[MOAB-dev] r3516 - MOAB/trunk
tautges at mcs.anl.gov tautges at mcs.anl.gov
Sun Jan 31 11:55:42 CST 2010
Author: tautges
Date: 2010-01-31 11:55:42 -0600 (Sun, 31 Jan 2010)
New Revision: 3516
Modified:
   MOAB/trunk/ReadCCMIO.cpp
   MOAB/trunk/ReadCCMIO.hpp
Log:
Adding ability to read and tag material sets.
Modified: MOAB/trunk/ReadCCMIO.cpp
--- MOAB/trunk/ReadCCMIO.cpp	2010-01-31 14:57:45 UTC (rev 3515)
+++ MOAB/trunk/ReadCCMIO.cpp	2010-01-31 17:55:42 UTC (rev 3516)
@@ -33,7 +33,19 @@
  *             FieldData
  *     Processor ...
+ * MaterialType (CCMIOReadOptstr in readexample)
+ * constants (see readexample)
+ * lagrangian data (CCMIOReadLagrangianData)
+ * vertices label (CCMIOEntityDescription)
+ * restart info: char solver[], iteratoins, time, char timeUnits[], angle
+ *      (CCMIOReadRestartInfo, kCCMIORestartData), reference data?
+ * phase:
+ *   field: char name[], dims, CCMIODataType datatype, char units[]
+ *       dims = kCCMIOScalar (CCMIOReadFieldDataf),
+ *              kCCMIOVector (CCMIOReadMultiDimensionalFieldData),
+ *              kCCMIOTensor
+ * MonitoringSets: num, name (CellSet, VertexSet, BoundarySet, BlockSet, SplineSet, CoupleSet)
+ *      CCMIOGetProstarSet, CCMIOReadOpt1i,
 enum DataType { kScalar, kVector, kVertex, kCell, kInternalFace, kBoundaryFace,
@@ -45,6 +57,13 @@
 static int const kVertOffset = 2;
 static int const kCellInc = 4;
+#define CHKERR(a, b)                                 \
+    {if (MB_SUCCESS != a) {if (b) readMeshIface->report_error(b); return a;}}
+#define CHKCCMERR(a, b)                                 \
+    {if (kCCMIONoErr != a) {if (b) readMeshIface->report_error(b); return MB_FAILURE;}}
 MBReaderIface* ReadCCMIO::factory( MBInterface* iface )
 { return new ReadCCMIO( iface ); }
@@ -125,32 +144,165 @@
   CCMIOError error = kCCMIONoErr;
   CCMIOOpenFile(&error, file_name, kCCMIORead, &rootID);
-  if (kCCMIONoErr != error) {
-    readMeshIface->report_error("Problem opening file.");
-    return MB_FAILURE;
+  CHKCCMERR(error, "Problem opening file.");
     // get the file state
   MBErrorCode rval = get_state(rootID, problemID, stateID);
-  if (MB_SUCCESS != rval) return MB_FAILURE;
+  CHKERR(rval,NULL);
     // get processors
   std::set<CCMIOSize_t> procs;
   rval = get_processors(stateID, processorID, procs);
   std::set<CCMIOSize_t>::iterator sit;
+  MBRange new_ents, *new_ents_ptr = NULL;
+  if (file_set) new_ents_ptr = &new_ents;
   for (sit = procs.begin(); sit != procs.end(); sit++) {
-    rval = read_processor(stateID, processorID, *sit);
+    rval = read_processor(stateID, problemID, processorID, *sit, new_ents_ptr);
+    // load some meta-data
+  rval = load_metadata(rootID, problemID, file_set);
+    // now, put all this into the file set, if there is one
+  if (file_set) {
+    rval = mbImpl->add_entities(*file_set, new_ents);
+    CHKERR(rval, "Failed to add new entities to file set.");
   return rval;
-MBErrorCode ReadCCMIO::read_processor(CCMIOID stateID, CCMIOID processorID, CCMIOSize_t proc)
+MBErrorCode ReadCCMIO::load_metadata(CCMIOID rootID, CCMIOID problemID,
+                                     const MBEntityHandle *file_set)
+    // Read the simulation title.
+  MBErrorCode rval = MB_SUCCESS;
+  CCMIONode rootNode;
+  if (kCCMIONoErr == CCMIOGetEntityNode(&error, rootID, &rootNode)) {
+    char *name = NULL;
+    CCMIOGetTitle(&error, rootNode, &name);
+    if (NULL != name && strlen(name) != 0) {
+        // make a tag for it and tag the read set
+      MBTag simname;
+      rval = mbImpl->tag_get_handle("SimulationName", simname);
+      if (MB_TAG_NOT_FOUND == rval) {
+        rval = mbImpl->tag_create("SimulationName", strlen(name), MB_TAG_SPARSE,
+                                  MB_TYPE_OPAQUE, simname, NULL);
+        CHKERR(rval, "Simulation name tag not found or created.");
+      MBEntityHandle tag_set = (NULL != file_set ? *file_set : 0);
+      rval = mbImpl->tag_set_data(simname, &tag_set, 1, name);
+      CHKERR(rval, "Problem setting simulation name tag.");
+    if (name) free(name);
+  rval = load_matset_data(problemID);
+  CHKERR(rval, NULL);
+  return rval;
+MBErrorCode ReadCCMIO::load_matset_data(CCMIOID problemID)
+    // make sure there are matsets
+  if (newMatsets.empty()) return MB_SUCCESS;
+    // ... walk through each cell type
+  CCMIOSize_t i = CCMIOSIZEC(0);
+  CCMIOID next;
+  std::vector<char> mtype_name;
+  CCMIOError error = kCCMIONoErr;
+  MBTag matNameTag = 0, matPorosityTag = 0, matSpinTag = 0, matGroupTag = 0;
+  MBErrorCode rval = create_matset_tags(matNameTag, matPorosityTag,
+                                        matSpinTag, matGroupTag);
+  while (CCMIONextEntity(NULL, problemID, kCCMIOCellType, &i, &next)
+         == kCCMIONoErr) {
+    int csize, mindex, idum;
+    CCMIOGetEntityIndex(&error, next, &mindex);
+    assert(mindex > 0 && mindex <= (int)newMatsets.size()+1);
+    mindex--;
+      // do Id first, since it should be set to something to identify set as a matset
+    if (kCCMIONoErr != CCMIOReadOpti(NULL, next, "MaterialId", &idum))
+      idum = mindex + 1;
+    MBEntityHandle dum_ent = newMatsets[mindex];
+    rval = mbImpl->tag_set_data(mMaterialSetTag, &dum_ent, 1, &idum);
+    CHKERR(rval, "Failed to set material set id tag.");
+      // MaterialType
+    if (kCCMIONoErr == CCMIOReadOptstr(NULL, next, "MaterialType", &csize, NULL)) {
+      mtype_name.resize(csize+1, '\0');
+      CCMIOReadOptstr(&error, next, "MaterialType", &csize, &mtype_name[0]);
+      rval = mbImpl->tag_set_data(matNameTag, &dum_ent, 1, &mtype_name[0]);
+      CHKERR(rval, "Failed to set matNameTag.");
+      // porosity
+    if (kCCMIONoErr == CCMIOReadOpti(NULL, next, "PorosityId", &idum)) {
+      rval = mbImpl->tag_set_data(matPorosityTag, &dum_ent, 1, &idum);
+      CHKERR(rval, "Failed to set matPorosityTag.");
+      // Spin
+    if (kCCMIONoErr == CCMIOReadOpti(NULL, next, "SpinId", &idum)) {
+      rval = mbImpl->tag_set_data(matSpinTag, &dum_ent, 1, &idum);
+      CHKERR(rval, "Failed to set matSpinTag.");
+      // group
+    if (kCCMIONoErr == CCMIOReadOpti(NULL, next, "GroupId", &idum)) {
+      rval = mbImpl->tag_set_data(matGroupTag, &dum_ent, 1, &idum);
+      CHKERR(rval, "Failed to set matGroupTag.");
+  return MB_SUCCESS;
+MBErrorCode ReadCCMIO::create_matset_tags(MBTag &matNameTag, MBTag &matPorosityTag,
+                                          MBTag &matSpinTag, MBTag &matGroupTag)
+  MBErrorCode rval = mbImpl->tag_create("MaterialName", NAME_TAG_SIZE, MB_TAG_SPARSE, MB_TYPE_OPAQUE,
+                                        matNameTag, NULL, true);
+  CHKERR(rval, "Failed to create matNameTag.");
+  rval = mbImpl->tag_create("MaterialPorosity", sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER,
+                            matPorosityTag, NULL, true);
+  CHKERR(rval, "Failed to create matPorosityTag.");
+  rval = mbImpl->tag_create("MaterialSpin", sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER,
+                            matSpinTag, NULL, true);
+  CHKERR(rval, "Failed to create matSpinTag.");
+  rval = mbImpl->tag_create("MaterialGroup", sizeof(int), MB_TAG_SPARSE, MB_TYPE_INTEGER,
+                            matGroupTag, NULL, true);
+  CHKERR(rval, "Failed to create matGroupTag.");
+MBErrorCode ReadCCMIO::read_processor(CCMIOID stateID, CCMIOID problemID,
+                                      CCMIOID processorID, CCMIOSize_t proc,
+                                      MBRange *new_ents)
