[MOAB-dev] r3521 - in MOAB/trunk: . test/obb
    sjackson at cae.wisc.edu
    Mon Feb  1 17:03:45 CST 2010
Author: sjackson
Date: 2010-02-01 17:03:45 -0600 (Mon, 01 Feb 2010)
New Revision: 3521
Modified:
   MOAB/trunk/MBOrientedBoxTreeTool.cpp
   MOAB/trunk/MBOrientedBoxTreeTool.hpp
   MOAB/trunk/test/obb/obb_test.cpp
Log:
Fix typos encountered while working on OBB tree code.
Modified: MOAB/trunk/MBOrientedBoxTreeTool.cpp
--- MOAB/trunk/MBOrientedBoxTreeTool.cpp	2010-02-01 23:01:21 UTC (rev 3520)
+++ MOAB/trunk/MBOrientedBoxTreeTool.cpp	2010-02-01 23:03:45 UTC (rev 3521)
@@ -181,7 +181,7 @@
-/**\brief Split trianges by which side of a plane they are on
+/**\brief Split triangles by which side of a plane they are on
  * Given a plane specified as a bisecting plane normal to one
  * of the axes of a box, split triangles based on which side
@@ -514,7 +514,7 @@
   return MB_SUCCESS;
-/********************** General Sphere/Triangel Intersection ***************/
+/********************** General Sphere/Triangle Intersection ***************/
 MBErrorCode MBOrientedBoxTreeTool::sphere_intersect_triangles(
                                         const double* center_v,
@@ -625,7 +625,7 @@
-/********************** General Ray/Tree and Ray/Triangel Intersection ***************/
+/********************** General Ray/Tree and Ray/Triangle Intersection ***************/
 class RayIntersector : public MBOrientedBoxTreeTool::Op
@@ -810,8 +810,8 @@
                    double tolerance,
                    unsigned min_tol_intersections,
                    std::vector<double>& intersections,
-		   std::vector<MBEntityHandle>& surfaces,
-		   std::vector<MBEntityHandle>& facets )
+                   std::vector<MBEntityHandle>& surfaces,
+                   std::vector<MBEntityHandle>& facets )
       : tool(tool_ptr), minTolInt(min_tol_intersections),
         b(ray_point), m(unit_ray_dir),
         len(ray_length), tol(tolerance),
@@ -968,7 +968,7 @@
     intersections.push_back( t );
     sets.push_back( lastSet );
     facets.push_back(facet);
-      // udpate length.  this is currently the closest intersection, so
+      // update length.  this is currently the closest intersection, so
       // only want further intersections that are closer than this one.
     len = &intersections.back();
Modified: MOAB/trunk/MBOrientedBoxTreeTool.hpp
--- MOAB/trunk/MBOrientedBoxTreeTool.hpp	2010-02-01 23:01:21 UTC (rev 3520)
+++ MOAB/trunk/MBOrientedBoxTreeTool.hpp	2010-02-01 23:03:45 UTC (rev 3521)
@@ -38,8 +38,8 @@
      * Available settings for controlling when and how nodes in the tree
      * are split.  The constructor will initialize to the default
      * settings.  All settings except best_split_ratio control when
-     * a node is subdivied.  best_split_ratio influences the choice
-     * of how the node is subdivied.
+     * a node is subdivided.  best_split_ratio influences the choice
+     * of how the node is subdivided.
      * A calculated ratio is used in the determination of when and how
      * to split a node.  The ratio is calculated as:
@@ -55,8 +55,8 @@
      *  - Node must contain more than max_leaf_entities entities.
      *  - The 'ratio' must be less than worst_split_ratio
-     * The node will be subdivied using a plane normal to one of the
-     * box axis and containg the box center.  The planes are tested
+     * The node will be subdivided using a plane normal to one of the
+     * box axis and containing the box center.  The planes are tested
      * beginning with the one orthogonal to the longest box axis and
      * finishing with the one orthogonal to the shortest box axis.  The
      * search will stop at the first plane for which the 'ratio' is
@@ -105,13 +105,13 @@
     /**\brief Build a tree of sets, where each set contains triangles.
      * Build a tree of sets.  Each set must contain at least one triangle
-     * to define it's geometry.  Each passed set will become a leaf of
+     * to define its geometry.  Each passed set will become a leaf of
      * the OBB tree.  Settings controlling tree depth are ignored by
      * this method.  The tree will be as deep as it needs to be for each
      * input set to be a leaf.
      * To build a tree representing the surfaces of a geometric volume,
-     * 1) Build and OBB tree for each surface using the 'build' method
+     * 1) Build an OBB tree for each surface using the 'build' method
      * 2) Add each surface to the contents of the resulting OBB tree root set
      * 3) Build a tree from all the surface OBB tree root sets using this
      *    method to get a combined tree for the volume.
@@ -333,7 +333,7 @@
                        // virtual function but no virtual destructor.
-    /**\brief Visistor pattern - do operation for each tree node
+    /**\brief Visitor pattern - do operation for each tree node
      * Do a preorder traversal of the tree, calling the method
      * in the passed operation instance for each node in the tree.
Modified: MOAB/trunk/test/obb/obb_test.cpp
--- MOAB/trunk/test/obb/obb_test.cpp	2010-02-01 23:01:21 UTC (rev 3520)
+++ MOAB/trunk/test/obb/obb_test.cpp	2010-02-01 23:03:45 UTC (rev 3521)
@@ -43,7 +43,7 @@
     str << " If no file is specified the defautl test files will be used" << std::endl
         << " -h  print help text. " << std::endl
         << " -v  verbose output (may be specified multiple times) " << std::endl
-        << " -q  quite (minimal output) " << std::endl
+        << " -q  quiet (minimal output) " << std::endl
         << " -f <x>:<y>:<z>:<i>:<j>:<k> Do ray fire" << std::endl
         << " -c  write box geometry to Cubit journal file." << std::endl
         << " -k  write leaf contents to vtk files." << std::endl
@@ -57,7 +57,7 @@
         << " -s force construction of surface tree" << std::endl
         << " -S do not build surface tree." << std::endl
         << "    (Default: surface tree if file contains multiple surfaces" << std::endl
-        << " -u  use unorderd (MBRange) meshsets for tree nodes" << std::endl
+        << " -u  use unordered (MBRange) meshsets for tree nodes" << std::endl
         << " -U  use ordered (vector) meshsets for tree nodes" << std::endl
         << " Verbosity (-q sets to 0, each -v increments, default is 1):" << std::endl
         << "  0 - no output" << std::endl
@@ -66,7 +66,7 @@
         << "  3 - output errors for each node" << std::endl
         << "  4 - print tree" << std::endl
         << "  5 - print tree w/ contents of each node" << std::endl
-        << " See documentation for MMOrientedBoxTreeTool::Settings for " << std::endl
+        << " See documentation for MBOrientedBoxTreeTool::Settings for " << std::endl
         << " a description of tree generation settings." << std::endl
   exit( !!error );
@@ -1292,7 +1292,7 @@
       continue;
-      // find closest point usnig tree
+      // find closest point using tree
     rval = tool.closest_to_location( points[i].array(),
                                      root_set,
                                      t_result.array(),
