[MOAB-dev] iMeshP and parallel imesh
Jason Kraftcheck kraftche at cae.wisc.edu
Tue Feb 2 10:09:37 CST 2010
acaceres at mcs.anl.gov wrote:
> Hi,
> I'm using iMesh in parallel and trying to see if I can use iMeshP to get
> information like whether a local vertex is a ghost or not. I haven't quite
> figured out the interface, but it seems like a lot of the iMeshP calls want
> an iMeshP_PartitionHandle, so my first attempt was just:
> call iMesh_newMesh("PARALLEL",iMesh, err)
> call iMesh_load(%val(iMesh), %val(IMESH_NULL), input_filename,
> ";PARALLEL=READ_DELETE;PARTITION=PARALLEL_PARTITION;PARTITION_DISTRIBUTE;",
> err)
> call iMeshP_getNumPartitions(%val(iMesh), numPartitions, err)
> (the file I'm reading has a partition defined on it using the
> "PARALLEL_PARTITION" tag, pre-computed with zoltan). This is with 2
> processors. I'm getting numPartitions==0. I'm probably completely
> misunderstanding how iMeshP is supposed to be used, so can somebody clarify
> the following:
> - am I getting the correct behavior? - when I load a mesh using the first
> two calls above, how do I find out if
an entity is a ghost or not?
Note that MOAB's iMeshP implementation is rather incomplete and may not work
correctly.
You need to do the load through the iMeshP API:
call iMesh_newMesh("",iMesh,err)
call iMeshP_createPartitionAll(%val(iMesh),%val(MPI_COMM_WORLD),partn,err)
call iMeshP_loadAll(%val(iMesh),%val(partn),%val(root),input_filename,
                   ";PARALLEL=READ_DELETE",err)
- jason