   MBErrorCode rval;
   bool has_solution = true;
   CCMIOID verticesID, topologyID, solutionID;
@@ -165,91 +317,157 @@
     CCMIOReadProcessor(&error, processorID, &verticesID, &topologyID, NULL, NULL);
     if(kCCMIONoErr == error)
         hasSolution = false;
-    else {
-      readMeshIface->report_error("Couldn't get vertices and topology.");
+    else CHKERR(MB_FAILURE, "Couldn't get vertices and topology.");
-  MBRange verts;
     // vert_map fields: s: none, i: gid, ul: vert handle, r: none
     //TupleList vert_map(0, 1, 1, 0, 0);
   TupleList vert_map;
   rval = read_vertices(proc, processorID, verticesID, topologyID,
-                       solutionID, has_solution, verts, vert_map);
-  if (MB_SUCCESS != rval) return rval;
+                       solutionID, has_solution, new_ents, vert_map);
-  rval = read_cells(proc, processorID, verticesID, topologyID,
-                    solutionID, has_solution, vert_map);
+  rval = read_cells(proc, problemID, verticesID, topologyID,
+                    solutionID, has_solution, vert_map, new_ents);
   return rval;
-MBErrorCode ReadCCMIO::read_cells(CCMIOSize_t proc, CCMIOID processorID,
+MBErrorCode ReadCCMIO::read_cells(CCMIOSize_t proc, CCMIOID problemID,
                                   CCMIOID verticesID, CCMIOID topologyID,
                                   CCMIOID solutionID, bool has_solution,
-                                  TupleList &vert_map)
+                                  TupleList &vert_map, MBRange *new_ents)
-  CCMIOID cellsID, mapID;
-  CCMIOError error = kCCMIONoErr;
-    // get the cells entity and number of cells
-  CCMIOSize_t num_cells;
-  CCMIOGetEntity(&error, topologyID, kCCMIOCells, 0, &cellsID);
-  CCMIOEntitySize(&error, cellsID, &num_cells, NULL);
-    // read the cell types and gid map
-  std::vector<int> cell_gids(GETINT32(num_cells)), cell_types(GETINT32(num_cells));
-  CCMIOReadCells(&error, cellsID, &mapID, NULL,
-                 CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
-    // this reads the cellids from the map.
-  CCMIOReadMap(&error, mapID, &cell_gids[0],
-    readMeshIface->report_error("Couldn't read cells or cell id map.");
     // read the faces.
     // face_map fields: s:forward/reverse, i: cell id, ul: face handle, r: none
+  MBErrorCode rval;
 #ifdef TUPLE_LIST
   TupleList face_map(1, 1, 1, 0, 0);
 #else
   TupleList face_map;
   SenseList sense_map;
 #endif
-  MBErrorCode rval = read_all_faces(topologyID, vert_map, face_map
+  rval = read_all_faces(topologyID, vert_map, face_map
 #ifndef TUPLE_LIST
-                                    , sense_map
+                        , sense_map
 #endif
+                        , new_ents);
     // now construct the cells; sort the face map by cell ids first
 #ifdef TUPLE_LIST
   rval = face_map.sort(1);
-  if (MB_SUCCESS != rval) {
-    readMeshIface->report_error("Couldn't sort face map by cell id.");
+  CHKERR(rval, "Couldn't sort face map by cell id.");
 #endif
-  MBRange new_cells;
+  std::vector<MBEntityHandle> new_cells;
   rval = construct_cells(face_map,
 #ifndef TUPLE_LIST
                          sense_map,
 #endif
                          vert_map, new_cells);
+  if (new_ents) {
+    MBRange::iterator rit = new_ents->end();
+    std::vector<MBEntityHandle>::reverse_iterator vit;
+    for (vit = new_cells.rbegin(); vit != new_cells.rend(); vit++)
+      rit = new_ents->insert(rit, *vit);
+  rval = read_gids_and_types(problemID, topologyID, new_cells);
   return MB_SUCCESS;
+MBErrorCode ReadCCMIO::read_gids_and_types(CCMIOID problemID,
+                                           CCMIOID topologyID,
+                                           std::vector<MBEntityHandle> &cells)
+    // get the cells entity and number of cells
+  CCMIOSize_t num_cells;
+  CCMIOID cellsID, mapID;
+  CCMIOGetEntity(&error, topologyID, kCCMIOCells, 0, &cellsID);
+  CCMIOEntitySize(&error, cellsID, &num_cells, NULL);
+    // check the number of cells against how many are in the cell array
+  if (num_cells != (int)cells.size())
+    CHKERR(MB_FAILURE, "Number of cells doesn't agree.");
+    // read the gid map and set global ids
+  std::vector<int> cell_gids(GETINT32(num_cells));
+  CCMIOReadCells(&error, cellsID, &mapID, NULL,
+                 CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
+  CCMIOReadMap(&error, mapID, &cell_gids[0],
+  CHKCCMERR(error, "Couldn't read cells or cell id map.");
+  MBErrorCode rval = mbImpl->tag_set_data(mGlobalIdTag, &cells[0],
+                                          cells.size(), &cell_gids[0]);
+  CHKERR(rval, "Couldn't set gids tag.");
+    // now read cell types; first get the number of different types, so we can make material
+    // sets
+  int num_matsets = 0;
+  CCMIOSize_t dum = CCMIOSIZEC(0);
+  // if we don't have a problem description, return
+  if (!CCMIOIsValidEntity(problemID)) return MB_SUCCESS;
+    // get the number of cells
+  CCMIOID next;
+  while (kCCMIONoErr == CCMIONextEntity(NULL, problemID, kCCMIOCellType, &dum, &next))
+    num_matsets++;
+    // create the matsets
+  for (int i = 0; i < num_matsets; i++) {
+    MBEntityHandle matset;
+    rval = mbImpl->create_meshset(MESHSET_SET, matset);
+    CHKERR(rval, "Couldn't create material set.");
+    newMatsets.insert(matset);
+    // read in cell types and use to assign cells to matsets; reuse cell_gids
+  CCMIOReadCells(&error, cellsID, NULL, &cell_gids[0],
+  CHKCCMERR(error, "Trouble reading cell types.");
+    // check min/max
+  int min = *(std::min_element(cell_gids.begin(), cell_gids.end())),
+      max = *(std::max_element(cell_gids.begin(), cell_gids.end()));
+  if (1 != min || num_matsets != max) CHKERR(MB_FAILURE, "Wrong range for cell types.");
+  if (min == max && num_matsets == 1) {
+      // no streaming necessary, all elements are in this set
+    rval = mbImpl->add_entities(newMatsets[0], &cells[0], cells.size());
+    CHKERR(rval, "Trouble adding cells to matset.");
+  else {
+      // now stream through cell types, gather cells for each type, add to matsets
+    MBRange mcells;
+    for (int i = 1; i <= num_matsets; i++) {
+      mcells.clear();
+        // go backwards, since it's more efficient when adding to the end of a range
+      for (int j = num_cells-1; j >= 0; j--)
+        if (cell_gids[j] == i) mcells.insert(cells[j]);
+      rval = mbImpl->add_entities(newMatsets[i-1], mcells);
 MBErrorCode ReadCCMIO::construct_cells(TupleList &face_map,
 #ifndef TUPLE_LIST
                                        SenseList &sense_map,
 #endif
-                                       MBRange &new_cells)
+                                       std::vector<MBEntityHandle> &new_cells)
   std::vector<MBEntityHandle> facehs;
   std::vector<int> senses;
@@ -269,11 +487,11 @@
       senses.push_back(face_map.get_short(inext));
 #else
-    std::map<int,std::vector<MBEntityHandle> >::iterator fmit;
-    std::map<int,std::vector<int> >::iterator smit;
-    for (fmit = face_map.begin(), smit = sense_map.begin();
-         fmit != face_map.end(); fmit++, smit++) {
+  std::map<int,std::vector<MBEntityHandle> >::iterator fmit;
+  std::map<int,std::vector<int> >::iterator smit;
+  for (fmit = face_map.begin(), smit = sense_map.begin();
+       fmit != face_map.end(); fmit++, smit++) {
       // pull out face handles bounding the same cell
     facehs.clear();
     int this_id = (*fmit).first;
@@ -284,7 +502,7 @@
     tmp_rval = create_cell_from_faces(facehs, senses, cell);
