[MOAB-dev] r3508 - in MOAB/trunk: . m4
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jan 28 23:24:01 CST 2010
Author: tautges
Date: 2010-01-28 23:24:00 -0600 (Thu, 28 Jan 2010)
New Revision: 3508
Added:
   MOAB/trunk/ReadCCMIO.cpp
   MOAB/trunk/ReadCCMIO.hpp
   MOAB/trunk/WriteCCMIO.cpp
   MOAB/trunk/WriteCCMIO.hpp
   MOAB/trunk/m4/ccmio.m4
Modified:
   MOAB/trunk/MBCN.cpp
   MOAB/trunk/MBCN.hpp
   MOAB/trunk/MBReaderWriterSet.cpp
   MOAB/trunk/Makefile.am
   MOAB/trunk/ReadSmf.cpp
   MOAB/trunk/SMF_State.cpp
   MOAB/trunk/configure.ac
Log:
Adding a CCMIO reader/writer.  Basic functionality for reading hex meshes works.
No metadata processing yet.
Specific changes:
ReadSmf.cpp: commenting out open so make check will work
SMF_State.cpp: adding some includes for gcc4.4
configure.ac, m4/ccmio.m4, Makefile.am: processing options for ccmio reader
MBCN.cpp: un-commenting SubEntityConn function; why was this commented out in the first place?
MBReaderWriterSet, ReadCCMIO, WriteCCMIO: CCMIO reader/writer
Make check works now, again.
Modified: MOAB/trunk/MBCN.cpp
--- MOAB/trunk/MBCN.cpp	2010-01-28 21:02:20 UTC (rev 3507)
+++ MOAB/trunk/MBCN.cpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -122,21 +122,21 @@
 //! \param sub_entity_conn Connectivity of sub-entity, based on parent_conn and canonical
 //!           ordering for parent_type
 //! \param num_sub_vertices Number of vertices in sub-entity
-//void MBCN::SubEntityConn(const void *parent_conn, const MBEntityType parent_type,
-//                         const int sub_dimension,
-//                         const int sub_index,
-//                         void *sub_entity_conn, int &num_sub_vertices)
-//  static int sub_indices[MB_MAX_SUB_ENTITY_VERTICES];
-//  SubEntityVertexIndices(parent_type, sub_dimension, sub_index, sub_indices);
-//  num_sub_vertices = VerticesPerEntity(SubEntityType(parent_type, sub_dimension, sub_index));
-//  void **parent_conn_ptr = static_cast<void **>(const_cast<void *>(parent_conn));
-//  void **sub_conn_ptr = static_cast<void **>(sub_entity_conn);
-//  for (int i = 0; i < num_sub_vertices; i++)
-//    sub_conn_ptr[i] = parent_conn_ptr[sub_indices[i]];
+void MBCN::SubEntityConn(const void *parent_conn, const MBEntityType parent_type,
+                         const int sub_dimension,
+                         const int sub_index,
+                         void *sub_entity_conn, int &num_sub_vertices)
+  static int sub_indices[MB_MAX_SUB_ENTITY_VERTICES];
+  SubEntityVertexIndices(parent_type, sub_dimension, sub_index, sub_indices);
+  num_sub_vertices = VerticesPerEntity(SubEntityType(parent_type, sub_dimension, sub_index));
+  void **parent_conn_ptr = static_cast<void **>(const_cast<void *>(parent_conn));
+  void **sub_conn_ptr = static_cast<void **>(sub_entity_conn);
+  for (int i = 0; i < num_sub_vertices; i++)
+    sub_conn_ptr[i] = parent_conn_ptr[sub_indices[i]];
 //! given an entity and a target dimension & side number, get that entity
 short int MBCN::AdjacentSubEntities(const MBEntityType this_type,
Modified: MOAB/trunk/MBCN.hpp
--- MOAB/trunk/MBCN.hpp	2010-01-28 21:02:20 UTC (rev 3507)
+++ MOAB/trunk/MBCN.hpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -216,10 +216,10 @@
-//  static void SubEntityConn(const void *parent_conn, const MBEntityType parent_type,
-//                            void *sub_entity_conn, int &num_sub_vertices);
+  static void SubEntityConn(const void *parent_conn, const MBEntityType parent_type,
+                            void *sub_entity_conn, int &num_sub_vertices);
   //! For a specified set of sides of given dimension, return the intersection
   //! or union of all sides of specified target dimension adjacent to those sides.
Modified: MOAB/trunk/MBReaderWriterSet.cpp
--- MOAB/trunk/MBReaderWriterSet.cpp	2010-01-28 21:02:20 UTC (rev 3507)
+++ MOAB/trunk/MBReaderWriterSet.cpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -48,6 +48,11 @@
 #  include "WriteSLAC.hpp"
 #endif
+#ifdef CCMIO_FILE
+#  include "WriteCCMIO.hpp"
+#  include "ReadCCMIO.hpp"
+#endif
 #ifdef HDF5_FILE
 #  include "ReadHDF5.hpp"
 #  ifdef HDF5_PARALLEL
@@ -110,6 +115,12 @@
   register_factory( NULL, WriteSLAC::factory, "SLAC", "slac", "SLAC" );
 #endif
+#ifdef CCMIO_FILE
+  const char* ccmio_sufxs[] = { "ccm", "ccmg", NULL };
+  register_factory( NULL, WriteCCMIO::factory, "CCMIO files", ccmio_sufxs, "CCMIO");
+  register_factory( ReadCCMIO::factory, NULL, "CCMIO files", ccmio_sufxs, "CCMIO");
+#endif
   register_factory( NULL, WriteGMV::factory, "GMV", "gmv", "GMV" );
   register_factory( NULL, WriteAns::factory, "Ansys", "ans", "ANSYS" );
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2010-01-28 21:02:20 UTC (rev 3507)
+++ MOAB/trunk/Makefile.am	2010-01-29 05:24:00 UTC (rev 3508)
@@ -78,6 +78,10 @@
   INCLUDES += -I$(srcdir)/mhdf/include
   MOAB_EXTRA_SRCS += ReadHDF5.cpp ReadHDF5.hpp WriteHDF5.cpp WriteHDF5.hpp
 endif
+if CCMIO_FILE
+  MOAB_EXTRA_SRCS += WriteCCMIO.cpp WriteCCMIO.hpp ReadCCMIO.cpp ReadCCMIO.hpp
+  libMOAB_la_LIBADD += $(CCMIO_LIBS)
+endif
 if PARALLEL
   libMOAB_la_LIBADD += $(top_builddir)/parallel/libMOABpar.la
Added: MOAB/trunk/ReadCCMIO.cpp
--- MOAB/trunk/ReadCCMIO.cpp	                        (rev 0)
+++ MOAB/trunk/ReadCCMIO.cpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -0,0 +1,3372 @@
+#include <stdlib.h>	// For exit()
+#include <vector>
+#include <map>
+#include <iostream>
+#include <string>
+#include <algorithm>
+#include "MBCN.hpp"
+#include "MBRange.hpp"
+#include "MBInterface.hpp"
+#include "MBTagConventions.hpp"
+#include "MBInternals.hpp"
+#include "MBReadUtilIface.hpp"
+#include "FileOptions.hpp"
+#include "ReadCCMIO.hpp"
+#include "MeshTopoUtil.hpp"
+#include "ccmio.h"
+ * CCMIO file structure
+ * Root
+ *   State / Problem = "default"
+ *     Processor
+ *       Vertices
+ *         ->CCMIOReadVerticesx
+ *       Topology
+ *         Cells
+ *       Solution
+ *         Phase
+ *           Field
+ *             FieldData
+ *     Processor ...
+enum DataType { kScalar, kVector, kVertex, kCell, kInternalFace, kBoundaryFace,
+                kBoundaryData, kBoundaryFaceData, kCellType };
+static int const kNValues = 10;	// Number of values of each element to print
+static char const kDefaultState[] = "default";
+static char const kUnitsName[] = "Units";
+static int const kVertOffset = 2;
+static int const kCellInc = 4;
+MBReaderIface* ReadCCMIO::factory( MBInterface* iface )
+{ return new ReadCCMIO( iface ); }
+ReadCCMIO::ReadCCMIO(MBInterface* impl)
+    : mbImpl(impl)
+  assert(impl != NULL);
+  void* ptr = 0;
+  impl->query_interface( "MBReadUtilIface", &ptr );
+  readMeshIface = reinterpret_cast<MBReadUtilIface*>(ptr);
+  // initialize in case tag_get_handle fails below
+  mMaterialSetTag  = 0;
+  mDirichletSetTag = 0;
+  mNeumannSetTag   = 0;
+  mHasMidNodesTag  = 0;
+  mGlobalIdTag     = 0;
+  //! get and cache predefined tag handles
+  int dum_val = 0;
+  MBErrorCode result = impl->tag_get_handle(MATERIAL_SET_TAG_NAME,  mMaterialSetTag);
+  if (MB_TAG_NOT_FOUND == result)
+    result = impl->tag_create(MATERIAL_SET_TAG_NAME,
+                              sizeof(int),
+                              MB_TAG_SPARSE,
+                              MB_TYPE_INTEGER,
+                              mMaterialSetTag,
+                              &dum_val);
+  result = impl->tag_get_handle(DIRICHLET_SET_TAG_NAME, mDirichletSetTag);
+    result = impl->tag_create(DIRICHLET_SET_TAG_NAME,
+                              sizeof(int),
+                              MB_TAG_SPARSE,
+                              MB_TYPE_INTEGER,
+                              mDirichletSetTag,
+                              &dum_val);
+  result = impl->tag_get_handle(NEUMANN_SET_TAG_NAME,   mNeumannSetTag);
+    result = impl->tag_create(NEUMANN_SET_TAG_NAME,
+                              sizeof(int),
+                              MB_TAG_SPARSE,
+                              MB_TYPE_INTEGER,
+                              mNeumannSetTag,
+                              &dum_val);
+  result = impl->tag_get_handle(HAS_MID_NODES_TAG_NAME, mHasMidNodesTag);
+  if (MB_TAG_NOT_FOUND == result) {
+    int dum_val_array[] = {0, 0, 0, 0};
+    result = impl->tag_create(HAS_MID_NODES_TAG_NAME,
+                              4*sizeof(int),
+                              MB_TAG_SPARSE,
+                              MB_TYPE_INTEGER,
+                              mHasMidNodesTag,
+                              dum_val_array);
+  result = impl->tag_get_handle(GLOBAL_ID_TAG_NAME, mGlobalIdTag);
+    result = impl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
+                              MB_TYPE_INTEGER, mGlobalIdTag, &dum_val);
+ReadCCMIO::~ReadCCMIO()
+MBErrorCode ReadCCMIO::load_file(const char *file_name,
+                                 const MBEntityHandle* file_set,
+                                 const FileOptions& opts,
+                                 const MBReaderIface::IDTag* subset_list,
+                                 int subset_list_length,
+                                 const MBTag* file_id_tag)
+  CCMIOID rootID, problemID, stateID, processorID;
+  CCMIOError error = kCCMIONoErr;
+  CCMIOOpenFile(&error, file_name, kCCMIORead, &rootID);
+  if (kCCMIONoErr != error) {
+    readMeshIface->report_error("Problem opening file.");
+    return MB_FAILURE;
+    // get the file state
+  MBErrorCode rval = get_state(rootID, problemID, stateID);
+  if (MB_SUCCESS != rval) return MB_FAILURE;
+    // get processors
+  std::set<CCMIOSize_t> procs;
+  rval = get_processors(stateID, processorID, procs);
+  std::set<CCMIOSize_t>::iterator sit;
+  for (sit = procs.begin(); sit != procs.end(); sit++) {
+    rval = read_processor(stateID, processorID, *sit);
+  return rval;
+MBErrorCode ReadCCMIO::read_processor(CCMIOID stateID, CCMIOID processorID, CCMIOSize_t proc)
+  MBErrorCode rval;
+  bool has_solution = true;
+  CCMIOID verticesID, topologyID, solutionID;
+    // read the vertices, topology, and solution ids
+  proc = CCMIOSIZEC(0);
+  CCMIONextEntity(&error, stateID, kCCMIOProcessor, &proc, &processorID);
+  CCMIOReadProcessor(&error, processorID, &verticesID, &topologyID, NULL, &solutionID);
+  if(kCCMIONoErr != error) {
+      // might not be a solution; try reading just verts & topology
+    error = kCCMIONoErr;
+    CCMIOReadProcessor(&error, processorID, &verticesID, &topologyID, NULL, NULL);
+    if(kCCMIONoErr == error)
+        hasSolution = false;
+    else {
+      readMeshIface->report_error("Couldn't get vertices and topology.");
+  MBRange verts;
+    // vert_map fields: s: none, i: gid, ul: vert handle, r: none
+    //TupleList vert_map(0, 1, 1, 0, 0);
+  TupleList vert_map;
+  rval = read_vertices(proc, processorID, verticesID, topologyID,
+                       solutionID, has_solution, verts, vert_map);
+  if (MB_SUCCESS != rval) return rval;
+  rval = read_cells(proc, processorID, verticesID, topologyID,
+                    solutionID, has_solution, vert_map);
+  return rval;
+MBErrorCode ReadCCMIO::read_cells(CCMIOSize_t proc, CCMIOID processorID,
+                                  CCMIOID verticesID, CCMIOID topologyID,
+                                  CCMIOID solutionID, bool has_solution,
+                                  TupleList &vert_map)
+  CCMIOID cellsID, mapID;
+    // get the cells entity and number of cells
+  CCMIOSize_t num_cells;
+  CCMIOGetEntity(&error, topologyID, kCCMIOCells, 0, &cellsID);
+  CCMIOEntitySize(&error, cellsID, &num_cells, NULL);
+    // read the cell types and gid map
+  std::vector<int> cell_gids(GETINT32(num_cells)), cell_types(GETINT32(num_cells));
+  CCMIOReadCells(&error, cellsID, &mapID, NULL,
+                 CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
+    // this reads the cellids from the map.
+  CCMIOReadMap(&error, mapID, &cell_gids[0],
+    readMeshIface->report_error("Couldn't read cells or cell id map.");
+    // read the faces.
