[MOAB-dev] Edges on subdomain interface
Jason Kraftcheck kraftche at cae.wisc.edu
Fri Jan 29 09:40:27 CST 2010
Roman Putanowicz wrote:
> Hi,
> Could you please give me a hint what would be the best approach
> to find edges common to two subdomains.
> I read the partitioned mesh and then use MBSkinner to find the
> edges on the subdomain boundary. However I imagine that the edges
> have different orientation thus simple intersection operation on
> MBRange objects representing the edges does not work.
The orientation of the edges shouldn't matter.  The skinner should be
finding any existing edges on the boundary, regardless of orientation.
> Is there in MOAB function to change the orientation of element
> (order of vertices) or should I use quite other approach
MBInterface::set_connectivity
- jason