     if (MB_SUCCESS != tmp_rval) rval = tmp_rval;
     else {
-      new_cells.insert(cell);
+      new_cells.push_back(cell);
         // tag cell with global id
       tmp_rval = mbImpl->tag_set_data(mGlobalIdTag, &cell, 1, &this_id);
@@ -315,21 +533,15 @@
       (MBQUAD == this_type && facehs.size() != 6) ||
       (MBQUAD != this_type && MBTRI != this_type)) {
     rval = mbImpl->create_element(MBPOLYHEDRON, &facehs[0], facehs.size(), cell);
-      readMeshIface->report_error("Couldn't make polyhedron.");
-    else return MB_SUCCESS;
+    CHKERR(rval, "Couldn't make polyhedron.");
+    return rval;
     // try tet and hex elements; get connectivity of first face
   std::vector<MBEntityHandle> verts;
   rval = mbImpl->get_connectivity(&facehs[0], 1, verts);
+  CHKERR(rval, "Couldn't get connectivity.");
   bool match = false;
-    readMeshIface->report_error("Couldn't get connectivity.");
     // reverse connectivity if sense is forward, since base face always points
     // into entity
@@ -341,13 +553,12 @@
       // get the 4th vertex through the next tri
     const MBEntityHandle *conn; int conn_size;
     rval = mbImpl->get_connectivity(facehs[1], conn, conn_size, true, &storage);
     int i = 0;
     while (std::find(verts.begin(), verts.end(), conn[i]) != verts.end() && i < conn_size) i++;
-    if (conn_size == i) return MB_FAILURE;
+    if (conn_size == i)
+      CHKERR(MB_FAILURE, "Didn't find apex vertex.");
     match = true;
     this_type = MBTET;
@@ -369,48 +580,37 @@
       // get q1, which shares 2 vertices with q0
     std::copy(facehs.begin(), facehs.end(), mb_range_inserter(tmp_faces));
     rval = mbImpl->get_adjacencies(&verts[0], 2, 2, false, tmp_faces);
-    if (MB_SUCCESS != rval || tmp_faces.size() != 2) {
-      readMeshIface->report_error("Couldn't get adj face.");
+    if (MB_SUCCESS != rval || tmp_faces.size() != 2)
+      CHKERR(MB_FAILURE, "Couldn't get adj face.");
     tmp_faces.erase(facehs[0]);
     MBEntityHandle q1 = *tmp_faces.begin();
       // get other 2 verts of q1
     rval = mbImpl->get_connectivity(&q1, 1, tmp_verts);
-      readMeshIface->report_error("Couldn't get adj verts.");
+    CHKERR(rval, "Couldn't get adj verts.");
     tmp_verts.erase(verts[0]); tmp_verts.erase(verts[1]);
       // get q2
     rval = mbImpl->get_adjacencies(tmp_verts, 2, false, tmp_faces);
     tmp_faces.erase(q1);
     MBEntityHandle q2 = *tmp_faces.begin();
       // get verts in q2
     rval = mbImpl->get_connectivity(&q2, 1, storage);
-      readMeshIface->report_error("Couldn't get adj vertices.");
+    CHKERR(rval, "Couldn't get adj vertices.");
       // get verts in q1 opposite from v[1] and v[0] in q0
     MBEntityHandle v0 = 0, v1 = 0;
     rval = mtu.opposite_entity(q1, verts[1], v0);
     rval = mtu.opposite_entity(q1, verts[0], v1);
-    if (!v0 || !v1) {
-      readMeshIface->report_error("Trouble finding opposite vertices.");
+    if (!v0 || !v1)
+      CHKERR(MB_FAILURE, "Trouble finding opposite vertices.");
       // offset of v0 in q2, then rotate and flip
     unsigned int ioff = std::find(storage.begin(), storage.end(), v0) - storage.begin();
-    if (4 == ioff) {
-      readMeshIface->report_error("Trouble finding offset.");
+    if (4 == ioff)
+      CHKERR(MB_FAILURE, "Trouble finding offset.");
     if (storage[(ioff+1)%4] != v1) {
       std::reverse(storage.begin(), storage.end());
@@ -423,24 +623,22 @@
     match = true;
     this_type = MBHEX;
-  if (!match) return MB_FAILURE;
+  if (!match)
+    CHKERR(MB_FAILURE, "Couldn't find vertices for hex.");
-          // now make the element
+    // now make the element
   rval = mbImpl->create_element(this_type, &verts[0], verts.size(), cell);
-    readMeshIface->report_error("create_element failed.");
+  CHKERR(rval, "create_element failed.");
   return MB_SUCCESS;
 MBErrorCode ReadCCMIO::read_all_faces(CCMIOID topologyID, TupleList &vert_map,
                                       TupleList &face_map
 #ifndef TUPLE_LIST
                                       ,SenseList &sense_map
 #endif
+                                      , MBRange *new_faces)
   CCMIOSize_t index = CCMIOSIZEC(0);
   CCMIOID faceID;
@@ -472,11 +670,8 @@
 #ifndef TUPLE_LIST
                       , sense_map
 #endif
-      readMeshIface->report_error("Trouble reading boundary faces.");
+                      , new_faces);
+    CHKERR(rval, "Trouble reading boundary faces.");
     // now get internal faces
@@ -486,11 +681,8 @@
 #ifndef TUPLE_LIST
                     , sense_map
 #endif
-    readMeshIface->report_error("Trouble reading internal faces.");
+                    , new_faces);
+  CHKERR(rval, "Trouble reading internal faces.");
   return rval;
@@ -501,12 +693,10 @@
 #ifndef TUPLE_LIST
 #endif
-  if (kCCMIOInternalFaces != bdy_or_int && kCCMIOBoundaryFaces != bdy_or_int) {
-    readMeshIface->report_error("Face type isn't boundary or internal.");
+  if (kCCMIOInternalFaces != bdy_or_int && kCCMIOBoundaryFaces != bdy_or_int)
+    CHKERR(MB_FAILURE, "Face type isn't boundary or internal.");
   CCMIOSize_t num_faces;
@@ -517,10 +707,7 @@
   CCMIOSize_t farray_size = CCMIOSIZEC(0);
   CCMIOReadFaces(&error, faceID, bdy_or_int, NULL, &farray_size, NULL,
-    readMeshIface->report_error("Trouble reading face connectivity length.");
+  CHKCCMERR(error, "Trouble reading face connectivity length.");
     // allocate vectors for holding farray and cells for each face; use new for finer
@@ -532,14 +719,11 @@
   CCMIOID mapID;
   CCMIOReadFaces(&error, faceID, bdy_or_int, &mapID, NULL,
                  farray, CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
-    readMeshIface->report_error("Trouble reading face connectivity.");
+  CHKCCMERR(error, "Trouble reading face connectivity.");
   std::vector<MBEntityHandle> face_handles(GETINT32(num_faces), 0);
   MBErrorCode rval = make_faces(farray, vert_map, face_handles);
     // read face cells and make tuples
   int *face_cells;
@@ -547,10 +731,7 @@
   else face_cells = farray;
   CCMIOReadFaceCells(&error, faceID, bdy_or_int, face_cells,
-    readMeshIface->report_error("Trouble reading face cells.");
+  CHKCCMERR(error, "Trouble reading face cells.");
   int *tmp_ptr = face_cells;
   for (int i = 0; i < num_faces; i++) {
@@ -571,19 +752,23 @@
     // now read & set face gids, reuse face_cells 'cuz we know it's big enough
   CCMIOReadMap(&error, mapID, face_cells, CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
-    readMeshIface->report_error("Trouble reading face gids.");
+  CHKCCMERR(error, "Trouble reading face gids.");
   rval = mbImpl->tag_set_data(mGlobalIdTag, &face_handles[0], face_handles.size(), face_cells);
-    readMeshIface->report_error("Couldn't set face global ids.");
+  CHKERR(rval, "Couldn't set face global ids.");
+    // ok, now sort face handles, and add to range
+  std::sort(face_handles.begin(), face_handles.end());
+  if (new_faces) {
+    MBRange::iterator rit = new_faces->end();
+    for (std::vector<MBEntityHandle>::reverse_iterator vit = face_handles.rbegin();
+         vit != face_handles.rend(); vit++)
+      rit = new_faces->insert(rit, *vit);
   return MB_SUCCESS;
 MBErrorCode ReadCCMIO::make_faces(int *farray,
@@ -630,26 +815,20 @@
 MBErrorCode ReadCCMIO::read_vertices(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID,
                                      CCMIOID topologyID, CCMIOID solutionID, bool has_solution,
-                                     MBRange &verts, TupleList &vert_map)