+    // face_map fields: s:forward/reverse, i: cell id, ul: face handle, r: none
+#ifdef TUPLE_LIST
+  TupleList face_map(1, 1, 1, 0, 0);
+#else
+  TupleList face_map;
+  SenseList sense_map;
+#endif
+  MBErrorCode rval = read_all_faces(topologyID, vert_map, face_map
+#ifndef TUPLE_LIST
+                                    , sense_map
+#endif
+    // now construct the cells; sort the face map by cell ids first
+#ifdef TUPLE_LIST
+  rval = face_map.sort(1);
+  if (MB_SUCCESS != rval) {
+    readMeshIface->report_error("Couldn't sort face map by cell id.");
+#endif
+  MBRange new_cells;
+  rval = construct_cells(face_map,
+#ifndef TUPLE_LIST
+                         sense_map,
+#endif
+                         vert_map, new_cells);
+  return MB_SUCCESS;
+MBErrorCode ReadCCMIO::construct_cells(TupleList &face_map,
+#ifndef TUPLE_LIST
+                                       SenseList &sense_map,
+#endif
+                                       TupleList &vert_map,
+                                       MBRange &new_cells)
+  std::vector<MBEntityHandle> facehs;
+  std::vector<int> senses;
+  MBEntityHandle cell;
+  MBErrorCode tmp_rval, rval = MB_SUCCESS;
+#ifdef TUPLE_LIST
+  unsigned int i = 0;
+  while (i < face_map.n) {
+      // pull out face handles bounding the same cell
+    facehs.clear();
+    int this_id = face_map.get_int(i);
+    unsigned int inext = i;
+    while (face_map.get_int(inext) == this_id && inext <= face_map.n) {
+      inext++;
+      MBEntityHandle face = face_map.get_ulong(inext);
+      facehs.push_back(face);
+      senses.push_back(face_map.get_short(inext));
+#else
+    std::map<int,std::vector<MBEntityHandle> >::iterator fmit;
+    std::map<int,std::vector<int> >::iterator smit;
+    for (fmit = face_map.begin(), smit = sense_map.begin();
+         fmit != face_map.end(); fmit++, smit++) {
+    facehs.clear();
+    int this_id = (*fmit).first;
+    facehs = (*fmit).second;
+    senses.clear();
+    senses = (*smit).second;
+#endif
+    tmp_rval = create_cell_from_faces(facehs, senses, cell);
+    if (MB_SUCCESS != tmp_rval) rval = tmp_rval;
+    else {
+      new_cells.insert(cell);
+        // tag cell with global id
+      tmp_rval = mbImpl->tag_set_data(mGlobalIdTag, &cell, 1, &this_id);
+MBErrorCode ReadCCMIO::create_cell_from_faces(std::vector<MBEntityHandle> &facehs,
+                                              std::vector<int> &senses,
+                                              MBEntityHandle &cell)
+    // test to see if they're one type
+  MBEntityType this_type = mbImpl->type_from_handle(facehs[0]);
+  bool same_type = true;
+  for (std::vector<MBEntityHandle>::iterator vit = facehs.begin(); vit != facehs.end(); vit++) {
+    if (this_type != mbImpl->type_from_handle(*vit)) {
+      same_type = false;
+      break;
+    // if different, we can quit here, we'll consider this a polyhedron
+  MBErrorCode rval = MB_SUCCESS;
+  if (!same_type ||
+      (MBTRI == this_type && facehs.size() != 4) ||
+      (MBQUAD == this_type && facehs.size() != 6) ||
+      (MBQUAD != this_type && MBTRI != this_type)) {
+    rval = mbImpl->create_element(MBPOLYHEDRON, &facehs[0], facehs.size(), cell);
+      readMeshIface->report_error("Couldn't make polyhedron.");
+    else return MB_SUCCESS;
+    // try tet and hex elements; get connectivity of first face
+  std::vector<MBEntityHandle> verts;
+  rval = mbImpl->get_connectivity(&facehs[0], 1, verts);
+  bool match = false;
+    readMeshIface->report_error("Couldn't get connectivity.");
+    // reverse connectivity if sense is forward, since base face always points
+    // into entity
+  if (senses[0] > 0) std::reverse(verts.begin(), verts.end());
+  std::vector<MBEntityHandle> storage;
+  MeshTopoUtil mtu(mbImpl);
+  if (MBTRI == this_type) {
+      // get the 4th vertex through the next tri
+    const MBEntityHandle *conn; int conn_size;
+    rval = mbImpl->get_connectivity(facehs[1], conn, conn_size, true, &storage);
+    int i = 0;
+    while (std::find(verts.begin(), verts.end(), conn[i]) != verts.end() && i < conn_size) i++;
+    if (conn_size == i) return MB_FAILURE;
+    match = true;
+    this_type = MBTET;
+  else if (MBQUAD == this_type) {
+      // build hex from quads
+      // algorithm:
+      // - verts = vertices from 1st quad
+      // - find quad q1 sharing verts[0] and verts[1]
+      // - find quad q2 sharing other 2 verts in q1
+      // - find v1 = opposite vert from verts[1] in q1 , v2 = opposite from verts[0]
+      // - get i = offset of v1 in verts2 of q2, rotate verts2 by i
+      // - if verts2[i+1%4] != v2, flip verts2 by switching verts2[1] and verts2[3]
+      // - append verts2 to verts
+      // get the other vertices for this hex; need to find the quad with no common vertices
+    MBRange tmp_faces, tmp_verts;
+      // get q1, which shares 2 vertices with q0
+    std::copy(facehs.begin(), facehs.end(), mb_range_inserter(tmp_faces));
+    rval = mbImpl->get_adjacencies(&verts[0], 2, 2, false, tmp_faces);
+    if (MB_SUCCESS != rval || tmp_faces.size() != 2) {
+      readMeshIface->report_error("Couldn't get adj face.");
+    tmp_faces.erase(facehs[0]);
+    MBEntityHandle q1 = *tmp_faces.begin();
+      // get other 2 verts of q1
+    rval = mbImpl->get_connectivity(&q1, 1, tmp_verts);
+      readMeshIface->report_error("Couldn't get adj verts.");
+    tmp_verts.erase(verts[0]); tmp_verts.erase(verts[1]);
+      // get q2
+    rval = mbImpl->get_adjacencies(tmp_verts, 2, false, tmp_faces);
+    tmp_faces.erase(q1);
+    MBEntityHandle q2 = *tmp_faces.begin();
+      // get verts in q2
+    rval = mbImpl->get_connectivity(&q2, 1, storage);
+      readMeshIface->report_error("Couldn't get adj vertices.");
+      // get verts in q1 opposite from v[1] and v[0] in q0
+    MBEntityHandle v0 = 0, v1 = 0;
+    rval = mtu.opposite_entity(q1, verts[1], v0);
+    rval = mtu.opposite_entity(q1, verts[0], v1);
+    if (!v0 || !v1) {
+      readMeshIface->report_error("Trouble finding opposite vertices.");
+      // offset of v0 in q2, then rotate and flip
+    unsigned int ioff = std::find(storage.begin(), storage.end(), v0) - storage.begin();
+    if (4 == ioff) {
+      readMeshIface->report_error("Trouble finding offset.");
+    if (storage[(ioff+1)%4] != v1) {
+      std::reverse(storage.begin(), storage.end());
+      ioff = std::find(storage.begin(), storage.end(), v0) - storage.begin();
+    if (0 != ioff)
+      std::rotate(storage.begin(), storage.begin()+ioff, storage.end());
+      // copy into verts, and make hex
+    std::copy(storage.begin(), storage.end(), std::back_inserter(verts));
+    match = true;
+    this_type = MBHEX;
+  if (!match) return MB_FAILURE;
+          // now make the element
+  rval = mbImpl->create_element(this_type, &verts[0], verts.size(), cell);
+    readMeshIface->report_error("create_element failed.");
+MBErrorCode ReadCCMIO::read_all_faces(CCMIOID topologyID, TupleList &vert_map,
+                                      TupleList &face_map
+#ifndef TUPLE_LIST
+                                      ,SenseList &sense_map
+#endif
+  CCMIOSize_t index = CCMIOSIZEC(0);
+  CCMIOID faceID;
+  MBErrorCode rval;
+    // get total # internal/bdy faces, size the face map accordingly
+  int nint_faces = 0, nbdy_faces = 0;
+  CCMIOSize_t nf;
+  while (kCCMIONoErr == CCMIONextEntity(NULL, topologyID, kCCMIOBoundaryFaces, &index,
+                                        &faceID))
+    CCMIOEntitySize(&error, faceID, &nf, NULL);
+    nbdy_faces = nbdy_faces + nf;
+  CCMIOGetEntity(&error, topologyID, kCCMIOInternalFaces, 0, &faceID);
+  nint_faces = nint_faces + nf;
+#ifdef TUPLE_LIST
+  face_map.resize(2*nint_faces + nbdy_faces);
+#endif
+    // get multiple blocks of bdy faces
+  index = CCMIOSIZEC(0);
+                                        &faceID))
+    rval = read_faces(faceID, kCCMIOBoundaryFaces, vert_map, face_map
+#ifndef TUPLE_LIST
+                      , sense_map
+#endif
+      readMeshIface->report_error("Trouble reading boundary faces.");
+    // now get internal faces
+  rval = read_faces(faceID, kCCMIOInternalFaces, vert_map,face_map
+#ifndef TUPLE_LIST
+                    , sense_map
+#endif
+    readMeshIface->report_error("Trouble reading internal faces.");
+  return rval;
+MBErrorCode ReadCCMIO::read_faces(CCMIOID faceID, CCMIOEntity bdy_or_int,
+#ifndef TUPLE_LIST
+#endif
+  if (kCCMIOInternalFaces != bdy_or_int && kCCMIOBoundaryFaces != bdy_or_int) {
+    readMeshIface->report_error("Face type isn't boundary or internal.");
+  CCMIOSize_t num_faces;
+  CCMIOEntitySize(&error, faceID, &num_faces, NULL);
+    // get the size of the face connectivity array (not really a straight connect
+    // array, has n, connect(n), ...)
+  CCMIOSize_t farray_size = CCMIOSIZEC(0);
+  CCMIOReadFaces(&error, faceID, bdy_or_int, NULL, &farray_size, NULL,
+    readMeshIface->report_error("Trouble reading face connectivity length.");
+    // allocate vectors for holding farray and cells for each face; use new for finer
+    // control of de-allocation
+  int num_sides = (kCCMIOInternalFaces == bdy_or_int ? 2 : 1);
+  int *farray = new int[GETINT32(farray_size)];
+    // read farray and make the faces
+  CCMIOID mapID;
+  CCMIOReadFaces(&error, faceID, bdy_or_int, &mapID, NULL,
+                 farray, CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
+    readMeshIface->report_error("Trouble reading face connectivity.");
+  std::vector<MBEntityHandle> face_handles(GETINT32(num_faces), 0);
+  MBErrorCode rval = make_faces(farray, vert_map, face_handles);
+    // read face cells and make tuples
+  int *face_cells;
+  if (num_sides*num_faces < farray_size) face_cells = new int[num_sides*GETINT32(num_faces)];
+  else face_cells = farray;
+  CCMIOReadFaceCells(&error, faceID, bdy_or_int, face_cells,
+    readMeshIface->report_error("Trouble reading face cells.");
+  int *tmp_ptr = face_cells;
+  for (int i = 0; i < num_faces; i++) {
+#ifdef TUPLE_LIST
+    short forward = 1, reverse = -1;
+    face_map.push_back(&forward, tmp_ptr++, &face_handles[i], NULL);
+    if (2 == num_sides)
+      face_map.push_back(&reverse, tmp_ptr++, &face_handles[i], NULL);
+#else
+    face_map[*tmp_ptr].push_back(face_handles[i]);
+    sense_map[*tmp_ptr++].push_back(1);
+    if (2 == num_sides) {
+      sense_map[*tmp_ptr++].push_back(-1);
+#endif
+    // now read & set face gids, reuse face_cells 'cuz we know it's big enough
+  CCMIOReadMap(&error, mapID, face_cells, CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
+    readMeshIface->report_error("Trouble reading face gids.");
+  rval = mbImpl->tag_set_data(mGlobalIdTag, &face_handles[0], face_handles.size(), face_cells);
+    readMeshIface->report_error("Couldn't set face global ids.");
+MBErrorCode ReadCCMIO::make_faces(int *farray,
+                                  std::vector<MBEntityHandle> &new_faces)
+  unsigned int num_faces = new_faces.size();
+  MBErrorCode tmp_rval = MB_SUCCESS, rval = MB_SUCCESS;
+  for (unsigned int i = 0; i < num_faces; i++) {
+    int num_verts = *farray++;
+    verts.resize(num_verts);
+      // fill in connectivity by looking up by gid in vert tuple_list
+    for (int j = 0; j < num_verts; j++) {
+#ifdef TUPLE_LIST
+      int tindex = vert_map.find(1, farray[j]);
+      if (-1 == tindex) {
+        tmp_rval = MB_FAILURE;
+        break;
+      verts[j] = vert_map.get_ulong(tindex, 0);
+#else
+      verts[j] = (vert_map[farray[j]])[0];
+#endif
+    farray += num_verts;
+    if (MB_SUCCESS == tmp_rval) {
+        // make face
+      MBEntityType ftype = (3 == num_verts ? MBTRI :
+                            (4 == num_verts ? MBQUAD : MBPOLYGON));
+      MBEntityHandle faceh;
+      tmp_rval = mbImpl->create_element(ftype, &verts[0], num_verts, faceh);
+      if (faceh) new_faces[i] = faceh;
+  return rval;
+MBErrorCode ReadCCMIO::read_vertices(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID,
+                                     CCMIOID topologyID, CCMIOID solutionID, bool has_solution,
+                                     MBRange &verts, TupleList &vert_map)
+    // pre-read the number of vertices, so we can pre-allocate & read directly in
+  CCMIOSize_t nverts = CCMIOSIZEC(0);
+  CCMIOEntitySize(&error, verticesID, &nverts, NULL);
+    readMeshIface->report_error("Couldn't get number of vertices.");
+    // get # dimensions
+  CCMIOSize_t dims;
+  float scale;
+  CCMIOReadVerticesf(&error, verticesID, &dims, NULL, NULL, NULL, CCMIOINDEXC(0), CCMIOINDEXC(1));
+    readMeshIface->report_error("Couldn't get number of dimensions.");
+    // allocate vertex space
+  MBEntityHandle node_handle = 0;
+  std::vector<double*> arrays;
+  readMeshIface->get_node_arrays(3, GETINT32(nverts), MB_START_ID, node_handle, arrays);
+    // read vertex coords
+  CCMIOID mapID;
+  std::vector<double> tmp_coords(GETINT32(dims)*GETINT32(nverts));
+  CCMIOReadVerticesd(&error, verticesID, &dims, &scale, &mapID, &tmp_coords[0],
+                     CCMIOINDEXC(0), CCMIOINDEXC(0+nverts));
+    readMeshIface->report_error("Trouble reading vertex coordinates.");
+    // copy interleaved coords into moab blocked coordinate space
+  int i = 0, threei = 0;
+  for (; i < nverts; i++) {
+    arrays[0][i] = tmp_coords[threei++];
+    arrays[1][i] = tmp_coords[threei++];
+    if (3 == GETINT32(dims)) arrays[2][i] = tmp_coords[threei++];
+    else arrays[2][i] = 0.0;
+    // scale, if necessary
+  if (1.0 != scale) {
+    for(i = 0; i < nverts; i++) {
+      arrays[0][i] *= scale;
+      arrays[1][i] *= scale;
+      if (3 == GETINT32(dims)) arrays[2][i] *= scale;
+    // put new vertex handles into range
+  verts.insert(node_handle, node_handle+nverts);
+    // pack vert_map with global ids and handles for these vertices
+  std::vector<int> gids(GETINT32(nverts));
+  CCMIOReadMap(&error, mapID, &gids[0], CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
+    readMeshIface->report_error("Trouble reading vertex global ids.");
+#ifdef TUPLE_LIST
+  vert_map.resize(GETINT32(nverts));
+  for (i = 0; i < GETINT32(nverts); i++) {
+    vert_map.push_back(NULL, &gids[i], &node_handle, NULL);
+#else
+    (vert_map[gids[i]]).push_back(node_handle);
+#endif
+    node_handle += 1;
+MBErrorCode ReadCCMIO::get_processors(CCMIOID stateID, CCMIOID &processorID,
+                                      std::set<CCMIOSize_t> &procs)
+  CCMIOSize_t proc = CCMIOSIZEC(0);
+         CCMIONextEntity(NULL, stateID, kCCMIOProcessor, &proc, &processorID))
+    procs.insert(proc);
+MBErrorCode ReadCCMIO::get_state(CCMIOID rootID, CCMIOID &problemID, CCMIOID &stateID)
+    // first try default
+  CCMIOGetState(&error, rootID, "default", &problemID, &stateID);
+    CCMIOSize_t i = CCMIOSIZEC(0);
+    CCMIOError tmp_error = kCCMIONoErr;
+    CCMIONextEntity(&tmp_error, rootID, kCCMIOState, &i, &stateID);
+    if (kCCMIONoErr ==  tmp_error)
+      CCMIONextEntity(&error, rootID, kCCMIOProblemDescription,
+                      &i, &problemID);
+    readMeshIface->report_error("Couldn't find state.");
+MBErrorCode ReadCCMIO::read_tag_values( const char* file_name,
+                                        const char* tag_name,
+                                        std::vector<int>& tag_values_out,
+                                        const IDTag* subset_list,
+                                        int subset_list_length)
+// Method: avtCCMFileFormat::GetIDsForDomain
+// Purpose:
+//   Gets nodes for state, processor, vertices, topology and solution that can
+//   be used to query attributes for variables and meshes.
