[MOAB-dev] r3558 - in MOAB/trunk: . tools/dagmc
sjackson at cae.wisc.edu sjackson at cae.wisc.edu
Fri Feb 26 14:57:00 CST 2010
Author: sjackson
Date: 2010-02-26 14:57:00 -0600 (Fri, 26 Feb 2010)
New Revision: 3558
Modified:
   MOAB/trunk/MBOrientedBoxTreeTool.cpp
   MOAB/trunk/MBOrientedBoxTreeTool.hpp
   MOAB/trunk/tools/dagmc/ray_fire_test.cc
Log:
Add to OBB tree traversal statistics a count of the number of
tree leaves that were visited during traversals. Output this
information from the ray_fire_test benchmark in dagmc.
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp	2010-02-25 22:24:08 UTC (rev 3557)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp	2010-02-26 20:57:00 UTC (rev 3558)
@@ -504,6 +504,7 @@
     if (MB_SUCCESS != rval)
       return rval;
     if (children.empty()) {
+      if( accum ){ accum->increment_leaf( data.depth ); }
       rval = operation.leaf( data.set );
         return rval;
@@ -607,6 +608,7 @@
       continue;
+    if(accum){ accum->increment_leaf( current_depth ); }
       // if leaf, intersect sphere with triangles
 #ifndef MB_OBB_USE_VECTOR_QUERIES
 # ifdef MB_OBB_USE_TYPE_QUERIES
@@ -1133,6 +1135,8 @@
     else { // LEAF NODE
+      if( accum ){ accum->increment_leaf( current_depth ); }
       MBRange facets;
       rval = instance->get_entities_by_dimension( node, 2, facets );
@@ -1267,6 +1271,8 @@
     else { // LEAF NODE
       MBRange facets;
@@ -1596,6 +1602,7 @@
 void MBOrientedBoxTreeTool::TrvStats::reset(){
   nodes_visited_count.clear();
+  leaves_visited_count.clear();
   traversals_ended_count.clear();
@@ -1603,11 +1610,17 @@
   while( nodes_visited_count.size() <= depth ){
     nodes_visited_count.push_back(0);
+    leaves_visited_count.push_back(0);
     traversals_ended_count.push_back(0);
   nodes_visited_count[depth] += 1;
+void MBOrientedBoxTreeTool::TrvStats::increment_leaf( unsigned depth ){
+  //assume safe depth, because increment is called first
+  leaves_visited_count[depth] += 1;
 void MBOrientedBoxTreeTool::TrvStats::end_traversal( unsigned depth ){
   // assume safe depth, because increment is always called on a given
   // tree level first
@@ -1618,25 +1631,29 @@
   const std::string h1 = "OBBTree Depth";
   const std::string h2 = " - NodesVisited";
-  const std::string h3 = " - TraversalsEnded";
+  const std::string h3 = " - LeavesVisited";
+  const std::string h4 = " - TraversalsEnded";
-  str << h1 << h2 << h3 << std::endl;
+  str << h1 << h2 << h3 << h4 << std::endl;
-  unsigned num_visited = 0, num_traversals = 0;
+  unsigned num_visited = 0, num_leaves = 0, num_traversals = 0;
   for( unsigned i = 0; i < traversals_ended_count.size(); ++i){
     num_visited    += nodes_visited_count[i];
+    num_leaves     += leaves_visited_count[i];
     num_traversals += traversals_ended_count[i];
     str << std::setw(h1.length()) << i
         << std::setw(h2.length()) << nodes_visited_count[i]
-        << std::setw(h3.length()) << traversals_ended_count[i]
+        << std::setw(h3.length()) << leaves_visited_count[i]
+        << std::setw(h4.length()) << traversals_ended_count[i]
         << std::endl;
   str << std::setw(h1.length()) << "---- Totals:"
       << std::setw(h2.length()) << num_visited
-      << std::setw(h3.length()) << num_traversals
+      << std::setw(h3.length()) << num_leaves
+      << std::setw(h4.length()) << num_traversals
       << std::endl;
Modified: MOAB/trunk/MBOrientedBoxTreeTool.hpp
--- MOAB/trunk/MBOrientedBoxTreeTool.hpp	2010-02-25 22:24:08 UTC (rev 3557)
+++ MOAB/trunk/MBOrientedBoxTreeTool.hpp	2010-02-26 20:57:00 UTC (rev 3558)
@@ -136,9 +136,13 @@
     class TrvStats{
       public:
-        //! return counts of nodes visited, indexed by tree depth
+        //! return counts of nodes visited, indexed by tree depth.
+        //! the counts include both leaves and interior nodes
         const std::vector< unsigned >& nodes_visited() const
         { return nodes_visited_count; }
+        //! return counts of tree leaves visited, indexed by tree depth
+        const std::vector< unsigned >& leaves_visited() const
+        { return leaves_visited_count; }
         //! return counts of traversals ended, indexed by tree depth
         const std::vector< unsigned >& traversals_ended() const
         { return traversals_ended_count; }
@@ -150,9 +154,11 @@
       private:
         std::vector< unsigned > nodes_visited_count;
+        std::vector< unsigned > leaves_visited_count;
         std::vector< unsigned > traversals_ended_count;
         void increment( unsigned depth );
+        void increment_leaf( unsigned depth );
         void end_traversal( unsigned depth );
       friend class MBOrientedBoxTreeTool;
Modified: MOAB/trunk/tools/dagmc/ray_fire_test.cc
--- MOAB/trunk/tools/dagmc/ray_fire_test.cc	2010-02-25 22:24:08 UTC (rev 3557)
+++ MOAB/trunk/tools/dagmc/ray_fire_test.cc	2010-02-26 20:57:00 UTC (rev 3558)
@@ -561,7 +561,13 @@
       out << trv_stats->nodes_visited()[i] << ",";
     out << "]," << std::endl;
+    out << "'leaves_visited':[";
+    for( unsigned i = 0; i < stat_depth; ++i){
+      out << trv_stats->leaves_visited()[i] << ",";
+    out << "]," << std::endl;
     out << "'traversals_ended':[";
       out << trv_stats->traversals_ended()[i] << ",";