+                                     MBRange *verts, TupleList &vert_map)
     // pre-read the number of vertices, so we can pre-allocate & read directly in
   CCMIOSize_t nverts = CCMIOSIZEC(0);
   CCMIOEntitySize(&error, verticesID, &nverts, NULL);
-  if(kCCMIONoErr != error) {
-    readMeshIface->report_error("Couldn't get number of vertices.");
+  CHKCCMERR(error, "Couldn't get number of vertices.");
     // get # dimensions
   CCMIOSize_t dims;
   float scale;
   CCMIOReadVerticesf(&error, verticesID, &dims, NULL, NULL, NULL, CCMIOINDEXC(0), CCMIOINDEXC(1));
-    readMeshIface->report_error("Couldn't get number of dimensions.");
+  CHKCCMERR(error, "Couldn't get number of dimensions.");
     // allocate vertex space
   MBEntityHandle node_handle = 0;
@@ -661,10 +840,7 @@
   std::vector<double> tmp_coords(GETINT32(dims)*GETINT32(nverts));
   CCMIOReadVerticesd(&error, verticesID, &dims, &scale, &mapID, &tmp_coords[0],
                      CCMIOINDEXC(0), CCMIOINDEXC(0+nverts));
-    readMeshIface->report_error("Trouble reading vertex coordinates.");
+  CHKCCMERR(error, "Trouble reading vertex coordinates.");
     // copy interleaved coords into moab blocked coordinate space
   int i = 0, threei = 0;
@@ -685,15 +861,12 @@
     // put new vertex handles into range
-  verts.insert(node_handle, node_handle+nverts);
+  if (verts) verts->insert(node_handle, node_handle+nverts);
     // pack vert_map with global ids and handles for these vertices
   std::vector<int> gids(GETINT32(nverts));
   CCMIOReadMap(&error, mapID, &gids[0], CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
-    readMeshIface->report_error("Trouble reading vertex global ids.");
+  CHKCCMERR(error, "Trouble reading vertex global ids.");
 #ifdef TUPLE_LIST
   vert_map.resize(GETINT32(nverts));
   for (i = 0; i < GETINT32(nverts); i++) {
@@ -733,10 +906,7 @@
       CCMIONextEntity(&error, rootID, kCCMIOProblemDescription,
                       &i, &problemID);
-    readMeshIface->report_error("Couldn't find state.");
+  CHKCCMERR(error, "Couldn't find state.");
   return MB_SUCCESS;
@@ -754,175 +924,6 @@
-// Method: avtCCMFileFormat::GetIDsForDomain
-// Purpose:
-//   Gets nodes for state, processor, vertices, topology and solution that can
-//   be used to query attributes for variables and meshes.
-// Arguments:
-// Returns:
-// Note:
-// Programmer: Brad Whitlock
-// Creation:   Mon Aug 6 09:10:29 PDT 2007
-// Modifications:
-bool
-avtCCMFileFormat::GetIDsForDomain(int dom,
-    CCMIOID &processor, CCMIOID &vertices, CCMIOID &topology,
-    CCMIOID &solution, bool &hasSolution)
-    const char *mName = "avtCCMFileFormat::GetIDsForDomain: ";
-    // Try and get the requested processor.
-    int proc = dom;
-    bool ret = (
-        CCMIONextEntity(NULL, GetState(), kCCMIOProcessor, &proc, &processor) ==
-        kCCMIONoErr);
-    if(ret)
-        hasSolution = true;
-        ccmErr = kCCMIONoErr;
-        // Try and read the vertices, topology, and solution ids for this
-        // processor.
-        CCMIOReadProcessor(&ccmErr, processor, &vertices, &topology, NULL,
-                           &solution);
-        if(ccmErr != kCCMIONoErr)
-            // That didn't work. (Maybe no solution). See if we can at least
-            // get the vertices and processor.
-                               NULL);
-            if(ccmErr == kCCMIONoErr)
-                hasSolution = false;
-            else
-                ret = false;
-    return ret;
-//  Method: avtCCMFileFormat::GetFaces
-//  Purpose: Reads the face info.
-//  Arguments:
-//    faceID        The ID of the face entity.
-//    faceType      The type of faces (internal or boundary).
-//    nFaces        How many faces are in the entity.
-//    cellIDMap     Used to map cell IDs to indices
-//    vertexIDMap   Used to map vertex IDs to indices
-//    minSize       Min num verts in a face
-//    maxSize       Max num verts in a face
-//    ci            A place to store the face info, must be allocated by
-//                  calling method.
-//  Programmer: Kathleen Bonnell
-//  Creation:   September 5, 2007
-//  Modifications:
-//    Kathleen Bonnell, Thu Mar  6 09:21:02 PST 2008
-//    Removed unused variable.
-//    Dave Bremer, Fri Apr  4 16:29:49 PDT 2008
-//    Fixed a bug in which cell and vertex ids were mistaken for 1-based
-//    indices.
-void
-avtCCMFileFormat::GetFaces(CCMIOID faceID, CCMIOEntity faceType,
-                           unsigned int nFaces, const IDMap &cellIDMap,
-                           const IDMap &vertexIDMap,
-                           int &minSize, int &maxSize, CellInfoVector &ci)
-    if (faceType != kCCMIOInternalFaces && faceType != kCCMIOBoundaryFaces)
-        debug1 << "avtCCMFileFormat::GetFaces encountered an internal error"
-                << endl;
-        return;
-    int getFacesTimer = visitTimer->StartTimer();
-    CCMIOID mapID;
-    unsigned int nCells = 0, size = 0;
-    //intVector faces;
-    intVector faceNodes, faceCells;
-    // Determine the size of the faceNodes array, which is of the
-    // form n1, v1, v2, ...vn1, n2, v1, v2, ... vn2, )
-    CCMIOReadFaces(&ccmErr, faceID, faceType, NULL, &size, NULL,
-                   kCCMIOStart, kCCMIOEnd);
-    faceNodes.resize(size);
-    //faces.resize(nFaces);
-    if (faceType == kCCMIOInternalFaces)
-        faceCells.resize(nFaces*2);
-    else
-        faceCells.resize(nFaces);
-    CCMIOReadFaces(&ccmErr, faceID, faceType, &mapID, NULL,
-                   &faceNodes[0], kCCMIOStart, kCCMIOEnd);
-    CCMIOReadFaceCells(&ccmErr, faceID, faceType, &faceCells[0],
-    //CCMIOReadMap(&ccmErr, mapID, &faces[0], kCCMIOStart, kCCMIOEnd);
-    unsigned int pos = 0;
-    for (unsigned int i = 0; i < nFaces; ++i)
-        FaceInfo newFace;
-        //newFace.id = faces[i];
-            newFace.cells[0] = faceCells[i*2];
-            newFace.cells[1] = faceCells[i*2+1];
-        else
-            newFace.cells[0] = faceCells[i];
-        int nVerts = faceNodes[pos];
-        if (nVerts < minSize)
-            minSize = nVerts;
-        if (nVerts > maxSize)
-            maxSize = nVerts;
-        for (unsigned int j = 0; j < nVerts; ++j)
-            newFace.nodes.push_back( vertexIDMap.IDtoIndex(faceNodes[pos+1+j]) );
-        // cell ids are 1-origin, so must subract 1 to get the
-        // correct index into the CellInfoVector
-            int  c0 = cellIDMap.IDtoIndex(newFace.cells[0]);
-            int  c1 = cellIDMap.IDtoIndex(newFace.cells[1]);
-            ci[c0].faceTypes.push_back(1);
-            ci[c0].faces.push_back(newFace);
-            ci[c1].faceTypes.push_back(2);
-            ci[c1].faces.push_back(newFace);
-        else
-            ci[c0].faceTypes.push_back(0);
-        pos += faceNodes[pos] +1;
-    visitTimer->StopTimer(getFacesTimer, "GetFaces");
 //  Method: avtCCMFileFormat::PopulateDatabaseMetaData
 //  Purpose:
@@ -1230,631 +1231,6 @@
-//  Method: avtCCMFileFormat::GetMesh
-//  Purpose:
-//      Gets the mesh associated with this file.  The mesh is returned as a
-//      derived type of vtkDataSet (ie vtkRectilinearGrid, vtkStructuredGrid,
-//      vtkUnstructuredGrid, etc).
-//  Arguments:
-//      domain      The index of the domain.  If there are NDomains, this
-//                  value is guaranteed to be between 0 and NDomains-1,
-//                  regardless of block origin.
-//      meshname    The name of the mesh of interest.  This can be ignored if
-//                  there is only one mesh.