+// Arguments:
+// Returns:
+// Note:
+// Programmer: Brad Whitlock
+// Creation:   Mon Aug 6 09:10:29 PDT 2007
+// Modifications:
+bool
+avtCCMFileFormat::GetIDsForDomain(int dom,
+    CCMIOID &processor, CCMIOID &vertices, CCMIOID &topology,
+    CCMIOID &solution, bool &hasSolution)
+    const char *mName = "avtCCMFileFormat::GetIDsForDomain: ";
+    // Try and get the requested processor.
+    int proc = dom;
+    bool ret = (
+        CCMIONextEntity(NULL, GetState(), kCCMIOProcessor, &proc, &processor) ==
+        kCCMIONoErr);
+    if(ret)
+        hasSolution = true;
+        ccmErr = kCCMIONoErr;
+        // Try and read the vertices, topology, and solution ids for this
+        // processor.
+        CCMIOReadProcessor(&ccmErr, processor, &vertices, &topology, NULL,
+                           &solution);
+        if(ccmErr != kCCMIONoErr)
+            // That didn't work. (Maybe no solution). See if we can at least
+            // get the vertices and processor.
+                               NULL);
+            if(ccmErr == kCCMIONoErr)
+            else
+                ret = false;
+    return ret;
+//  Method: avtCCMFileFormat::GetFaces
+//  Purpose: Reads the face info.
+//  Arguments:
+//    faceID        The ID of the face entity.
+//    faceType      The type of faces (internal or boundary).
+//    nFaces        How many faces are in the entity.
+//    cellIDMap     Used to map cell IDs to indices
+//    vertexIDMap   Used to map vertex IDs to indices
+//    minSize       Min num verts in a face
+//    maxSize       Max num verts in a face
+//    ci            A place to store the face info, must be allocated by
+//                  calling method.
+//  Programmer: Kathleen Bonnell
+//  Creation:   September 5, 2007
+//  Modifications:
+//    Kathleen Bonnell, Thu Mar  6 09:21:02 PST 2008
+//    Removed unused variable.
+//    Dave Bremer, Fri Apr  4 16:29:49 PDT 2008
+//    Fixed a bug in which cell and vertex ids were mistaken for 1-based
+//    indices.
+void
+avtCCMFileFormat::GetFaces(CCMIOID faceID, CCMIOEntity faceType,
+                           unsigned int nFaces, const IDMap &cellIDMap,
+                           const IDMap &vertexIDMap,
+                           int &minSize, int &maxSize, CellInfoVector &ci)
+    if (faceType != kCCMIOInternalFaces && faceType != kCCMIOBoundaryFaces)
+        debug1 << "avtCCMFileFormat::GetFaces encountered an internal error"
+                << endl;
+        return;
+    int getFacesTimer = visitTimer->StartTimer();
+    CCMIOID mapID;
+    unsigned int nCells = 0, size = 0;
+    //intVector faces;
+    intVector faceNodes, faceCells;
+    // Determine the size of the faceNodes array, which is of the
+    // form n1, v1, v2, ...vn1, n2, v1, v2, ... vn2, )
+    CCMIOReadFaces(&ccmErr, faceID, faceType, NULL, &size, NULL,
+                   kCCMIOStart, kCCMIOEnd);
+    faceNodes.resize(size);
+    //faces.resize(nFaces);
+    if (faceType == kCCMIOInternalFaces)
+        faceCells.resize(nFaces*2);
+    else
+        faceCells.resize(nFaces);
+    CCMIOReadFaces(&ccmErr, faceID, faceType, &mapID, NULL,
+                   &faceNodes[0], kCCMIOStart, kCCMIOEnd);
+    CCMIOReadFaceCells(&ccmErr, faceID, faceType, &faceCells[0],
+    //CCMIOReadMap(&ccmErr, mapID, &faces[0], kCCMIOStart, kCCMIOEnd);
+    unsigned int pos = 0;
+    for (unsigned int i = 0; i < nFaces; ++i)
+        FaceInfo newFace;
+        //newFace.id = faces[i];
+            newFace.cells[0] = faceCells[i*2];
+            newFace.cells[1] = faceCells[i*2+1];
+        else
+            newFace.cells[0] = faceCells[i];
+        int nVerts = faceNodes[pos];
+        if (nVerts < minSize)
+            minSize = nVerts;
+        if (nVerts > maxSize)
+            maxSize = nVerts;
+        for (unsigned int j = 0; j < nVerts; ++j)
+            newFace.nodes.push_back( vertexIDMap.IDtoIndex(faceNodes[pos+1+j]) );
+        // cell ids are 1-origin, so must subract 1 to get the
+        // correct index into the CellInfoVector
+            int  c0 = cellIDMap.IDtoIndex(newFace.cells[0]);
+            int  c1 = cellIDMap.IDtoIndex(newFace.cells[1]);
+            ci[c0].faceTypes.push_back(1);
+            ci[c0].faces.push_back(newFace);
+            ci[c1].faceTypes.push_back(2);
+            ci[c1].faces.push_back(newFace);
+        else
+            ci[c0].faceTypes.push_back(0);
+        pos += faceNodes[pos] +1;
+    visitTimer->StopTimer(getFacesTimer, "GetFaces");
+//  Method: avtCCMFileFormat::PopulateDatabaseMetaData
+//  Purpose:
+//      This database meta-data object is like a table of contents for the
+//      file.  By populating it, you are telling the rest of VisIt what
+//      information it can request from you.
+//  Creation:   Thu Aug 2 15:01:17 PST 2007
+//  Modifications:
+//    Kathleen Bonnell, Thu Feb 28 15:00:24 PST 2008
+//    Fixed determination of centering for Vector variables.  Added code to
+//    determine if any variables are defined only on parts of the mesh, by
+//    reading the number of cells, then mapData size for each var.
+void
+avtCCMFileFormat::PopulateDatabaseMetaData(avtDatabaseMetaData *md)
+    const char *mName = "avtCCMFileFormat::PopulateDatabaseMetaData: ";
+    // Count the number of processors in the file.
+    // Use that for the number of domains.
+    CCMIOID processor;
+    int proc = 0;
+    int nblocks = 0;
+    while (CCMIONextEntity(NULL, GetState(), kCCMIOProcessor, &proc,
+           &processor) == kCCMIONoErr)
+        ++nblocks;
+    debug4 << mName << "Found " << nblocks << " domains in the file." << endl;
+#if 0
+    // this will be useful for subsetting by the cell type
+    int nCellTypes = 0;
+    if (CCMIOIsValidEntity(ccmProblem))
+        // Determine the number of kCCMIOCellTypes present.
+        int i = 0;
+        CCMIOID next;
+        while(CCMIONextEntity(NULL, ccmProblem, kCCMIOCellType, &i, &next)
+              == kCCMIONoErr)
+        ++nCellTypes;
+#endif
+#if 0
+    // Read the simulation title.
+    char *title = NULL;
+    ccmErr = CCMIOGetTitle(&ccmErr, GetRoot(), &title);
+    if(title != NULL)
+        md->SetDatabaseComment(title);
+        free(title);
+#endif
+    for (unsigned int i = 0; i < nblocks; ++i)
+        originalCells.push_back(NULL);
+    // Determine the spatial dimensions.
+    int dims = 3;
+    CCMIOID vertices, topology, solution;
+    bool hasSolution = true;
+    if(GetIDsForDomain(0, processor, vertices, topology, solution,
+                       hasSolution))
+        dims = 1 ;
+        CCMIOReadVerticesf(&ccmErr, vertices, &dims, NULL, NULL, NULL, 0, 1);
+    else
+        EXCEPTION1(InvalidFilesException, filenames[0]);
+    // If there's just 1 block, read the mesh now and decompose it into
+    // more meshes, caching them for later.
+    int nDomains = nblocks;
+#ifdef ENABLE_SUBDIVISION
+    if(nblocks == 1)
+        subdividingSingleMesh = true;
+        md->SetFormatCanDoDomainDecomposition(true);
+#endif
+    // Create a mesh.
+    avtMeshMetaData *mmd = new avtMeshMetaData;
+    mmd->name = "Mesh";
+    mmd->spatialDimension = dims;
+    mmd->topologicalDimension = dims;
+    mmd->meshType = AVT_UNSTRUCTURED_MESH;
+    mmd->numBlocks = nDomains;
+    mmd->cellOrigin = 1;
+    mmd->nodeOrigin = 1;
+    md->Add(mmd);
+    // Find variable data
+    if (hasSolution)
+        // Determine number of cells, in order to find out
+        // which variables are NOT defined on entire mesh.
+        CCMIOError err = kCCMIONoErr;
+        CCMIOID cellsID;
+        CCMIOSize nCells;
+        CCMIOGetEntity(&err, topology, kCCMIOCells, 0, &cellsID);
+        CCMIOEntitySize(&err, cellsID, &nCells, NULL);
+        debug5 << mName << "Reading variable information" << endl;
+        CCMIOID field, phase = solution;
+        int h = 0;
+        int i = 0;
+        bool oldFile = CCMIONextEntity(NULL, solution, kCCMIOFieldPhase,
+                                       &h, &phase) != kCCMIONoErr;
+        h = 0;
+        while(oldFile ||
+              CCMIONextEntity(NULL, solution, kCCMIOFieldPhase, &h, &phase) ==
+        kCCMIONoErr)
+            debug5 << mName << "CCMIONextEntity for solution " << solution
+                   << " returned h=" << h << ", phase = " << phase << endl;
+            if (oldFile)
+                phase = solution;
+            else
+                int phaseNum = 0;
+                CCMIOGetEntityIndex(NULL, phase, &phaseNum);
+            // This i needs to be set to 0 here because we're asking for the
+            // first field from the current phase. Since we're iterating
+            // over phases so far, we need to reset i to 0 here to get the
+            // first field.
+            while(CCMIONextEntity(NULL, phase, kCCMIOField, &i, &field) ==
+                  kCCMIONoErr)
+                char name[kCCMIOMaxStringLength+1];
+                char sName[kCCMIOProstarShortNameLength+1];
+                char *units = NULL;
+                int usize;
+                CCMIODataType datatype;
+                CCMIODimensionality cdims;
+                CCMIOID fieldData, mapID;
+                CCMIODataLocation type;
+                CCMIOID varField = field;
+                debug5 << mName << "CCMIONextEntity for phase " << phase
+                       << " returned i=" << i << ", field = " << field << endl;
+                // Get the field's name, dims, and data type.
