[MOAB-dev] r3510 - MOAB/trunk
iulian at mcs.anl.gov
Fri Jan 29 11:36:52 CST 2010
Author: iulian
Date: 2010-01-29 11:36:52 -0600 (Fri, 29 Jan 2010)
New Revision: 3510
Modified:
MOAB/trunk/ReadSmf.cpp
MOAB/trunk/ReadSmf.hpp
MOAB/trunk/SMF_State.cpp
Log:
remove exit call from a function in a library
clean up some unused data in ReadSmf
Modified: MOAB/trunk/ReadSmf.cpp
--- MOAB/trunk/ReadSmf.cpp 2010-01-29 16:23:40 UTC (rev 3509)
+++ MOAB/trunk/ReadSmf.cpp 2010-01-29 17:36:52 UTC (rev 3510)
@@ -113,11 +113,6 @@
const MBTag* file_id_tag)
MBErrorCode result;
- int major, minor;
- char vendor_string[257];
- std::vector<MBRange> element_list;
- MBRange vertices;
if (subset_list && subset_list_length) {
readMeshIface->report_error( "Reading subset of files not supported for VTK." );
@@ -131,9 +126,8 @@
if ( result == MB_SUCCESS )
mPartitionTagName = partition_tag_name;
- std::ifstream smfFile;
- //smfFile.open( filename , std::ifstream::in);
- if (!smfFile.is_open())
+ std::ifstream smfFile ( filename );
+ if (!smfFile)
return MB_FILE_DOES_NOT_EXIST;
@@ -143,7 +137,11 @@
while( !smfFile.eof() )
if( smfFile.getline(line, SMF_MAXLINE, '\n').good() )
- parse_line(line);
+ result = parse_line(line);
+ if (MB_SUCCESS != result)
+ return result;
// at this point we have _numNodesInFile vertices and _numElementsInFile triangles
@@ -261,7 +259,7 @@
-void ReadSmf::parse_line(char *line)
+MBErrorCode ReadSmf::parse_line(char *line)
char *cmd,*s;
std::vector<std::string> argv;
@@ -269,10 +267,10 @@
while( *line==' ' || *line=='\t' ) line++; // skip initial white space
// Ignore empty lines
- if( line[0]=='\n' || line[0]=='\0' ) return;
+ if( line[0]=='\n' || line[0]=='\0' ) return MB_SUCCESS;
// Ignore comments
- if( line[0]=='#' && line[1]!='$' ) return;
+ if( line[0]=='#' && line[1]!='$' ) return MB_SUCCESS;
// First, split the line into tokens
@@ -306,9 +304,10 @@
// Invalid command:
std::cerr << "SMF: Illegal command [" << cmd << "]" << std::endl;
- exit(1);
+ return MB_UNSUPPORTED_OPERATION;
+ return MB_SUCCESS;
Modified: MOAB/trunk/ReadSmf.hpp
--- MOAB/trunk/ReadSmf.hpp 2010-01-29 16:23:40 UTC (rev 3509)
+++ MOAB/trunk/ReadSmf.hpp 2010-01-29 17:36:52 UTC (rev 3510)
@@ -84,7 +84,7 @@
void mmult(std::vector<std::string> &);
void mload(std::vector<std::string> &);
- void parse_line(char *line);
+ MBErrorCode parse_line(char *line);
private:
MBReadUtilIface* readMeshIface;
Modified: MOAB/trunk/SMF_State.cpp
--- MOAB/trunk/SMF_State.cpp 2010-01-29 16:23:40 UTC (rev 3509)
+++ MOAB/trunk/SMF_State.cpp 2010-01-29 17:36:52 UTC (rev 3510)
@@ -4,7 +4,7 @@
#include <cstring>
#include <cstdlib>
-inline int streq(const char *a,const char *b) { return strcmp(a,b)==0; }
+inline int streq(const char *a,const char *b) { return std::strcmp(a,b)==0; }
SMF_State::SMF_State(const SMF_ivars& ivar, SMF_State *link)