-//  Creation:   Thu Aug 2 15:01:17 PST 2007
-//  Modifications:
-//    Brad Whitlock, Tue Dec 18 12:57:28 PST 2007
-//    Added support for 2D polygonal shapes.
-//    Kathleen Bonnell, Thu Feb 28 15:00:24 PST 2008
-//    If the primary variable (activeVisItVar) is defined only on a portion of
-//    the mesh, only retrieve (and tesselate) those cells it is defined upon.
-//    indices.
-//    Brad Whitlock, Thu Oct  1 13:36:48 PDT 2009
-//    I refactored this routine into helper routines and added support for
-//    automatically subdividing a mesh on the fly.
-#ifndef MDSERVER
-#include <PolygonToTriangles.C>
-#endif
-vtkDataSet *
-avtCCMFileFormat::GetMesh(int domain, const char *meshname)
-#ifdef MDSERVER
-    return 0;
-#else
-    // Override domain if we're automatically dividing the data
-    int dom = subdividingSingleMesh ? 0 : domain;
-    vtkUnstructuredGrid *ugrid = NULL;
-    vtkPoints *points = NULL;
-    TRY
-        // Read the points
-        points = ReadPoints(dom, meshname);
-        // Read the cell connectivity
-        CellInfoVector cellInfo;
-        int minFaceSize = VTK_LARGE_INTEGER;
-        int maxFaceSize = -1;
-        ReadCellInfo(dom, meshname,
-                     cellInfo, minFaceSize, maxFaceSize);
-        // Convert cellInfo into vtkUnstructuredGrid
-        SelectCellsForThisProcessor(cellInfo, points);
-        ugrid = vtkUnstructuredGrid::New();
-        // Determine cell topology from face lists
-        if (minFaceSize == 2 && maxFaceSize == 2)
-            // 2D edges that we must assemble into polygons and tessellate into
-            // triangles that VisIt can digest.
-            TesselateCells2D(domain, cellInfo, points, ugrid);
-        else if (minFaceSize <= 4 && maxFaceSize <= 4)
-#ifdef ENABLE_SUBDIVISION
-            // If we're subdividing a single domain on the fly then we create
-            // original cell numbers so we can use them in the GetVar method
-            // to return only the cell values that we selected for this chunk
-            // of the mesh.
-            unsigned int oc[2] = {dom, 0};
-            vtkUnsignedIntArray *origCells = 0;
-            if(subdividingSingleMesh)
-                int useCount = 0;
-                for(unsigned int i = 0; i < cellInfo.size(); ++i)
-                    useCount += (cellInfo[i].id != -1) ? 1 : 0;
-                origCells = vtkUnsignedIntArray::New();
-                origCells->SetName("avtOriginalCellNumbers");
-                origCells->SetNumberOfComponents(2);
-                origCells->Allocate(useCount * 3);
-                originalCells[dom] = origCells;
-#endif
-            ugrid->SetPoints(points);
-            // We have zoo elements that we can deal with.
-            vtkCellArray *cellArray = vtkCellArray::New();
-            intVector cellTypes;
-            bool unhandledCellType = false;
-            for (unsigned int i = 0; i < cellInfo.size(); i++)
-                const CellInfo &ci = cellInfo[i];
-                if(ci.id == -1)
-                    continue;
-                oc[1] = ci.id;
-#endif
-                switch(ci.faces.size())
-                    case 4 :
-                        BuildTet(ci, cellArray, cellTypes);
-                            origCells->InsertNextTupleValue(oc);
-#endif
-                        break;
-                    case 5 :
-                        int nNodes = 0;
-                        for (size_t j = 0; j < ci.faces.size(); j++)
-                            nNodes += ci.faces[j].nodes.size();
-                        if (nNodes == 16) // Pyramid
-                            BuildPyramid(ci, cellArray, cellTypes);
-#endif
-                        else if (nNodes == 18) // Wedge
-                            BuildWedge(ci, cellArray, cellTypes);
-#endif
-                        else
-                            unhandledCellType = true;
-                        break;
-                    case 6 :
-                        BuildHex(ci, cellArray, cellTypes);
-#endif
-                        break;
-                    default :
-                        break;
-            ugrid->SetCells(&cellTypes[0], cellArray);
-            cellArray->Delete();
-        else
-            TesselateCell(domain, cellInfo, points, ugrid);
-        points->Delete();
-    CATCHALL
-        if(points != NULL)
-            points->Delete();
-        if(ugrid != NULL)
-            ugrid->Delete();
-    ENDTRY
-    return ugrid;
-#endif
-// Method: avtCCMFileFormat::ReadPoints
-// Purpose:
-//   Reads the points associated with a specified domain/mesh.
-// Arguments:
-//   dom         : The domain number.
-//   meshname    : The name of the mesh.(for error reporting)
-// Returns:    The vtkPoints object that contains the points.
-// Note:       This method was broken out from the original GetMesh routine.
-// Programmer: Kathleen Bonnell, Brad Whitlock
-// Creation:   Thu Oct  1 13:29:03 PDT 2009
-// Modifications:
-vtkPoints *
-avtCCMFileFormat::ReadPoints(int dom, const char *meshname)
-    CCMIOID processor, vertices, topology, solution;
-    bool hasSolution = true;
-    if(!GetIDsForDomain(dom, processor, vertices, topology, solution,
-                        hasSolution))
-        EXCEPTION1(InvalidVariableException, meshname);
-    // Read the size of the vertices
-    CCMIOSize nnodes = 0;
-    CCMIOEntitySize(&ccmErr, vertices, &nnodes, NULL);
-        debug4 << "CCMIOEntitySize for vertices failed with error " ;
-        debug4 << ccmErr << endl;
-    // Read the dimensions of the vertex.
-    int dims = 1;
-    float scale;
-    CCMIOReadVerticesf(&ccmErr, vertices, &dims, NULL, NULL, NULL, 0, 1);
-        debug4 << "CCMIOReadVertices for first vertex dimensions ";
-        debug4 << "failed with error " << ccmErr << endl;
-    // Allocate VTK memory.
-    vtkPoints *points = vtkPoints::New();
-    points->SetNumberOfPoints(nnodes);
-    float *pts = (float *)points->GetVoidPointer(0);
-    // Read the data into the VTK points.
-    CCMIOID mapID;
-    if(dims == 2)
-        // Read 2D points and convert to 3D, storing into VTK.
-        float *pts2d = new float[2 * nnodes];
-        CCMIOReadVerticesf(&ccmErr, vertices, &dims, &scale, &mapID, pts2d,
-                   0, nnodes);
-        float *src = pts2d;
-        float *dest = pts;
-        for(int i = 0; i < nnodes; ++i)
-            *dest++ = *src++;
-            *dest++ = *src++;
-            *dest++ = 0.;
-        delete [] pts2d;
-    else
-        // Read the data directly into the VTK buffer.
-        CCMIOReadVerticesf(&ccmErr, vertices, &dims, &scale, &mapID, pts,
-                   0, nnodes);
-    // Scale the points, according to the scale factor read with the
-    // vertices.
-        pts[0] *= scale;
-        pts[1] *= scale;
-        pts[2] *= scale;
-        pts += 3;
-    return points;
-// Method: avtCCMFileFormat::ReadCellInfo
-// Purpose:
-//   Reads the cell info associated with a specified domain/mesh.
-// Arguments:
-//   cellInfo    : The cell information to populate.
-//   minFaceSize : Return value of the min face size.
-//   maxFaceSize : Return value of the max face size.
-// Returns:
-//             min/maxFaceSize are used to determine whether tesselation is
-//             required.
-// Modifications:
-void
-avtCCMFileFormat::ReadCellInfo(int dom, const char *meshname,
-    CellInfoVector &cellInfo, int &minFaceSize, int &maxFaceSize)
-                       hasSolution))
-    // Read the dimensions of the vertex and get the mapID
-    int dims = 1;
-    CCMIOID mapID;
-    CCMIOReadVerticesf(&ccmErr, vertices, &dims, NULL, &mapID, NULL, 0, 1);
-    // Read the vertex ids
-    intVector tmpVertexMap(nnodes);
-    CCMIOReadMap(&ccmErr, mapID, &tmpVertexMap[0], kCCMIOStart, kCCMIOEnd);
-    IDMap  vertexIDMap;
-    vertexIDMap.SetIDs(tmpVertexMap);
-    tmpVertexMap.clear();
-    // Get the topology information
-    CCMIOID faceID, cellsID;
-    unsigned int nIFaces = 0, nCells = 0, size = 0;
-    intVector cells;
-    //intVector cellMatType;
-    // Read the cells entity
-    CCMIOGetEntity(&ccmErr, topology, kCCMIOCells, 0, &cellsID);
-    // Read the cells entity size (num cells)
-    CCMIOEntitySize(&ccmErr, cellsID, &nCells, NULL);
-    cells.resize(nCells);
-    cellInfo.resize(nCells);
-    //cellMatType.resize(nCells);
-    // this gets the cell types and the map that stores the cell ids
-    CCMIOReadCells(&ccmErr, cellsID, &mapID, NULL,
-    CCMIOReadMap(&ccmErr, mapID, &cells[0], kCCMIOStart, kCCMIOEnd);
-    for (int i = 0; i < nCells; ++i)
-        cellInfo[i].id = cells[i];
-    IDMap cellIDMap;
-    cellIDMap.SetIDs(cells);
-    // Read the boundary faces.