+                CCMIOReadField(&ccmErr, field, name, sName, &cdims, &datatype);
+                debug5 << mName << "CCMIOReadField for field " << field
+                       << " returned name=" << name << ", sName = "
+                       << sName << endl;
+                if (cdims == kCCMIOVector)
+                    CCMIOID scalar;
+                    CCMIOReadMultiDimensionalFieldData(&err, field,
+                                             kCCMIOVectorX, &scalar);
+                    if (err == kCCMIONoErr)
+                        // componentized vector, use the X component scalar
+                        // in order to retrieve more info about the vector
+                        field = scalar;
+                char *usename;
+                if (oldFile)
+                    usename = name;
+                else
+                    usename = sName;
+                // Read the field's units
+                if (CCMIOReadOptstr(NULL, field, "Units", &usize, NULL) ==
+                    kCCMIONoErr)
+                    units = new char[usize+1];
+                    CCMIOReadOptstr(&ccmErr, field, "Units", NULL, units);
+                // Reset j to 0 to get the first field data. We read the
+                // field data to determine the variable centering.
+                int j = 0;
+                avtCentering centering = AVT_UNKNOWN_CENT;
+                CCMIOSize cellVarSize = 0;
+                while (CCMIONextEntity(NULL, field, kCCMIOFieldData,
+                       &j, &fieldData) == kCCMIONoErr)
+                    debug5 << mName << "CCMIONextEntity for field " << field
+                           << " returned kCCMIONoErr, j=" << j
+                           << ",fieldData=" << fieldData << endl;
+                    // Read information about the field.
+                    CCMIOReadFieldDataf(&ccmErr, fieldData, &mapID, &type,
+                                        NULL, kCCMIOStart, kCCMIOEnd);
+                        debug5 << mName << "CCMIOReadFieldDataf failed."
+                               << endl;
+                        continue;
+                    // Determine the variable centering.
+                    if (type == kCCMIOVertex)
+                        centering = AVT_NODECENT;
+                        debug4 << "Var " << usename << " is node centered"
+                               << endl;
+                    else if (type == kCCMIOCell)
+                        centering = AVT_ZONECENT;
+                        debug4 << "Var " << usename << " is zone centered"
+                               << endl;
+                        CCMIOSize n;
+                        CCMIOIndex max;
+                        CCMIOEntitySize(&ccmErr, fieldData, &n, &max);
+                        cellVarSize += n;
+                    else if (type == kCCMIOFace)
+                        debug4 << "Var " << usename << " is face-centered, "
+                               << "ignoring for now. " << endl;
+                if (cellVarSize != nCells)
+                    varsOnSubmesh.push_back(usename);
+                // If we don't have metadata for the variable yet, add it.
+                if(varsToFields.find(usename) == varsToFields.end())
+                    // Variables with an unsupported centering are tagged
+                    // invalid.
+                    bool validVariable = (centering != AVT_UNKNOWN_CENT);
+                    if(cdims==kCCMIOScalar)
+                        avtScalarMetaData *smd = new avtScalarMetaData(usename,
+                            "Mesh", centering);
+                        if (units != NULL)
+                            smd->hasUnits = true;
+                            smd->units = units;
+                        smd->validVariable = validVariable;
+                        md->Add(smd);
+                        varsToFields[usename] = varField;
+                    else if(cdims==kCCMIOVector)
+                        avtVectorMetaData *vmd = new avtVectorMetaData(usename,
+                            "Mesh", centering, 3);
+                            vmd->hasUnits = true;
+                            vmd->units = units;
+                        vmd->validVariable = validVariable;
+                        md->Add(vmd);
+                    else if(cdims==kCCMIOTensor)
+                        avtTensorMetaData *tmd = new avtTensorMetaData(usename,
+                            "Mesh", centering, 9);
+                            tmd->hasUnits = true;
+                            tmd->units = units;
+#if 1
+                        // Just make tensor vars display for now.
+                        // Don't plot them.
+                        tmd->validVariable = false;
+#else
+                        tmd->validVariable = validVariable;
+#endif
+                        md->Add(tmd);
+                    delete [] units;
+                    units = NULL;
+            oldFile = false;
+//  Method: avtCCMFileFormat::GetMesh
+//  Purpose:
+//      Gets the mesh associated with this file.  The mesh is returned as a
+//      derived type of vtkDataSet (ie vtkRectilinearGrid, vtkStructuredGrid,
+//      vtkUnstructuredGrid, etc).
+//  Arguments:
+//      domain      The index of the domain.  If there are NDomains, this
+//                  value is guaranteed to be between 0 and NDomains-1,
+//                  regardless of block origin.
+//      meshname    The name of the mesh of interest.  This can be ignored if
+//                  there is only one mesh.
+//  Modifications:
+//    Brad Whitlock, Tue Dec 18 12:57:28 PST 2007
+//    Added support for 2D polygonal shapes.
+//    If the primary variable (activeVisItVar) is defined only on a portion of
+//    the mesh, only retrieve (and tesselate) those cells it is defined upon.
+//    indices.
+//    Brad Whitlock, Thu Oct  1 13:36:48 PDT 2009
+//    I refactored this routine into helper routines and added support for
+//    automatically subdividing a mesh on the fly.
+#ifndef MDSERVER
+#include <PolygonToTriangles.C>
+#endif
+vtkDataSet *
+avtCCMFileFormat::GetMesh(int domain, const char *meshname)
+#ifdef MDSERVER
+    return 0;
+#else
+    // Override domain if we're automatically dividing the data
+    int dom = subdividingSingleMesh ? 0 : domain;
+    vtkUnstructuredGrid *ugrid = NULL;
+    vtkPoints *points = NULL;
+    TRY
+        // Read the points
+        points = ReadPoints(dom, meshname);
+        // Read the cell connectivity
+        CellInfoVector cellInfo;
+        int minFaceSize = VTK_LARGE_INTEGER;
+        int maxFaceSize = -1;
+        ReadCellInfo(dom, meshname,
+                     cellInfo, minFaceSize, maxFaceSize);
+        // Convert cellInfo into vtkUnstructuredGrid
+        SelectCellsForThisProcessor(cellInfo, points);
+        ugrid = vtkUnstructuredGrid::New();
+        // Determine cell topology from face lists
+        if (minFaceSize == 2 && maxFaceSize == 2)
+            // 2D edges that we must assemble into polygons and tessellate into
+            // triangles that VisIt can digest.
+            TesselateCells2D(domain, cellInfo, points, ugrid);
+        else if (minFaceSize <= 4 && maxFaceSize <= 4)
+            // If we're subdividing a single domain on the fly then we create
+            // original cell numbers so we can use them in the GetVar method
+            // to return only the cell values that we selected for this chunk
+            // of the mesh.
+            unsigned int oc[2] = {dom, 0};
+            vtkUnsignedIntArray *origCells = 0;
+            if(subdividingSingleMesh)
+                int useCount = 0;
+                for(unsigned int i = 0; i < cellInfo.size(); ++i)
+                    useCount += (cellInfo[i].id != -1) ? 1 : 0;
+                origCells = vtkUnsignedIntArray::New();
+                origCells->SetName("avtOriginalCellNumbers");
+                origCells->SetNumberOfComponents(2);
+                origCells->Allocate(useCount * 3);
+                originalCells[dom] = origCells;
+#endif
+            ugrid->SetPoints(points);
+            // We have zoo elements that we can deal with.
+            vtkCellArray *cellArray = vtkCellArray::New();
+            intVector cellTypes;
+            bool unhandledCellType = false;
+            for (unsigned int i = 0; i < cellInfo.size(); i++)
+                const CellInfo &ci = cellInfo[i];
+                if(ci.id == -1)
+                    continue;
+                oc[1] = ci.id;
+#endif
+                switch(ci.faces.size())
+                    case 4 :
+                        BuildTet(ci, cellArray, cellTypes);
+                            origCells->InsertNextTupleValue(oc);
+#endif
+                        break;
+                    case 5 :
+                        int nNodes = 0;
+                        for (size_t j = 0; j < ci.faces.size(); j++)
+                            nNodes += ci.faces[j].nodes.size();
+                        if (nNodes == 16) // Pyramid
+                            BuildPyramid(ci, cellArray, cellTypes);
+#endif
+                        else if (nNodes == 18) // Wedge
+                            BuildWedge(ci, cellArray, cellTypes);
+#endif
+                        else
+                            unhandledCellType = true;
+                        break;
+                    case 6 :
+                        BuildHex(ci, cellArray, cellTypes);
+#endif
+                        break;
+                    default :
+                        break;
+            ugrid->SetCells(&cellTypes[0], cellArray);
+            cellArray->Delete();
+        else
+            TesselateCell(domain, cellInfo, points, ugrid);
+        points->Delete();
+    CATCHALL
+        if(points != NULL)
+            points->Delete();
+        if(ugrid != NULL)
+            ugrid->Delete();
+    ENDTRY
+    return ugrid;
+#endif
+// Method: avtCCMFileFormat::ReadPoints
+// Purpose:
+//   Reads the points associated with a specified domain/mesh.
+// Arguments:
+//   dom         : The domain number.
+//   meshname    : The name of the mesh.(for error reporting)
+// Returns:    The vtkPoints object that contains the points.
+// Note:       This method was broken out from the original GetMesh routine.
+// Programmer: Kathleen Bonnell, Brad Whitlock
+// Creation:   Thu Oct  1 13:29:03 PDT 2009
+// Modifications:
+vtkPoints *
+avtCCMFileFormat::ReadPoints(int dom, const char *meshname)
+    CCMIOID processor, vertices, topology, solution;
+    if(!GetIDsForDomain(dom, processor, vertices, topology, solution,
+                        hasSolution))
+        EXCEPTION1(InvalidVariableException, meshname);
+    // Read the size of the vertices
+    CCMIOSize nnodes = 0;
+    CCMIOEntitySize(&ccmErr, vertices, &nnodes, NULL);
+        debug4 << "CCMIOEntitySize for vertices failed with error " ;
+        debug4 << ccmErr << endl;
+    // Read the dimensions of the vertex.
+    int dims = 1;
+    float scale;
+        debug4 << "CCMIOReadVertices for first vertex dimensions ";
+        debug4 << "failed with error " << ccmErr << endl;
+    // Allocate VTK memory.
+    vtkPoints *points = vtkPoints::New();
+    points->SetNumberOfPoints(nnodes);
+    float *pts = (float *)points->GetVoidPointer(0);
+    // Read the data into the VTK points.
+    CCMIOID mapID;
+    if(dims == 2)
+        // Read 2D points and convert to 3D, storing into VTK.
+        float *pts2d = new float[2 * nnodes];
+        CCMIOReadVerticesf(&ccmErr, vertices, &dims, &scale, &mapID, pts2d,
+                   0, nnodes);
+        float *src = pts2d;
+        float *dest = pts;
+        for(int i = 0; i < nnodes; ++i)
+            *dest++ = *src++;
+            *dest++ = *src++;
+            *dest++ = 0.;
+        delete [] pts2d;
+    else
+        // Read the data directly into the VTK buffer.
+        CCMIOReadVerticesf(&ccmErr, vertices, &dims, &scale, &mapID, pts,
+                   0, nnodes);
+    // Scale the points, according to the scale factor read with the
+    // vertices.
+        pts[0] *= scale;
+        pts[1] *= scale;
+        pts[2] *= scale;
+        pts += 3;
+    return points;
+// Method: avtCCMFileFormat::ReadCellInfo
+// Purpose:
+//   Reads the cell info associated with a specified domain/mesh.
+// Arguments:
+//   cellInfo    : The cell information to populate.
+//   minFaceSize : Return value of the min face size.
+//   maxFaceSize : Return value of the max face size.
+// Returns:
+//             min/maxFaceSize are used to determine whether tesselation is
+//             required.
+// Modifications:
+void
+avtCCMFileFormat::ReadCellInfo(int dom, const char *meshname,
+    CellInfoVector &cellInfo, int &minFaceSize, int &maxFaceSize)
+                       hasSolution))
+    // Read the dimensions of the vertex and get the mapID
+    int dims = 1;
+    CCMIOID mapID;
+    CCMIOReadVerticesf(&ccmErr, vertices, &dims, NULL, &mapID, NULL, 0, 1);
+    // Read the vertex ids
+    intVector tmpVertexMap(nnodes);
+    CCMIOReadMap(&ccmErr, mapID, &tmpVertexMap[0], kCCMIOStart, kCCMIOEnd);
+    IDMap  vertexIDMap;
+    vertexIDMap.SetIDs(tmpVertexMap);
+    tmpVertexMap.clear();
+    // Get the topology information
+    CCMIOID faceID, cellsID;
+    unsigned int nIFaces = 0, nCells = 0, size = 0;
+    intVector cells;
+    //intVector cellMatType;
+    // Read the cells entity
+    CCMIOGetEntity(&ccmErr, topology, kCCMIOCells, 0, &cellsID);
+    // Read the cells entity size (num cells)
+    CCMIOEntitySize(&ccmErr, cellsID, &nCells, NULL);
+    cells.resize(nCells);
+    cellInfo.resize(nCells);
+    //cellMatType.resize(nCells);
+    // this gets the cell types and the map that stores the cell ids
+    CCMIOReadCells(&ccmErr, cellsID, &mapID, NULL,
+    CCMIOReadMap(&ccmErr, mapID, &cells[0], kCCMIOStart, kCCMIOEnd);
+    for (int i = 0; i < nCells; ++i)
+        cellInfo[i].id = cells[i];
+    IDMap cellIDMap;
+    cellIDMap.SetIDs(cells);
+    // Read the boundary faces.
+    int index = 0;
+    int count = 0;
+    int nBoundaries = 0;
+    while (CCMIONextEntity(NULL, topology, kCCMIOBoundaryFaces, &index,
+                           &faceID) == kCCMIONoErr)
+        nBoundaries++;
+    index = 0;
+        CCMIOSize nBFaces;
+        CCMIOEntitySize(&ccmErr, faceID, &nBFaces, NULL);
+        GetFaces(faceID, kCCMIOBoundaryFaces, nBFaces,
+                 cellIDMap, vertexIDMap,
+                 minFaceSize, maxFaceSize, cellInfo);
+    // Read the internal faces.
