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> After looking at this further, I think that this is not a bug. The
> --with-zoltan and --with-parmetis flags are available solely for the purpose
> of specifying alternate locations in which to look for those libraries. If
> they are in the default search path then it should be sufficient to specify
> *only* '--enable-mbzoltan'.
This works[1], but it is very confusing for the user to determine which
options must be specified, which are optional, which need an argument,
and which must be specified without an argument. My usual procedure
with a new library is to run configure --help, then specify
--with-xxx=/path/to/xxx for each optional package that I have available.
The current MOAB situation is far more delicate.
Jed
[1] Actually, all the tests fail due to symbol versioning errors.
/home/jed/build/moab/bompi/parallel/.libs/lt-pcomm_unit: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /home/jed/build/moab/bompi/.libs/libMOAB.so.0)
I can fix this by setting
LD_LIBRARY_PATH=/usr/lib/gcc/x86_64-unknown-linux-gnu/4.5.0
but no other C++ projects require this hackery. Perhaps this is due to
the use of -nostdlib?
Jed