-    int index = 0;
-    int count = 0;
-    int nBoundaries = 0;
-    while (CCMIONextEntity(NULL, topology, kCCMIOBoundaryFaces, &index,
-                           &faceID) == kCCMIONoErr)
-        nBoundaries++;
-    index = 0;
-        CCMIOSize nBFaces;
-        CCMIOEntitySize(&ccmErr, faceID, &nBFaces, NULL);
-        GetFaces(faceID, kCCMIOBoundaryFaces, nBFaces,
-                 cellIDMap, vertexIDMap,
-                 minFaceSize, maxFaceSize, cellInfo);
-    // Read the internal faces.
-    // Get the InternalFaces entity.
-    CCMIOGetEntity(&ccmErr, topology, kCCMIOInternalFaces, 0, &faceID);
-    // Get the InternalFaces size (num faces).
-    CCMIOEntitySize(&ccmErr, faceID, &nIFaces, NULL);
-    GetFaces(faceID, kCCMIOInternalFaces, nIFaces, cellIDMap, vertexIDMap,
-    if (find(varsOnSubmesh.begin(), varsOnSubmesh.end(), activeVisItVar)
-            != varsOnSubmesh.end())
-        // need to reduce the number of cells we actually process.
-        intVector validCells;
-        CellInfoVector vcv;
-        GetCellMapData(dom, activeVisItVar, validCells);
-        for (int i = 0; i < cellInfo.size(); ++i)
-            if (find(validCells.begin(), validCells.end(), cellInfo[i].id)
-                     != validCells.end())
-                vcv.push_back(cellInfo[i]);
-        cellInfo = vcv;
-    debug5 << "minFaceSize = " << minFaceSize
-           << ", maxFaceSize = " << maxFaceSize << endl;
-// Method: ComputePatchCenter
-// Purpose:
-//   Computes the center and bounds of the patch.
-// Arguments:
-//   centers : The centers for each cell in the mesh.
-//   patch   : The list of cellids that make up the patch.
-//   center  : The calculated center of the patch.
-//   bounds  : The calculated bounds of the patch.
-// Creation:   Tue Oct  6 16:12:08 PDT 2009
-// Modifications:
-static void
-ComputePatchCenter(const double *centers, const intVector &patch, double *center, double *bounds)
-    center[0] = 0.;
-    center[1] = 0.;
-    center[2] = 0.;
-    int nMatches = 0;
-    for(int i = 0; i < patch.size(); ++i)
-        const double *c = centers + patch[i] * 3;
-        // Compute extents of cell centers.
-        if(nMatches == 0)
-            bounds[0] = bounds[1] = c[0];
-            bounds[2] = bounds[3] = c[1];
-            bounds[4] = bounds[5] = c[2];
-        else
-            if(c[0] < bounds[0])
-                bounds[0] = c[0];
-            if(c[0] > bounds[1])
-                bounds[1] = c[0];
-            if(c[1] < bounds[2])
-                bounds[2] = c[1];
-            if(c[1] > bounds[3])
-                bounds[3] = c[1];
-            if(c[2] < bounds[4])
-                bounds[4] = c[2];
-            if(c[2] > bounds[5])
-                bounds[5] = c[2];
-        center[0] += c[0];
-        center[1] += c[1];
-        center[2] += c[2];
-        nMatches++;
-    if(nMatches > 0)
-        center[0] /= double(nMatches);
-        center[1] /= double(nMatches);
-        center[2] /= double(nMatches);
-// Method: DivideLargestPatch
-// Purpose:
-//   Divides the largest patch in the patch vector.
-// Arguments:
-//   centers : The centers of all cells in the mesh.
-//   patches : The list of all patches.
-// Returns:
-// Note:       This routine modifies the patches vector by splitting 1 of the
-//             patches, replacing the split patch with piece0. piece1 is appended
-//             to the patch vector.
-// Creation:   Tue Oct  6 16:13:33 PDT 2009
-// Modifications:
-static void
-DivideLargestPatch(const double *centers, std::vector<intVector> &patches)
-    // Find the index of the largest patch
-    int maxIndex = 0;
-    for(int i = 1; i < patches.size(); ++i)
-        if(patches[i].size() > patches[maxIndex].size())
-            maxIndex = i;
-    // Compute the center at which we will bisect.
-    double center[3], bounds[6];
-    ComputePatchCenter(centers, patches[maxIndex], center, bounds);
-    // Figure out the longest dimension since that's the dimension we'll bisect.
-    double dX = bounds[1] - bounds[0];
-    double dY = bounds[3] - bounds[2];
-    double dZ = bounds[5] - bounds[4];
-    int longestDimension = 2;
-    if(dX > dY)
-        if(dX > dZ)
-            longestDimension = 0;
-    else
-        if(dY > dZ)
-            longestDimension = 1;
-    const intVector &patch = patches[maxIndex];
-    intVector piece0, piece1;
-    for(int j = 0; j < patch.size(); ++j)
-        const double *c = centers + patch[j] * 3;
-        if(c[longestDimension] > center[longestDimension])
-            piece0.push_back(patch[j]);
-        else
-            piece1.push_back(patch[j]);
-    patches[maxIndex] = piece0;
-    patches.push_back(piece1);
-#endif
-// Method: avtCCMFileFormat::SelectCellsForThisProcessor
-// Purpose:
-//   This routine divides the cells spatially into PAR_Size() different bins
-//   and sets all of the ids for the cells in cellInfo to -1 (invalid) unless
-//   their bin matches PAR_Rank(). This means that we are marking a subset of
-//   the cells in cellInfo as being valid so we can return just a part of the
-//   dataset.
-// Arguments:
-//   cellInfo : The vector of cell data.
-//   points   : The points used by the cells.
-// Returns:
-// Note:       This method is just used in parallel when we have a single
-//             domain dataset that we want to automatically chunk up under the
-//             covers.
-// Creation:   Thu Oct  1 13:25:17 PDT 2009
-// Modifications:
-void
-avtCCMFileFormat::SelectCellsForThisProcessor(CellInfoVector &cellInfo, vtkPoints *points)
-        // Compute cell centers
-        double *centers = new double[cellInfo.size() * 3];
-        for(size_t i = 0; i < cellInfo.size(); ++i)
-            cellInfo[i].CellCenter(centers + i * 3, points);
-        // Start out with all cells in 1 patch
-        std::vector<intVector> patches;
-        intVector allCells;
-            allCells.push_back(i);
-        patches.push_back(allCells);
-        // Divide the largest patch until we have enough patches.
-        while(patches.size() < PAR_Size())
-            DivideLargestPatch(centers, patches);
-        // Set cellid to -1 unless we're on the patch whose id == PAR_Rank.
-        for(size_t p = 0; p < patches.size(); ++p)
-            if(p == PAR_Rank())
-                continue;
-            const intVector &patch = patches[p];
-            for(size_t i = 0; i < patch.size(); ++i)
-                cellInfo[patch[i]].id = -1;
-        delete [] centers;
-#endif
 //  Method:  avtCCMFileFormat::RegisterVariableList
 //  Purpose:
@@ -2219,363 +1595,6 @@
-//  Method: avtCCMFileFormat::TesselateCell
-//  Purpose:
-//  Arguments:
-//    civ       Contains cell information.
-//    points    The points comprising the dataset.
-//    ugrid     The unstructured grid we are building.
-//  Creation:   October 1, 2007
-//  Modifications:
-//    Use cellid stored in CellInfo in avtOriginalCellNumbers array.
-//    Change fbounds to doubleVector to get around compiler problem on Windows.
-//    indices.