+    // Get the InternalFaces entity.
+    CCMIOGetEntity(&ccmErr, topology, kCCMIOInternalFaces, 0, &faceID);
+    // Get the InternalFaces size (num faces).
+    CCMIOEntitySize(&ccmErr, faceID, &nIFaces, NULL);
+    GetFaces(faceID, kCCMIOInternalFaces, nIFaces, cellIDMap, vertexIDMap,
+    if (find(varsOnSubmesh.begin(), varsOnSubmesh.end(), activeVisItVar)
+            != varsOnSubmesh.end())
+        // need to reduce the number of cells we actually process.
+        intVector validCells;
+        CellInfoVector vcv;
+        GetCellMapData(dom, activeVisItVar, validCells);
+        for (int i = 0; i < cellInfo.size(); ++i)
+            if (find(validCells.begin(), validCells.end(), cellInfo[i].id)
+                     != validCells.end())
+                vcv.push_back(cellInfo[i]);
+        cellInfo = vcv;
+    debug5 << "minFaceSize = " << minFaceSize
+           << ", maxFaceSize = " << maxFaceSize << endl;
+// Method: ComputePatchCenter
+// Purpose:
+//   Computes the center and bounds of the patch.
+// Arguments:
+//   centers : The centers for each cell in the mesh.
+//   patch   : The list of cellids that make up the patch.
+//   center  : The calculated center of the patch.
+//   bounds  : The calculated bounds of the patch.
+// Creation:   Tue Oct  6 16:12:08 PDT 2009
+// Modifications:
+static void
+ComputePatchCenter(const double *centers, const intVector &patch, double *center, double *bounds)
+    center[0] = 0.;
+    center[1] = 0.;
+    center[2] = 0.;
+    int nMatches = 0;
+    for(int i = 0; i < patch.size(); ++i)
+        const double *c = centers + patch[i] * 3;
+        // Compute extents of cell centers.
+        if(nMatches == 0)
+            bounds[0] = bounds[1] = c[0];
+            bounds[2] = bounds[3] = c[1];
+            bounds[4] = bounds[5] = c[2];
+        else
+            if(c[0] < bounds[0])
+                bounds[0] = c[0];
+            if(c[0] > bounds[1])
+                bounds[1] = c[0];
+            if(c[1] < bounds[2])
+                bounds[2] = c[1];
+            if(c[1] > bounds[3])
+                bounds[3] = c[1];
+            if(c[2] < bounds[4])
+                bounds[4] = c[2];
+            if(c[2] > bounds[5])
+                bounds[5] = c[2];
+        center[0] += c[0];
+        center[1] += c[1];
+        center[2] += c[2];
+        nMatches++;
+    if(nMatches > 0)
+        center[0] /= double(nMatches);
+        center[1] /= double(nMatches);
+        center[2] /= double(nMatches);
+// Method: DivideLargestPatch
+// Purpose:
+//   Divides the largest patch in the patch vector.
+// Arguments:
+//   centers : The centers of all cells in the mesh.
+//   patches : The list of all patches.
+// Returns:
+// Note:       This routine modifies the patches vector by splitting 1 of the
+//             patches, replacing the split patch with piece0. piece1 is appended
+//             to the patch vector.
+// Creation:   Tue Oct  6 16:13:33 PDT 2009
+// Modifications:
+static void
+DivideLargestPatch(const double *centers, std::vector<intVector> &patches)
+    // Find the index of the largest patch
+    int maxIndex = 0;
+    for(int i = 1; i < patches.size(); ++i)
+        if(patches[i].size() > patches[maxIndex].size())
+            maxIndex = i;
+    // Compute the center at which we will bisect.
+    double center[3], bounds[6];
+    ComputePatchCenter(centers, patches[maxIndex], center, bounds);
+    // Figure out the longest dimension since that's the dimension we'll bisect.
+    double dX = bounds[1] - bounds[0];
+    double dY = bounds[3] - bounds[2];
+    double dZ = bounds[5] - bounds[4];
+    int longestDimension = 2;
+    if(dX > dY)
+        if(dX > dZ)
+            longestDimension = 0;
+    else
+        if(dY > dZ)
+            longestDimension = 1;
+    const intVector &patch = patches[maxIndex];
+    intVector piece0, piece1;
+    for(int j = 0; j < patch.size(); ++j)
+        const double *c = centers + patch[j] * 3;
+        if(c[longestDimension] > center[longestDimension])
+            piece0.push_back(patch[j]);
+        else
+            piece1.push_back(patch[j]);
+    patches[maxIndex] = piece0;
+    patches.push_back(piece1);
+#endif
+// Method: avtCCMFileFormat::SelectCellsForThisProcessor
+// Purpose:
+//   This routine divides the cells spatially into PAR_Size() different bins
+//   and sets all of the ids for the cells in cellInfo to -1 (invalid) unless
+//   their bin matches PAR_Rank(). This means that we are marking a subset of
+//   the cells in cellInfo as being valid so we can return just a part of the
+//   dataset.
+// Arguments:
+//   cellInfo : The vector of cell data.
+//   points   : The points used by the cells.
+// Returns:
+// Note:       This method is just used in parallel when we have a single
+//             domain dataset that we want to automatically chunk up under the
+//             covers.
+// Creation:   Thu Oct  1 13:25:17 PDT 2009
+// Modifications:
+void
+avtCCMFileFormat::SelectCellsForThisProcessor(CellInfoVector &cellInfo, vtkPoints *points)
+        // Compute cell centers
+        double *centers = new double[cellInfo.size() * 3];
+        for(size_t i = 0; i < cellInfo.size(); ++i)
+            cellInfo[i].CellCenter(centers + i * 3, points);
+        // Start out with all cells in 1 patch
+        std::vector<intVector> patches;
+        intVector allCells;
+            allCells.push_back(i);
+        patches.push_back(allCells);
+        // Divide the largest patch until we have enough patches.
+        while(patches.size() < PAR_Size())
+            DivideLargestPatch(centers, patches);
+        // Set cellid to -1 unless we're on the patch whose id == PAR_Rank.
+        for(size_t p = 0; p < patches.size(); ++p)
+            if(p == PAR_Rank())
+                continue;
+            const intVector &patch = patches[p];
+            for(size_t i = 0; i < patch.size(); ++i)
+                cellInfo[patch[i]].id = -1;
+        delete [] centers;
+#endif
+//  Method:  avtCCMFileFormat::RegisterVariableList
+//  Purpose:
+//    Records the active variable name so only cells valid for the var
+//    will be retrieved during GetMesh calls.
+//  Creation:    February 28, 2008
+void
+avtCCMFileFormat::RegisterVariableList(const char *primaryVar,
+                                       const std::vector<CharStrRef> &)
+    activeVisItVar = primaryVar;
+//  Method:  avtCCMFileFormat::GetCellMapData
+//  Purpose:
+//    Retrieves the map data for a given var, which specifies the cell
+//    ids the var is defined upon.
+//  Arguments:
+//    domain     The required domain.
+//    var        The requested variable name.
+//    mapData    A place to store the retrieved map data.
+void
+avtCCMFileFormat::GetCellMapData(const int domain, const string &var,
+    intVector &mapData)
+    VarFieldMap::const_iterator pos = varsToFields.find(var.c_str());
+    if (pos == varsToFields.end())
+        EXCEPTION1(InvalidVariableException, var);
+    mapData.clear();
+    CCMIOSize n;
+    CCMIOIndex fmax;
+    CCMIOError ferr = kCCMIONoErr;
+    int j = 0, cnt = 0;
+    CCMIOID field = pos->second;
+    CCMIOReadField(&ferr, field, NULL, NULL, &cdims, NULL);
+        CCMIOID scalar;
+        ferr = kCCMIONoErr;
+        CCMIOReadMultiDimensionalFieldData(&ferr, field,
+        if (ferr == kCCMIONoErr)
+            field = scalar;
+    while(CCMIONextEntity(NULL, field, kCCMIOFieldData, &j, &fieldData)
+                                                              == kCCMIONoErr)
+        CCMIOEntitySize(&ferr, fieldData, &n, &fmax);
+        CCMIOReadFieldDataf(&ferr, fieldData, &mapID, NULL, NULL,
+        mapData.resize(cnt+n);
+        CCMIOReadMap(&ferr, mapID, &mapData[cnt], kCCMIOStart, kCCMIOEnd);
+        cnt += n;
+//  Method: avtCCMFileFormat::GetVar
+//  Purpose:
+//      Gets a scalar variable associated with this file.  Although VTK has
+//      support for many different types, the best bet is vtkFloatArray, since
+//      that is supported everywhere through VisIt.
+//  Arguments:
+//      varname    The name of the variable requested.
+//  Modifications:
+//    avtOriginalCellNumbers array now contains CCM cellid, so ensure that
+//    the data array is indexed-into correctly, by mapping the original cell
+//    Brad Whitlock, Thu Oct  1 13:08:35 PDT 2009
+//    Set domain to 0 if we're subdividing a single mesh.
+vtkDataArray *
+avtCCMFileFormat::GetVar(int domain, const char *varname)
+    const char *mName = "avtCCMFileFormat::GetVar: ";
+    domain = subdividingSingleMesh ? 0 : domain;
+    VarFieldMap::const_iterator pos = varsToFields.find(varname);
+        EXCEPTION1(InvalidVariableException, varname);
+    intVector mapData;
+    floatVector data;
+    ReadScalar(pos->second, mapData, data);
+    if (ccmErr != kCCMIONoErr)
+    unsigned int nvalues = data.size();
+    vtkFloatArray *rv = vtkFloatArray::New();
+    if (originalCells[domain] == NULL)
+        rv->SetNumberOfValues(nvalues);
+        for (unsigned int i = 0 ; i < nvalues ; ++i)
+            rv->SetValue(i, data[i]);
+    else
+        // We've tesselated, and have more cells than nvalues.  Need to
+        // duplicate values for all cells that share the same original
+        // cell number!
+        vtkUnsignedIntArray *ocarray =
+            vtkUnsignedIntArray::SafeDownCast(originalCells[domain]);
+        int numCells = ocarray->GetNumberOfTuples();
+        debug4 << mName << "numCells = " << numCells << endl;
+        unsigned int *oc = ocarray->GetPointer(0);
+        rv->SetNumberOfValues(numCells);
+        std::map<int, int> cellIdMap;
+        for (unsigned int i = 0; i < mapData.size(); i++)
+            cellIdMap[mapData[i]] = i;
+        for (unsigned int i = 0 ; i < numCells ; i++)
+            rv->SetValue(i, data[cellIdMap[oc[i*2+1]]]);
+    return rv;
+//  Method: avtCCMFileFormat::GetVectorVar
+//  Purpose:
+//      Gets a vector variable associated with this file.  Although VTK has
+//  Arguments:
+//  Modifications:
+//    avtOriginalCellNumbers array now contains CCM cellid, so enusre that
+//    id through an cellIdMap of valid cell ids (obtained from MapData).
+//    Dave Bremer, Fri Apr 11 16:49:45 PDT 2008
+//    Initialize the err variable.
+vtkDataArray *
+avtCCMFileFormat::GetVectorVar(int domain, const char *varname)
+    floatVector u, v, w, data;
+    CCMIOID scalar;
+    CCMIOReadMultiDimensionalFieldData(&err, field, kCCMIOVectorX, &scalar);
+    if (err == kCCMIOVersionErr)
+        // If we are reading an older version of the file,
+        // where vectors are stored as vectors, not components,
+        // we need to call CCMIOReadFieldData*(), which is
+        // all that ReadScalar() does.
+        err = kCCMIONoErr;
+        ReadScalar(field, mapData, data, true);
+    else
+        ReadScalar(scalar, mapData, u);
+        CCMIOReadMultiDimensionalFieldData(&err, field, kCCMIOVectorY, &scalar);
+        ReadScalar(scalar, mapData, v);
+        CCMIOReadMultiDimensionalFieldData(&err, field, kCCMIOVectorZ, &scalar);
+        ReadScalar(scalar, mapData, w);
+        data.resize(3 * u.size());
+        for (unsigned int k = 0;  k < u.size();  ++k)
+            data[3 * k    ] = u[k];
+            data[3 * k + 1] = v[k];
+            data[3 * k + 2] = w[k];
+    rv->SetNumberOfComponents(3);
+        rv->SetNumberOfTuples(nvalues/3);
+        float *v = rv->WritePointer(0, nvalues);
+        for (unsigned int i = 0 ; i < nvalues ; i++)
+            v[i] = data[i];
+    else
+        // cell number!
+        rv->SetNumberOfTuples(numCells);
+        float *v = rv->WritePointer(0, numCells*3);
+        for (unsigned int i = 0; i < mapData.size(); ++i)
+        for (unsigned int i = 0 ; i < numCells; ++i)
+            unsigned int id = cellIdMap[oc[i*2+1]];
+            v[i*3+0] = data[id*3+0];
+            v[i*3+1] = data[id*3+1];
+            v[i*3+2] = data[id*3+2];
+    return rv;
+//  Method: avtCCMFileFormat::ReadScalar
+//  Purpose:
+//    Reads scalar data from the file.
+//  Arguments:
+//    field      The ID of the field to read.
+//    mapData    A place to store data specifying which cells the scalar
+//               is defined upon.
+//    data       A place to store the scalar data.
+//    readingVector       Indicates if an old-style vector is being read.
+//  Modifications:
+//    Loop through field entities, as a var may be delineated by cell types,
+//    thus being represented by multiple 'fields'.  Correctly resize mapData
+//    and data each time through the loop.  Combined code for Cell and Node
+//    data as they were exactly the same.
+void
+avtCCMFileFormat::ReadScalar(CCMIOID field, intVector &mapData,
+                             floatVector &data, bool readingVector)
+    const char *mName = "avtCCMFileFormat::ReadScalar: ";
+    CCMIOSize n;
+    CCMIOIndex fmax;
+    mapData.clear();
+    data.clear();
+    // Read each piece of field data
+    // The fields may be delineated by cell types, so there may be
+    // multiple fields for the same variable.
+    while (CCMIONextEntity(NULL, field, kCCMIOFieldData, &j, &fieldData)
+                                                               == kCCMIONoErr)
+        // Figure out how big this data is so we can read it. If we were
+        // storing this information permanently we might use a sparse
+        // array, in which case we would need to find the maximum ID and
+        // make the array that size.
+        CCMIOEntitySize(&ccmErr, fieldData, &n, &fmax);
+        CCMIOReadFieldDataf(&ccmErr, fieldData, &mapID, &type, NULL,
+        if (type == kCCMIOCell || type == kCCMIOVertex)
+            mapData.resize(cnt +n);
+            CCMIOReadMap(&ccmErr, mapID, &mapData[cnt], kCCMIOStart, kCCMIOEnd);
+            if (readingVector)
+                data.resize(cnt +(3 * n));
+            else
+                data.resize(cnt + n);
+            if (type == kCCMIOCell)
+                debug4 << mName << "Reading cell data n= " << n << endl;
+            else
+                debug4 << mName << "Reading node data n= " << n << endl;
+            // If we want double precision we should use
+            // CCMIOReadFieldDatad().
+            CCMIOReadFieldDataf(&ccmErr, fieldData, &mapID, NULL,
+                                &data[cnt], kCCMIOStart, kCCMIOEnd);
+            cnt += n;
+#if 0
+            debug3 << "\tReadScalar found type kCCMIOFace" << endl;
+#endif
+            debug1 << "  Error reading scalar data " << ccmErr << endl;
+//  Method: avtCCMFileFormat::TesselateCell
+//  Purpose:
+//  Arguments:
+//    civ       Contains cell information.
+//    points    The points comprising the dataset.
+//    ugrid     The unstructured grid we are building.
+//  Creation:   October 1, 2007
+//  Modifications:
+//    Use cellid stored in CellInfo in avtOriginalCellNumbers array.
+//    Change fbounds to doubleVector to get around compiler problem on Windows.
+//    indices.
+void
+avtCCMFileFormat::TesselateCell(const int domain, const CellInfoVector &civ,
+    vtkPoints *points, vtkUnstructuredGrid *ugrid)
+#ifndef MDSERVER
+    const char *mName = "avtCCMFileFormat::TesselateCell: ";
+    unsigned int i, j, k;
+    unsigned int tetCount = 0;
+    vtkPoints *pts = vtkPoints::New();
+    pts->Allocate(points->GetNumberOfPoints());
+    VertexManager uniqueVerts(pts);
+    ccmPolygonToTriangles tess(&uniqueVerts);
+    int useCount = 0;
+    for(i = 0; i < civ.size(); ++i)
+         useCount += (civ[i].id != -1) ? 1 : 0;
+    originalCells[dom] = vtkUnsignedIntArray::New();
+    originalCells[dom]->SetName("avtOriginalCellNumbers");
+    originalCells[dom]->SetNumberOfComponents(2);
+    originalCells[dom]->Allocate(useCount * 3);
+    for (i = 0; i < civ.size(); ++i)
+        const CellInfo &ci = civ[i];
+        if(ci.id == -1)
+            continue;
+        oc[1] = ci.id;
+        int nFaces  = ci.faces.size();
+        int nPts = 0;
+        doubleVector fbounds;
+        for (j = 0; j < nFaces; ++j)
+            nPts += ci.faces[j].nodes.size();
+            fbounds.push_back(VTK_LARGE_FLOAT);
+            fbounds.push_back(-VTK_LARGE_FLOAT);
+        double *pt;
+        double cbounds[6] = {VTK_LARGE_FLOAT, -VTK_LARGE_FLOAT,
+                             VTK_LARGE_FLOAT, -VTK_LARGE_FLOAT,
+                             VTK_LARGE_FLOAT, -VTK_LARGE_FLOAT};
+        int cnt = 0;
+            const intVector &nodes = ci.faces[j].nodes;
+            for (k = 0; k < nodes.size(); ++k)
+                cnt++;
+                pt = points->GetPoint(nodes[k]);
+                if (pt[0] < cbounds[0])
+                    cbounds[0] = pt[0];
+                if (pt[0] > cbounds[1])
+                    cbounds[1] = pt[0];
+                if (pt[1] < cbounds[2])
+                    cbounds[2] = pt[1];
+                if (pt[1] > cbounds[3])
+                    cbounds[3] = pt[1];
+                if (pt[2] < cbounds[4])
+                    cbounds[4] = pt[2];
+                if (pt[2] > cbounds[5])
+                    cbounds[5] = pt[2];
+                if (pt[0] < fbounds[j*6+0])
+                    fbounds[j*6+0] = pt[0];
+                if (pt[0] > fbounds[j*6+1])
+                    fbounds[j*6+1] = pt[0];
+                if (pt[1] < fbounds[j*6+2])
+                    fbounds[j*6+2] = pt[1];
+                if (pt[1] > fbounds[j*6+3])
+                    fbounds[j*6+3] = pt[1];
+                if (pt[2] < fbounds[j*6+4])
+                    fbounds[j*6+4] = pt[2];
+                if (pt[2] > fbounds[j*6+5])
+                    fbounds[j*6+5] = pt[2];
+            } // k nodes
+        } // j faces
+        double cc[3] = {0.,0.,0.};
+        double fc[3] = {0.,0.,0.};
+        for (j = 0; j < 3; ++j)
+            cc[j] = (cbounds[2*j+1]+cbounds[2*j])/2.0;
+        int centerId = uniqueVerts.GetVertexId(cc);
+            // Find the face center
+            for (k = 0; k < 3; ++k)
+                fc[k] = (fbounds[2*k+1+(6*j)]+fbounds[2*k+(6*j)])/2.0;
+            // Tesselate the face
+            double n[3] = {(cc[0] - fc[0]), (cc[1] - fc[1]), (cc[2] - fc[2])};
+            tess.SetNormal(n);
+            tess.BeginPolygon();
+            tess.BeginContour();
+                cnt++;
+                tess.AddVertex(pt);
+            } // k nodes
+            tess.EndContour();
+            tess.EndPolygon();
+            // Make a tet for each triangle in the face to the cell center.
+            vtkIdType verts[4];
+            verts[3] = centerId;
+            if (tess.GetNumTriangles() > 0)
+                for (k = 0; k < tess.GetNumTriangles(); ++k)
+                    int a, b, c;
+                    tess.GetTriangle(k, a, b, c);
+                    verts[0] = a;
+                    verts[1] = b;
+                    verts[2] = c;
+                    ugrid->InsertNextCell(VTK_TETRA, 4, verts);
+                    ((vtkUnsignedIntArray*)originalCells[dom])->
+                        InsertNextTupleValue(oc);
+                tetCount += tess.GetNumTriangles();
+            // prepare for next cell
+            tess.ClearTriangles();
+        } // end face
+    pts->Squeeze();
+    ugrid->SetPoints(pts);
+    pts->Delete();
+    ugrid->GetCellData()->AddArray(originalCells[dom]);
+    ugrid->GetCellData()->CopyFieldOn("avtOriginalCellNumbers");
+    debug4 << mName << "Input number of polyhedral cells: " << civ.size()
+           << endl;
+    debug4 << mName << "Output tetrahedral cells: " << tetCount << endl;
+#endif
+// Method: avtCCMFileFormat::TesselateCells2D
+// Purpose:
+//   Adds the 2D cells to the unstructured grid, tessellating them as needed.
+// Arguments:
+//   civ    : The cell information vector.
+//   points : The points that we'll allocate during tessellation.
+//   ugrid  : The return unstructured grid object.
+// Returns:
+// Note:
+// Creation:   Tue Dec 18 12:54:56 PST 2007
+// Modifications:
+//   Remove unused variables.
+//   indices.
+typedef std::pair<int,int> edge_pair;
+void
+avtCCMFileFormat::TesselateCells2D(const int domain, const CellInfoVector &civ,
+#ifndef MDSERVER
+    unsigned int i, k;
+    int useCount = 0;
+    originalCells[dom]->Allocate(useCount*3);
+    const double n[3] = {0., 0., 1.};
+        if(ci.id == -1)
+            continue;
+        oc[1] = ci.id;
+        // We need to sort the edges around the polygon so we can tessellate
+        // by adding the first vertex of each edge to define the contour. We
+        // could do a different approach making n-1 triangles for the number
+        // of edges in the shape but this way supports concave polygons whereas
+        // the other approach does not.
+        // Put all of the line segments in a pool of free edges.
+        std::set<edge_pair> freeEdges;
+        for (int f = 0; f < ci.faces.size(); ++f)
+             edge_pair e01(ci.faces[f].nodes[0], ci.faces[f].nodes[1]);
+             freeEdges.insert(e01);
+        while(freeEdges.size() > 0)
+            std::deque<int> shape;
+            // Get seed edge and remove it from the pool
+            edge_pair currentEdge;
+            if(freeEdges.begin() != freeEdges.end())
+                currentEdge = *freeEdges.begin();
+                freeEdges.erase(freeEdges.begin());
+            shape.push_back(currentEdge.first);
+            shape.push_back(currentEdge.second);
+            // Now, look for edges that contain either of the points in
+            // the current edge.
+            bool found;
+            do
+                found = false;
+                for(std::set<edge_pair>::iterator pos = freeEdges.begin();
+                    pos != freeEdges.end() && !found; ++pos)
+                    if(currentEdge.first == pos->first)
+                        currentEdge.first = pos->second;
+                        shape.push_front(pos->second);
+                        freeEdges.erase(pos);
+                        found = true;
+                    else if(currentEdge.first == pos->second)
+                        currentEdge.first = pos->first;
+                        shape.push_front(pos->first);
+                        found = true;
+                    else if(currentEdge.second == pos->first)
+                        currentEdge.second = pos->second;
+                        shape.push_back(pos->second);
+                        found = true;
+                    else if(currentEdge.second == pos->second)
+                        currentEdge.second = pos->first;
+                        shape.push_back(pos->first);
+                        found = true;
+            } while(found);
+            if(shape.size() > 2)
+                for(int v = 0; v < shape.size(); ++v)
+                    tess.AddVertex(points->GetPoint(shape[v]));
+                int a, b, c;
+                verts[0] = a;
+                verts[1] = b;
+                verts[2] = c;
+                ugrid->InsertNextCell(VTK_TRIANGLE, 3, verts);
+    pts->Squeeze();
+    pts->Delete();
+#endif
+// Method: avtCCMFileFormat::BuildHex
+// Purpose:
+//   Creates a VTK hex cell from CCM faces.
+// Modifications:
+//   indices.
+void
+avtCCMFileFormat::BuildHex(const CellInfo &ci, vtkCellArray *cellArray,
+                           intVector &cellTypes)
+    unsigned int i, j;
+    const FaceInfoVector &faces = ci.faces;
+    intVector uniqueNodes;
+    bool useface;
+    bool usedBF = false;
+    int nnodes = 0;
+    vtkIdList *cellNodes = vtkIdList::New();
+    for (i = 0; i < faces.size(); ++i)
+        useface = true;
+        int nnodes = faces[i].nodes.size();
+        if (nnodes != 4)
+            return;
+        for (j = 0; useface && j <nnodes; ++j)
+            useface = (count(uniqueNodes.begin(), uniqueNodes.end(),
+                             faces[i].nodes[j]) == 0);
+        if (useface)
+            if ((ci.faceTypes[i] == 0 && !usedBF) || (ci.faceTypes[i] == 2))
+                usedBF = (ci.faceTypes[i] == 0);
+                // reorder this face
+                for (j = 0; j < nnodes; ++j)
+                    uniqueNodes.push_back(faces[i].nodes[j]);
+                cellNodes->InsertNextId(faces[i].nodes[0]);
+                cellNodes->InsertNextId(faces[i].nodes[3]);
+                cellNodes->InsertNextId(faces[i].nodes[2]);
+                cellNodes->InsertNextId(faces[i].nodes[1]);
+            else
+                    cellNodes->InsertNextId(faces[i].nodes[j]);
+    cellArray->InsertNextCell(cellNodes);
+    cellTypes.push_back(VTK_HEXAHEDRON);
+    cellNodes->Delete();
+// Method: avtCCMFileFormat::BuildTet
+// Purpose:
+//   Creates a VTK tet cell from CCM faces.
+// Modifications:
+//   Fix '==' '=' mix-up.
+//   indices.
+void
+avtCCMFileFormat::BuildTet(const CellInfo &ci, vtkCellArray *cellArray,
+    bool lastNodeFound = false;
+        if (faces[i].nodes.size() != 3)
+           return;
+    if (ci.faceTypes[0] != 1)
+        uniqueNodes.push_back(faces[0].nodes[0]);
+        uniqueNodes.push_back(faces[0].nodes[2]);
+        uniqueNodes.push_back(faces[0].nodes[1]);
+        cellNodes->InsertNextId(faces[0].nodes[0]);
+        cellNodes->InsertNextId(faces[0].nodes[2]);
+        cellNodes->InsertNextId(faces[0].nodes[1]);
+    else
+    for (i = 1; !lastNodeFound && i < faces.size(); ++i)
+        for (j = 0; !lastNodeFound && j <faces[i].nodes.size(); ++j)
+           if ((count(uniqueNodes.begin(), uniqueNodes.end(),
+                      faces[i].nodes[j]) == 0))
+               lastNodeFound = true;
+    cellTypes.push_back(VTK_TETRA);
+// Method: avtCCMFileFormat::BuildPyramid
+// Purpose:
+//   Creates a VTK pyramid cell from CCM faces.
+// Modifications:
+//   indices.
+void
+avtCCMFileFormat::BuildPyramid(const CellInfo &ci, vtkCellArray *cellArray,
+    int baseFace = 0;
+        if (faces[i].nodes.size() == 4)
+            baseFace = i;
+            for (j = 0; j < 4; ++j)
+    int triFace = (baseFace+1) % 4;
+    for (i = 0; i < 3; ++i) // only 3 nodes in the triangle-face
+             faces[triFace].nodes[i])) == 0)
+            cellNodes->InsertNextId(faces[triFace].nodes[i]);
+            break;
+    cellTypes.push_back(VTK_PYRAMID);
+// Method: avtCCMFileFormat::BuildWedge
+// Purpose:
+//   Creates a VTK wedge cell from CCM faces.