-void
-avtCCMFileFormat::TesselateCell(const int domain, const CellInfoVector &civ,
-    vtkPoints *points, vtkUnstructuredGrid *ugrid)
-#ifndef MDSERVER
-    const char *mName = "avtCCMFileFormat::TesselateCell: ";
-    unsigned int i, j, k;
-    unsigned int tetCount = 0;
-    vtkPoints *pts = vtkPoints::New();
-    pts->Allocate(points->GetNumberOfPoints());
-    VertexManager uniqueVerts(pts);
-    ccmPolygonToTriangles tess(&uniqueVerts);
-    int useCount = 0;
-    for(i = 0; i < civ.size(); ++i)
-         useCount += (civ[i].id != -1) ? 1 : 0;
-    originalCells[dom] = vtkUnsignedIntArray::New();
-    originalCells[dom]->SetName("avtOriginalCellNumbers");
-    originalCells[dom]->SetNumberOfComponents(2);
-    originalCells[dom]->Allocate(useCount * 3);
-    for (i = 0; i < civ.size(); ++i)
-        const CellInfo &ci = civ[i];
-        if(ci.id == -1)
-            continue;
-        oc[1] = ci.id;
-        int nFaces  = ci.faces.size();
-        int nPts = 0;
-        doubleVector fbounds;
-        for (j = 0; j < nFaces; ++j)
-            nPts += ci.faces[j].nodes.size();
-            fbounds.push_back(VTK_LARGE_FLOAT);
-            fbounds.push_back(-VTK_LARGE_FLOAT);
-        double *pt;
-        double cbounds[6] = {VTK_LARGE_FLOAT, -VTK_LARGE_FLOAT,
-                             VTK_LARGE_FLOAT, -VTK_LARGE_FLOAT,
-                             VTK_LARGE_FLOAT, -VTK_LARGE_FLOAT};
-        int cnt = 0;
-            const intVector &nodes = ci.faces[j].nodes;
-            for (k = 0; k < nodes.size(); ++k)
-                cnt++;
-                pt = points->GetPoint(nodes[k]);
-                if (pt[0] < cbounds[0])
-                    cbounds[0] = pt[0];
-                if (pt[0] > cbounds[1])
-                    cbounds[1] = pt[0];
-                if (pt[1] < cbounds[2])
-                    cbounds[2] = pt[1];
-                if (pt[1] > cbounds[3])
-                    cbounds[3] = pt[1];
-                if (pt[2] < cbounds[4])
-                    cbounds[4] = pt[2];
-                if (pt[2] > cbounds[5])
-                    cbounds[5] = pt[2];
-                if (pt[0] < fbounds[j*6+0])
-                    fbounds[j*6+0] = pt[0];
-                if (pt[0] > fbounds[j*6+1])
-                    fbounds[j*6+1] = pt[0];
-                if (pt[1] < fbounds[j*6+2])
-                    fbounds[j*6+2] = pt[1];
-                if (pt[1] > fbounds[j*6+3])
-                    fbounds[j*6+3] = pt[1];
-                if (pt[2] < fbounds[j*6+4])
-                    fbounds[j*6+4] = pt[2];
-                if (pt[2] > fbounds[j*6+5])
-                    fbounds[j*6+5] = pt[2];
-            } // k nodes
-        } // j faces
-        double cc[3] = {0.,0.,0.};
-        double fc[3] = {0.,0.,0.};
-        for (j = 0; j < 3; ++j)
-            cc[j] = (cbounds[2*j+1]+cbounds[2*j])/2.0;
-        int centerId = uniqueVerts.GetVertexId(cc);
-            // Find the face center
-            for (k = 0; k < 3; ++k)
-                fc[k] = (fbounds[2*k+1+(6*j)]+fbounds[2*k+(6*j)])/2.0;
-            // Tesselate the face
-            double n[3] = {(cc[0] - fc[0]), (cc[1] - fc[1]), (cc[2] - fc[2])};
-            tess.SetNormal(n);
-            tess.BeginPolygon();
-            tess.BeginContour();
-                cnt++;
-                tess.AddVertex(pt);
-            } // k nodes
-            tess.EndContour();
-            tess.EndPolygon();
-            // Make a tet for each triangle in the face to the cell center.
-            vtkIdType verts[4];
-            verts[3] = centerId;
-            if (tess.GetNumTriangles() > 0)
-                for (k = 0; k < tess.GetNumTriangles(); ++k)
-                    int a, b, c;
-                    tess.GetTriangle(k, a, b, c);
-                    verts[0] = a;
-                    verts[1] = b;
-                    verts[2] = c;
-                    ugrid->InsertNextCell(VTK_TETRA, 4, verts);
-                    ((vtkUnsignedIntArray*)originalCells[dom])->
-                        InsertNextTupleValue(oc);
-                tetCount += tess.GetNumTriangles();
-            // prepare for next cell
-            tess.ClearTriangles();
-        } // end face
-    pts->Squeeze();
-    ugrid->SetPoints(pts);
-    pts->Delete();
-    ugrid->GetCellData()->AddArray(originalCells[dom]);
-    ugrid->GetCellData()->CopyFieldOn("avtOriginalCellNumbers");
-    debug4 << mName << "Input number of polyhedral cells: " << civ.size()
-           << endl;
-    debug4 << mName << "Output tetrahedral cells: " << tetCount << endl;
-#endif
-// Method: avtCCMFileFormat::TesselateCells2D
-// Purpose:
-//   Adds the 2D cells to the unstructured grid, tessellating them as needed.
-// Arguments:
-//   civ    : The cell information vector.
-//   points : The points that we'll allocate during tessellation.
-//   ugrid  : The return unstructured grid object.
-// Returns:
-// Note:
-// Creation:   Tue Dec 18 12:54:56 PST 2007
-// Modifications:
-//   Remove unused variables.
-//   indices.
-typedef std::pair<int,int> edge_pair;
-void
-avtCCMFileFormat::TesselateCells2D(const int domain, const CellInfoVector &civ,
-#ifndef MDSERVER
-    unsigned int i, k;
-    int useCount = 0;
-    originalCells[dom]->Allocate(useCount*3);
-    const double n[3] = {0., 0., 1.};
-        if(ci.id == -1)
-            continue;
-        oc[1] = ci.id;
-        // We need to sort the edges around the polygon so we can tessellate
-        // by adding the first vertex of each edge to define the contour. We
-        // could do a different approach making n-1 triangles for the number
-        // of edges in the shape but this way supports concave polygons whereas
-        // the other approach does not.
-        // Put all of the line segments in a pool of free edges.
-        std::set<edge_pair> freeEdges;
-        for (int f = 0; f < ci.faces.size(); ++f)
-             edge_pair e01(ci.faces[f].nodes[0], ci.faces[f].nodes[1]);
-             freeEdges.insert(e01);
-        while(freeEdges.size() > 0)
-            std::deque<int> shape;
-            // Get seed edge and remove it from the pool
-            edge_pair currentEdge;
-            if(freeEdges.begin() != freeEdges.end())
-                currentEdge = *freeEdges.begin();
-                freeEdges.erase(freeEdges.begin());
-            shape.push_back(currentEdge.first);
-            shape.push_back(currentEdge.second);
-            // Now, look for edges that contain either of the points in
-            // the current edge.
-            bool found;
-            do
-                found = false;
-                for(std::set<edge_pair>::iterator pos = freeEdges.begin();
-                    pos != freeEdges.end() && !found; ++pos)
-                    if(currentEdge.first == pos->first)
-                        currentEdge.first = pos->second;
-                        shape.push_front(pos->second);
-                        freeEdges.erase(pos);
-                        found = true;
-                    else if(currentEdge.first == pos->second)
-                        currentEdge.first = pos->first;
-                        shape.push_front(pos->first);
-                        found = true;
-                    else if(currentEdge.second == pos->first)
-                        currentEdge.second = pos->second;
-                        shape.push_back(pos->second);
-                        found = true;
-                    else if(currentEdge.second == pos->second)
-                        currentEdge.second = pos->first;
-                        shape.push_back(pos->first);
-                        found = true;
-            } while(found);
-            if(shape.size() > 2)
-                for(int v = 0; v < shape.size(); ++v)
-                    tess.AddVertex(points->GetPoint(shape[v]));
-                int a, b, c;
-                verts[0] = a;
-                verts[1] = b;
-                verts[2] = c;
-                ugrid->InsertNextCell(VTK_TRIANGLE, 3, verts);
-    pts->Squeeze();
-    pts->Delete();
-#endif
 // Method: avtCCMFileFormat::BuildHex
 // Purpose:
@@ -2820,250 +1839,7 @@
-// avtCCMFileFormat::FaceInfo class
-// Method: avtCCMFileFormat::FaceInfo::FaceInfo
-// Purpose:
-//   Constructor
-// Creation:   September 6, 2007
-// Modifications:
-//   Removed unused face id.