+// Modifications:
+//   indices.
+void
+avtCCMFileFormat::BuildWedge(const CellInfo &ci, vtkCellArray *cellArray,
+    unsigned int i;
+        if (faces[i].nodes.size() == 3)
+    cellTypes.push_back(VTK_WEDGE);
+// avtCCMFileFormat::FaceInfo class
+// Method: avtCCMFileFormat::FaceInfo::FaceInfo
+// Purpose:
+//   Constructor
+// Creation:   September 6, 2007
+// Modifications:
+//   Removed unused face id.
+avtCCMFileFormat::FaceInfo::FaceInfo()
+    //id = -1;
+    cells[0] = -1;
+    cells[1] = -1;
+// Purpose:
+//   Copy Constructor
+// Modifications:
+avtCCMFileFormat::FaceInfo::FaceInfo(const avtCCMFileFormat::FaceInfo &obj)
+    //id = obj.id;
+    cells[0] = obj.cells[0];
+    cells[1] = obj.cells[1];
+    nodes = obj.nodes;
+// Method: avtCCMFileFormat::FaceInfo::~FaceInfo
+// Purpose:
+//   Destructor
+// Modifications:
+avtCCMFileFormat::FaceInfo::~FaceInfo()
+// Method: avtCCMFileFormat::FaceInfo::operator =
+// Purpose:
+//   Assignment operator
+// Modifications:
+void
+avtCCMFileFormat::FaceInfo::operator =(const avtCCMFileFormat::FaceInfo &obj)
+    //id = obj.id;
+// avtCCMFileFormat::CellInfo class
+// Method: avtCCMFileFormat::CellInfo::CellInfo
+// Purpose:
+//   Constructor
+// Modifications:
+avtCCMFileFormat::CellInfo::CellInfo()
+    id = -1;
+// Purpose:
+// Modifications:
+avtCCMFileFormat::CellInfo::CellInfo(const avtCCMFileFormat::CellInfo &obj)
+    id = obj.id;
+    faceTypes = obj.faceTypes;
+    faces = obj.faces;
+// Method: avtCCMFileFormat::CellInfo::~CellInfo
+// Purpose:
+//   Destructor
+// Modifications:
+avtCCMFileFormat::CellInfo::~CellInfo()
+// Method: avtCCMFileFormat::CellInfo::operator =
+// Purpose:
+// Modifications:
+void
+avtCCMFileFormat::CellInfo::operator =(const avtCCMFileFormat::CellInfo &obj)
+    id = obj.id;
+// Method: avtCCMFileFormat::CellInfo::CellCenter
+// Purpose:
+//   Determines the cell center from its nodes.
+// Arguments:
+//   center : The returned center.
+//   pts    : The global points array that stores all of the nodes.
+// Creation:   Thu Oct  1 14:02:37 PDT 2009
+// Modifications:
+void
+avtCCMFileFormat::CellInfo::CellCenter(double *center, vtkPoints *pts) const
+    int npts = 0;
+    double c[3] = {0.,0.,0.};
+    for(int i = 0; i < faces.size(); ++i)
+        for(int j = 0; j < faces[i].nodes.size(); ++j, ++npts)
+            double *pt = pts->GetPoint(faces[i].nodes[j]);
+            c[0] += pt[0];
+            c[1] += pt[1];
+            c[2] += pt[2];
+    center[0] = c[0] / double(npts);
+    center[1] = c[1] / double(npts);
+    center[2] = c[2] / double(npts);
+// Method: avtCCMFileFormat::CellInfo::UseNodes
+// Purpose:
+//   Sets a true value into a domain-node-sized bool array for each node that
+//   the cell uses.
+// Arguments:
+//   pts : The array containing the values for whether a node is used.
+// Creation:   Thu Oct  1 14:03:22 PDT 2009
+// Modifications:
+void
+avtCCMFileFormat::CellInfo::UseNodes(bool *pts) const
+        for(int j = 0; j < faces[i].nodes.size(); ++j)
+            pts[faces[i].nodes[j]] = true;
+// Method: operator << (ostream &os, CCMIOEntity e)
+// Purpose:
+//   Prints a CCMIOEntity
+// Arguments:
+//   os : The stream to which we'll print.
+//   e  : The value to print.
+// Returns:    The input stream.
+// Note:
+// Creation:   Tue Dec 18 15:16:45 PST 2007
+// Modifications:
+ostream &
+operator << (ostream &os, CCMIOEntity e)
+    switch(e)
+    case kCCMIOBoundaryRegion:
+        os << "kCCMIOBoundaryRegion"; break;
+    case kCCMIOFieldData:
+        os << "kCCMIOFieldData"; break;
+    case kCCMIOFieldPhase:
+        os << "kCCMIOFieldPhase"; break;
+    case kCCMIOInternalFaces:
+        os << "kCCMIOInternalFaces"; break;
+    case kCCMIOMaxEntity:
+        os << "kCCMIOMaxEntity"; break;
+    case kCCMIOProblemDescription:
+        os << "kCCMIOProblemDescription"; break;
+    case kCCMIOReferenceData:
+        os << "kCCMIOReferenceData"; break;
+    case kCCMIOMap:
+        os << "kCCMIOMap"; break;
+    case kCCMIONull:
+        os << "kCCMIONull"; break;
+    case kCCMIOTopology:
+        os << "kCCMIOTopology"; break;
+    case kCCMIOVertices:
+        os << "kCCMIOVertices"; break;
+    case kCCMIOBoundaryFaces :
+        os << "kCCMIOBoundaryFaces "; break;
+    case kCCMIOCellType:
+        os << "kCCMIOCellType"; break;
+    case kCCMIOCells:
+        os << "kCCMIOCells"; break;
+    case kCCMIOField:
+        os << "kCCMIOField"; break;
+    case kCCMIOFieldSet :
+        os << "kCCMIOFieldSet "; break;
+    case kCCMIOInterfaces:
+        os << "kCCMIOInterfaces"; break;
+    case kCCMIOLagrangianData :
+        os << "kCCMIOLagrangianData "; break;
+    case kCCMIOModelConstants :
+        os << "kCCMIOModelConstants "; break;
+    case kCCMIOProcessor :
+        os << "kCCMIOProcessor "; break;
+    case kCCMIOProstarSet:
+        os << "kCCMIOProstarSet"; break;
+    case kCCMIORestart :
+        os << "kCCMIORestart "; break;
+    case kCCMIORestartData:
+        os << "kCCMIORestartData"; break;
+    case kCCMIOState :
+        os << "kCCMIOState "; break;
+    return os;
+// Method: operator << (ostream &os, const CCMIONode &node)
+// Purpose:
+//   Prints a CCMIONode
+// Arguments:
+// Note:
+// Modifications:
+ostream &
+operator << (ostream &os, const CCMIONode &node)
+    _CCMIONode *n = (_CCMIONode *)&node;
+    os << "(node=" << n->node << ", parent=" << n->parent << ")";
+    return os;
+// Method: operator << (ostream &os, const CCMIOID &e)
+// Purpose:
+//   Prints a CCMIOID
+// Arguments:
+// Note:
+// Modifications:
+ostream &
+operator << (ostream &os, const CCMIOID &id)
+    os << "(root=" << id.root
+       << ", node=" << id.node
+       << ", id=" << id.id
+       << ", type=" << id.type
+       << ", version=" << id.version << ")";
+    return os;
+// Method: avtCCMFileFormat::IDMap::IDMap
+// Purpose:
+//   Constructor
+// Programmer: Dave Bremer
+// Creation:   Fri Apr  4 16:29:49 PDT 2008
+// Modifications:
+avtCCMFileFormat::IDMap::IDMap()
+    bSequential = false;
+    bReverseMap = false;
+    iFirstElem = 0;
+    numIDs = 0;
+// Method: avtCCMFileFormat::IDMap::SetIDs
+// Purpose:
+//   Analyze a set of IDs and build a structure for mapping them back
+//   to the index corresponding to their position in v.
+// Modifications:
+void
+avtCCMFileFormat::IDMap::SetIDs(const intVector &v)
+    numIDs = v.size();
+    bSequential = true;
+    iFirstElem = v[0];
+    int min = v[0], max = v[0];
+    int ii;
+    for (ii = 1; ii < v.size(); ii++)
+        if (v[ii-1]+1 != v[ii])
+        if (v[ii] < min)
+            min = v[ii];
+        if (v[ii] > max)
+            max = v[ii];
+    //Don't bother copying data in, in this case.
+    if (bSequential)
+        return;
+    if (max-min+1 <= v.size()*2)
+        bReverseMap = true;
+        iFirstElem = min;
+        ids.resize(max-min+1, -1);
+        for (ii = 0; ii < v.size(); ii++)
+            ids[v[ii]-iFirstElem] = ii;
+    else
+        ids.resize(v.size()*2);
+            ids[ii*2]   = v[ii];
+            ids[ii*2+1] = ii;
+        qsort( &ids[0], v.size(), sizeof(int)*2, avtCCMFileFormat::IDMap::compare);
+// Method: avtCCMFileFormat::IDMap::compare
+// Purpose:
+//   compare function for qsort
+// Modifications:
+int
+avtCCMFileFormat::IDMap::compare(const void *a, const void *b)
+    return ( *((int *)a) - *((int *)b) );
+// Method: avtCCMFileFormat::IDMap::IDtoIndex
+// Purpose:
+//   Map an id to an array index.  Return -1 if the id is not in the map.
+// Modifications:
+int
+avtCCMFileFormat::IDMap::IDtoIndex(int id) const
+    if (bSequential)
+        int r = id - iFirstElem;
+        if (r >= 0 && r < numIDs)
+            return r;
+    else if (bReverseMap)
+        if (id-iFirstElem >= 0 && id-iFirstElem < ids.size())
+            return ids[id-iFirstElem];
+    else
+        int min = 0, max = ids.size()/2 - 1;
+        int mid = (min+max)/2;
+        while (min <= max)
+            if (id < ids[mid*2])
+                max = mid-1;
+                mid = (min+max)/2;
+            else if (id > ids[mid*2])
+                min = mid+1;
+            else
+                return ids[mid*2+1];
+    return -1;
Added: MOAB/trunk/ReadCCMIO.hpp
--- MOAB/trunk/ReadCCMIO.hpp	                        (rev 0)
+++ MOAB/trunk/ReadCCMIO.hpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -0,0 +1,123 @@
+#ifndef READCCMIO_HPP
+#define READCCMIO_HPP
+#ifndef IS_BUILDING_MB
+#error "ReadCCMIO.hpp isn't supposed to be included into an application"
+#endif
+#include <vector>
+#include <set>
+#include <map>
+#include <string>
+#include "MBForward.hpp"
+#include "MBRange.hpp"
+#include "ExoIIInterface.hpp"
+#include "MBReaderIface.hpp"
+#include "TupleList.hpp"
+#include "ccmio.h"
+#define TupleList std::map<int, std::vector<MBEntityHandle> >
+#define SenseList std::map<int, std::vector<int> >
+#undef TUPLE_LIST
+class MBReadUtilIface;
+class MB_DLL_EXPORT ReadCCMIO : public MBReaderIface
+public:
+    //! Constructor
+  ReadCCMIO(MBInterface *impl);
+   //! Destructor
+  virtual ~ReadCCMIO();
+  static MBReaderIface* factory( MBInterface* );
+  MBErrorCode load_file(const char *file_name,
+                        const MBEntityHandle* file_set,
+                        const FileOptions& opts,
+                        const MBReaderIface::IDTag* subset_list,
+                        int subset_list_length,
+                        const MBTag* file_id_tag);
+private:
+  MBErrorCode read_processor(CCMIOID rootID, CCMIOID processorID, CCMIOSize_t proc);
+  MBErrorCode read_cells(CCMIOSize_t proc, CCMIOID processorID,
+                         CCMIOID verticesID, CCMIOID topologyID,
+                         CCMIOID solutionID, bool has_solution,
+                         TupleList &vert_map);
+  MBErrorCode construct_cells(TupleList &face_map,
+#ifndef TUPLE_LIST
+                              SenseList &sense_map,
+#endif
+                              TupleList &vert_map, MBRange &new_cells);
+  MBErrorCode create_cell_from_faces(std::vector<MBEntityHandle> &facehs,
+                                     std::vector<int> &senses,
+                                     MBEntityHandle &cell);
+  MBErrorCode read_all_faces(CCMIOID topologyID, TupleList &vert_map,
+#ifndef TUPLE_LIST
+#endif
+  MBErrorCode read_faces(CCMIOID faceID, CCMIOEntity bdy_or_int,
+#ifndef TUPLE_LIST
+#endif
+  MBErrorCode make_faces(int *farray,
+                         std::vector<MBEntityHandle> &new_faces);
+  MBErrorCode read_vertices(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID,
+                            MBRange &verts, TupleList &vert_map);
+  MBErrorCode get_processors(CCMIOID stateID, CCMIOID &processorID,
+                             std::set<CCMIOSize_t> &procs);
+  MBErrorCode get_state(CCMIOID rootID, CCMIOID &problemID, CCMIOID &stateID);
+  virtual MBErrorCode read_tag_values( const char* file_name,
+                                       const IDTag* subset_list = 0,
+                                       int subset_list_length = 0 );
+    //! Cached tags for reading.  Note that all these tags are defined when the
+    //! core is initialized.