-avtCCMFileFormat::FaceInfo::FaceInfo()
-    //id = -1;
-    cells[0] = -1;
-    cells[1] = -1;
-// Purpose:
-//   Copy Constructor
-// Modifications:
-avtCCMFileFormat::FaceInfo::FaceInfo(const avtCCMFileFormat::FaceInfo &obj)
-    //id = obj.id;
-    cells[0] = obj.cells[0];
-    cells[1] = obj.cells[1];
-    nodes = obj.nodes;
-// Method: avtCCMFileFormat::FaceInfo::~FaceInfo
-// Purpose:
-//   Destructor
-// Modifications:
-avtCCMFileFormat::FaceInfo::~FaceInfo()
-// Method: avtCCMFileFormat::FaceInfo::operator =
-// Purpose:
-//   Assignment operator
-// Modifications:
-void
-avtCCMFileFormat::FaceInfo::operator =(const avtCCMFileFormat::FaceInfo &obj)
-    //id = obj.id;
-// avtCCMFileFormat::CellInfo class
-// Method: avtCCMFileFormat::CellInfo::CellInfo
-// Purpose:
-//   Constructor
-// Modifications:
-avtCCMFileFormat::CellInfo::CellInfo()
-    id = -1;
-// Purpose:
-// Modifications:
-avtCCMFileFormat::CellInfo::CellInfo(const avtCCMFileFormat::CellInfo &obj)
-    id = obj.id;
-    faceTypes = obj.faceTypes;
-    faces = obj.faces;
-// Method: avtCCMFileFormat::CellInfo::~CellInfo
-// Purpose:
-//   Destructor
-// Modifications:
-avtCCMFileFormat::CellInfo::~CellInfo()
-// Method: avtCCMFileFormat::CellInfo::operator =
-// Purpose:
-// Modifications:
-void
-avtCCMFileFormat::CellInfo::operator =(const avtCCMFileFormat::CellInfo &obj)
-    id = obj.id;
-// Method: avtCCMFileFormat::CellInfo::CellCenter
-// Purpose:
-//   Determines the cell center from its nodes.
-// Arguments:
-//   center : The returned center.
-//   pts    : The global points array that stores all of the nodes.
-// Creation:   Thu Oct  1 14:02:37 PDT 2009
-// Modifications:
-void
-avtCCMFileFormat::CellInfo::CellCenter(double *center, vtkPoints *pts) const
-    int npts = 0;
-    double c[3] = {0.,0.,0.};
-    for(int i = 0; i < faces.size(); ++i)
-        for(int j = 0; j < faces[i].nodes.size(); ++j, ++npts)
-            double *pt = pts->GetPoint(faces[i].nodes[j]);
-            c[0] += pt[0];
-            c[1] += pt[1];
-            c[2] += pt[2];
-    center[0] = c[0] / double(npts);
-    center[1] = c[1] / double(npts);
-    center[2] = c[2] / double(npts);
-// Method: avtCCMFileFormat::CellInfo::UseNodes
-// Purpose:
-//   Sets a true value into a domain-node-sized bool array for each node that
-//   the cell uses.
-// Arguments:
-//   pts : The array containing the values for whether a node is used.
-// Creation:   Thu Oct  1 14:03:22 PDT 2009
-// Modifications:
-void
-avtCCMFileFormat::CellInfo::UseNodes(bool *pts) const
-        for(int j = 0; j < faces[i].nodes.size(); ++j)
-            pts[faces[i].nodes[j]] = true;
 // Method: operator << (ostream &os, CCMIOEntity e)
 // Purpose:
@@ -3205,168 +1981,4 @@
-// Method: avtCCMFileFormat::IDMap::IDMap
-// Purpose:
-//   Constructor
-// Programmer: Dave Bremer
-// Creation:   Fri Apr  4 16:29:49 PDT 2008
-// Modifications:
-avtCCMFileFormat::IDMap::IDMap()
-    bSequential = false;
-    bReverseMap = false;
-    iFirstElem = 0;
-    numIDs = 0;
-// Method: avtCCMFileFormat::IDMap::SetIDs
-// Purpose:
-//   Analyze a set of IDs and build a structure for mapping them back
-//   to the index corresponding to their position in v.
-// Modifications:
-void
-avtCCMFileFormat::IDMap::SetIDs(const intVector &v)
-    numIDs = v.size();
-    bSequential = true;
-    iFirstElem = v[0];
-    int min = v[0], max = v[0];
-    int ii;
-    for (ii = 1; ii < v.size(); ii++)
-        if (v[ii-1]+1 != v[ii])
-        if (v[ii] < min)
-            min = v[ii];
-        if (v[ii] > max)
-            max = v[ii];
-    //Don't bother copying data in, in this case.
-    if (bSequential)
-        return;
-    if (max-min+1 <= v.size()*2)
-        bReverseMap = true;
-        iFirstElem = min;
-        ids.resize(max-min+1, -1);
-        for (ii = 0; ii < v.size(); ii++)
-            ids[v[ii]-iFirstElem] = ii;
-    else
-        ids.resize(v.size()*2);
-            ids[ii*2]   = v[ii];
-            ids[ii*2+1] = ii;
-        qsort( &ids[0], v.size(), sizeof(int)*2, avtCCMFileFormat::IDMap::compare);
-// Method: avtCCMFileFormat::IDMap::compare
-// Purpose:
-//   compare function for qsort
-// Modifications:
-int
-avtCCMFileFormat::IDMap::compare(const void *a, const void *b)
-    return ( *((int *)a) - *((int *)b) );
-// Method: avtCCMFileFormat::IDMap::IDtoIndex
-// Purpose:
-//   Map an id to an array index.  Return -1 if the id is not in the map.
-// Modifications:
-int
-avtCCMFileFormat::IDMap::IDtoIndex(int id) const
-    if (bSequential)
-        int r = id - iFirstElem;
-        if (r >= 0 && r < numIDs)
-            return r;
-    else if (bReverseMap)
-        if (id-iFirstElem >= 0 && id-iFirstElem < ids.size())
-            return ids[id-iFirstElem];
-    else
-        int min = 0, max = ids.size()/2 - 1;
-        int mid = (min+max)/2;
-        while (min <= max)
-            if (id < ids[mid*2])
-                max = mid-1;
-                mid = (min+max)/2;
-            else if (id > ids[mid*2])
-                min = mid+1;
-            else
-                return ids[mid*2+1];
-    return -1;
Modified: MOAB/trunk/ReadCCMIO.hpp
--- MOAB/trunk/ReadCCMIO.hpp	2010-01-31 14:57:45 UTC (rev 3515)
+++ MOAB/trunk/ReadCCMIO.hpp	2010-01-31 17:55:42 UTC (rev 3516)
@@ -45,33 +45,39 @@
 private:
-  MBErrorCode read_processor(CCMIOID rootID, CCMIOID processorID, CCMIOSize_t proc);
+  MBErrorCode read_processor(CCMIOID rootID, CCMIOID problemID,
+                             MBRange *new_ents);
   MBErrorCode read_cells(CCMIOSize_t proc, CCMIOID processorID,
-                         TupleList &vert_map);
+                         TupleList &vert_map, MBRange *new_cells);
   MBErrorCode construct_cells(TupleList &face_map,
 #ifndef TUPLE_LIST
 #endif
-                              TupleList &vert_map, MBRange &new_cells);
+                              std::vector<MBEntityHandle> &new_cells);
   MBErrorCode create_cell_from_faces(std::vector<MBEntityHandle> &facehs,
                                      std::vector<int> &senses,
                                      MBEntityHandle &cell);
+  MBErrorCode read_gids_and_types(CCMIOID problemID,
+                                  std::vector<MBEntityHandle> &cells);
   MBErrorCode read_all_faces(CCMIOID topologyID, TupleList &vert_map,
                              TupleList &face_map
 #ifndef TUPLE_LIST
 #endif
+                             , MBRange *new_faces);
   MBErrorCode read_faces(CCMIOID faceID, CCMIOEntity bdy_or_int,
@@ -80,7 +86,7 @@
 #ifndef TUPLE_LIST
 #endif
   MBErrorCode make_faces(int *farray,
@@ -88,7 +94,7 @@
   MBErrorCode read_vertices(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID,
-                            MBRange &verts, TupleList &vert_map);
+                            MBRange *verts, TupleList &vert_map);
   MBErrorCode get_processors(CCMIOID stateID, CCMIOID &processorID,
@@ -105,6 +111,14 @@
                                        const IDTag* subset_list = 0,
                                        int subset_list_length = 0 );
+  MBErrorCode load_matset_data(CCMIOID problemID);
+  MBErrorCode load_metadata(CCMIOID rootID, CCMIOID problemID,
+                            const MBEntityHandle *file_set);
+  MBErrorCode create_matset_tags(MBTag &matNameTag, MBTag &matPorosityTag,
+                                 MBTag &matSpinTag, MBTag &matGroupTag);
     //! Cached tags for reading.  Note that all these tags are defined when the
     //! core is initialized.
   MBTag mMaterialSetTag;
@@ -117,6 +131,8 @@
   MBReadUtilIface* readMeshIface;
+  MBRange newMatsets;
   bool hasSolution;