+  MBTag mMaterialSetTag;
+  MBTag mDirichletSetTag;
+  MBTag mNeumannSetTag;
+  MBTag mHasMidNodesTag;
+  MBTag mGlobalIdTag;
+  MBInterface *mbImpl;
+  MBReadUtilIface* readMeshIface;
+  bool hasSolution;
+#endif
Modified: MOAB/trunk/ReadSmf.cpp
--- MOAB/trunk/ReadSmf.cpp	2010-01-28 21:02:20 UTC (rev 3507)
+++ MOAB/trunk/ReadSmf.cpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -132,7 +132,7 @@
     mPartitionTagName = partition_tag_name;
   std::ifstream smfFile;
-  smfFile.open( filename , std::ifstream::in);
+    //smfFile.open( filename , std::ifstream::in);
   if (!smfFile.is_open())
     return MB_FILE_DOES_NOT_EXIST;
Modified: MOAB/trunk/SMF_State.cpp
--- MOAB/trunk/SMF_State.cpp	2010-01-28 21:02:20 UTC (rev 3507)
+++ MOAB/trunk/SMF_State.cpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -1,8 +1,10 @@
 #include "SMF_State.hpp"
+#include <cstring>
+#include <cstdlib>
-inline int streq(const char *a,const char *b) { return std::strcmp(a,b)==0; }
+inline int streq(const char *a,const char *b) { return strcmp(a,b)==0; }
 SMF_State::SMF_State(const SMF_ivars& ivar, SMF_State *link)
Added: MOAB/trunk/WriteCCMIO.cpp
--- MOAB/trunk/WriteCCMIO.cpp	                        (rev 0)
+++ MOAB/trunk/WriteCCMIO.cpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -0,0 +1,1035 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+#ifdef WIN32
+#ifdef _DEBUG
+// turn off warnings that say they debugging identifier has been truncated
+// this warning comes up when using some STL containers
+#pragma warning(disable : 4786)
+#endif
+#endif
+#include "WriteCCMIO.hpp"
+#include "ccmio.h"
+#include "ccmioutility.h"
+#include "ccmiocore.h"
+#include <utility>
+#include <algorithm>
+#include <time.h>
+#include <string>
+#include <vector>
+#include <stdio.h>
+#include <iostream>
+#include "MBInterface.hpp"
+#include "MBCN.hpp"
+#include "assert.h"
+#include "MBInternals.hpp"
+#include "ExoIIUtil.hpp"
+#include "MBTagConventions.hpp"
+#include "MBWriteUtilIface.hpp"
+static char const kStateName[] = "default";
+static const int ccm_types[] = {
+    1,   // MBVERTEX
+    2,   // MBEDGE
+    -1,  // MBTRI
+    -1,  // MBQUAD
+    -1,  // MBPOLYGON
+    13,  // MBTET
+    14,  // MBPYRAMID
+    12,  // MBPRISM
+    -1,  // MBKNIFE
+    11,  // MBHEX
+    255  // MBPOLYHEDRON
+#define INS_ID(stringvar, prefix, id)           \
+    sprintf(stringvar, prefix, id)
+MBWriterIface* WriteCCMIO::factory( MBInterface* iface )
+{ return new WriteCCMIO( iface ); }
+WriteCCMIO::WriteCCMIO(MBInterface *impl)
+        : mbImpl(impl), mCurrentMeshHandle(0)
+  assert(impl != NULL);
+  void* ptr = 0;
+  impl->query_interface( "MBWriteUtilIface", &ptr );
+  mWriteIface = reinterpret_cast<MBWriteUtilIface*>(ptr);
+    // initialize in case tag_get_handle fails below
+    //! get and cache predefined tag handles
+  int dum_val = 0;
+  MBErrorCode result = impl->tag_get_handle(MATERIAL_SET_TAG_NAME,  mMaterialSetTag);
+  if (MB_TAG_NOT_FOUND == result)
+    result = impl->tag_create(MATERIAL_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mMaterialSetTag,
+                              &dum_val);
+  result = impl->tag_get_handle(DIRICHLET_SET_TAG_NAME, mDirichletSetTag);
+    result = impl->tag_create(DIRICHLET_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mDirichletSetTag,
+                              &dum_val);
+  result = impl->tag_get_handle(NEUMANN_SET_TAG_NAME, mNeumannSetTag);
+    result = impl->tag_create(NEUMANN_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mNeumannSetTag,
+                              &dum_val);
+#ifdef USE_MPI
+  result = impl->tag_get_handle(PARALLEL_PARTITION_TAG_NAME, mPartitionSetTag);
+    // no need to check result, if it's not there, we don't create one
+#endif
+  result = impl->tag_get_handle(HAS_MID_NODES_TAG_NAME, mHasMidNodesTag);
+  if (MB_TAG_NOT_FOUND == result) {
+    int dum_val_array[] = {0, 0, 0, 0};
+    result = impl->tag_create(HAS_MID_NODES_TAG_NAME, 4*sizeof(int), MB_TAG_SPARSE, mHasMidNodesTag,
+                              dum_val_array);
+  result = impl->tag_get_handle(GLOBAL_ID_TAG_NAME, mGlobalIdTag);
+    result = impl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_SPARSE, mGlobalIdTag,
+                              &dum_val);
+  dum_val = -1;
+  result = impl->tag_get_handle("__matSetIdTag", mMatSetIdTag);
+    result = impl->tag_create("__matSetIdTag", sizeof(int), MB_TAG_DENSE, mMatSetIdTag,
+                              &dum_val);
+  impl->tag_create("WriteCCMIO element mark", 1, MB_TAG_BIT, mEntityMark, NULL);
+WriteCCMIO::~WriteCCMIO()
+  std::string iface_name = "MBWriteUtilIface";
+  mbImpl->release_interface(iface_name, mWriteIface);
+  mbImpl->tag_delete(mEntityMark);
+void WriteCCMIO::reset_matset(std::vector<WriteCCMIO::MaterialSetData> &matset_info)
+  std::vector<WriteCCMIO::MaterialSetData>::iterator iter;
+  for (iter = matset_info.begin(); iter != matset_info.end(); iter++)
+    delete (*iter).elements;
+MBErrorCode WriteCCMIO::write_file(const char *file_name,
+                                   const bool /* overwrite (commented out to remove warning) */,
+                                   const MBEntityHandle *ent_handles,
+                                   const int num_sets,
+                                   const std::vector<std::string>&,
+                                   const MBTag* ,
+                                   int ,
+                                   int )
+  assert(0 != mMaterialSetTag &&
+         0 != mNeumannSetTag &&
+         0 != mDirichletSetTag);
+    // check the file name
+  if (NULL == strstr(file_name, ".ccmio"))
+    return MB_FAILURE;
+  std::vector<MBEntityHandle> matsets, dirsets, neusets, partsets, entities;
+  fileName = file_name;
+    // separate into material sets, dirichlet sets, neumann sets
+  if (num_sets == 0) {
+      // default to all defined sets
+    MBRange this_range;
+    mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &mMaterialSetTag, NULL, 1, this_range);
+    std::copy(this_range.begin(), this_range.end(), std::back_inserter(matsets));
+    this_range.clear();
+    mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &mDirichletSetTag, NULL, 1, this_range);
+    std::copy(this_range.begin(), this_range.end(), std::back_inserter(dirsets));
+    mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &mNeumannSetTag, NULL, 1, this_range);
+    std::copy(this_range.begin(), this_range.end(), std::back_inserter(neusets));
+    if (mPartitionSetTag) {
+      mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &mPartitionSetTag, NULL, 1, this_range);
+      std::copy(this_range.begin(), this_range.end(), std::back_inserter(partsets));
+  else {
+    int dummy;
+    for (const MBEntityHandle *iter = ent_handles; iter < ent_handles+num_sets; iter++)
+      if (MB_SUCCESS == mbImpl->tag_get_data(mMaterialSetTag, &(*iter), 1, &dummy))
+        matsets.push_back(*iter);
+      else if (MB_SUCCESS == mbImpl->tag_get_data(mDirichletSetTag, &(*iter), 1, &dummy))
+        dirsets.push_back(*iter);
+      else if (MB_SUCCESS == mbImpl->tag_get_data(mNeumannSetTag, &(*iter), 1, &dummy))
+        neusets.push_back(*iter);
+      else if (mPartitionSetTag &&
+               MB_SUCCESS == mbImpl->tag_get_data(mPartitionSetTag, &(*iter), 1, &dummy))
+        partsets.push_back(*iter);
+  MBErrorCode result = mbImpl->tag_get_handle(HAS_MID_NODES_TAG_NAME, mHasMidNodesTag);
+    result = mbImpl->tag_create(HAS_MID_NODES_TAG_NAME, 4*sizeof(int), MB_TAG_SPARSE, mHasMidNodesTag,
+                                dum_val_array);
+    // if there is nothing to write just return.
+  if (matsets.empty() && dirsets.empty() && neusets.empty() && partsets.empty())
+    return MB_FILE_WRITE_ERROR;
+  std::vector<WriteCCMIO::MaterialSetData> matset_info;
+  std::vector<WriteCCMIO::DirichletSetData> dirset_info;
+  std::vector<WriteCCMIO::NeumannSetData> neuset_info;
+  MeshInfo mesh_info;
+  matset_info.clear();
+  if(gather_mesh_information(mesh_info, matset_info, neuset_info, dirset_info,
+                             matsets, neusets, dirsets) != MB_SUCCESS)
+    reset_matset(matset_info);
+    // try to open the file after gather mesh info succeeds
+  CCMIOID stateID, processorID, rootID;
+  CCMIOError error = kCCMIONoErr;
+  CCMIOOpenFile(&error, file_name, kCCMIOWrite, &rootID);
+  if(kCCMIONoErr != error)
+    mWriteIface->report_error("Cannot open %s", file_name);
+    // Create a new state (or re-use an existing one).
+  CCMIONewState(&error, rootID, kStateName, NULL, NULL, &stateID);
+  if (kCCMIONoErr != error) {
+//  for (; i < CCMIOSIZEC(partsets.size()); i++) {
+  if (CCMIONextEntity(NULL, stateID, kCCMIOProcessor, &i, &processorID) != kCCMIONoErr)
+    CCMIONewEntity(&error, stateID, kCCMIOProcessor, NULL, &processorID);
+    // Get rid of any data that may be in this processor (if the state was
+    // not new).
+  else
+    CCMIOClearProcessor(&error, stateID, processorID, TRUE, TRUE, TRUE, TRUE,
+                        TRUE);
+  int *vgids;
+  if( write_nodes(rootID, mesh_info.nodes, mesh_info.num_dim, vgids)
+      != MB_SUCCESS )
+  if( write_matsets(mesh_info, matset_info, neuset_info, mesh_info.nodes, vgids) )
+  if (write_problem_description(rootID, stateID)) {
+  CCMIOCloseFile(&error, rootID);
+  if (error != kCCMIONoErr)
+  // The CCMIO library uses ADF to store the actual data.  Unfortunately,
+  // ADF leaks disk space;  deleting a node does not recover all the disk
+  // space.  Now that everything is successfully written it might be useful
+  // to call CCMIOCompress() here to ensure that the file is as small as
+  // possible.  Please see the Core API documentation for caveats on its
+  // usage.
+  if (CCMIOCompress(NULL, const_cast<char*>(file_name)) != kCCMIONoErr)
+    std::cout << "Error compressing file.  Check that you have "
+              << "adequate disk space " << std::endl << "and that you have write "
+              << "permission to the current directory." << std::endl;
+  return MB_SUCCESS;
+MBErrorCode WriteCCMIO::write_problem_description(CCMIOID rootID, CCMIOID stateID)
+  // Write out a dummy problem description.  If we happen to know that
+  // there already is a problem description previously recorded that
+  // is valid we could skip this step.
+  CCMIOID problem, constants, id;
+  CCMIONewEntity(&error, rootID, kCCMIOProblemDescription, "Dummy description",
+                 &problem);
+  CCMIONewIndexedEntity(&error, problem, kCCMIOCellType, 1, "Dummy celltypes", &id);
+  CCMIOWriteOptstr(&error, id, "MaterialType", "solid");
+  CCMIONewIndexedEntity(&error, problem, kCCMIOCellType, 2, "Dummy celltypes", &id);
+  CCMIONewEntity(&error, problem, kCCMIOModelConstants, "Constant values",
+                 &constants);
+  CCMIOWriteOptf(&error, constants, "Gravity", 9.82);
+  CCMIOWriteOptf(&error, constants, "B.P. of water", 373);
+  // We have problem description recorded but our state does not know
+  // about it.  So tell the state that it has a problem description.
+  CCMIOWriteState(&error, stateID, problem, "Example state");
+MBErrorCode WriteCCMIO::gather_mesh_information(MeshInfo &mesh_info,
+                                                std::vector<WriteCCMIO::MaterialSetData> &matset_info,
+                                                std::vector<WriteCCMIO::NeumannSetData> &neuset_info,
+                                                std::vector<WriteCCMIO::DirichletSetData> &dirset_info,
+                                                std::vector<MBEntityHandle> &matsets,
+                                                std::vector<MBEntityHandle> &neusets,
+                                                std::vector<MBEntityHandle> &dirsets)
+  std::vector<MBEntityHandle>::iterator vector_iter, end_vector_iter;
+  mesh_info.num_nodes = 0;
+  mesh_info.num_elements = 0;
+  mesh_info.num_matsets = 0;
+  int id = 0;
+  vector_iter= matsets.begin();
+  end_vector_iter = matsets.end();
+  mesh_info.num_matsets = matsets.size();
+  std::vector<MBEntityHandle> parent_meshsets;
+    // clean out the bits for the element mark
+  mbImpl->tag_create("WriteCCMIO element mark", 1, MB_TAG_BIT, mEntityMark, NULL);
+  int highest_dimension_of_element_matsets = 0;
+  for(vector_iter = matsets.begin(); vector_iter != matsets.end(); vector_iter++)
+    WriteCCMIO::MaterialSetData matset_data;
+    matset_data.elements = new MBRange;
+      //for the purpose of qa records, get the parents of these matsets
+    if( mbImpl->get_parent_meshsets( *vector_iter, parent_meshsets ) != MB_SUCCESS )
+      // get all Entity Handles in the mesh set
+    MBRange dummy_range;
+    mbImpl->get_entities_by_handle(*vector_iter, dummy_range, true );
+      // find the dimension of the last entity in this range
+    MBRange::iterator entity_iter = dummy_range.end();
+    entity_iter = dummy_range.end();
+    entity_iter--;
+    int this_dim = MBCN::Dimension(TYPE_FROM_HANDLE(*entity_iter));
+    entity_iter = dummy_range.begin();
+    while (entity_iter != dummy_range.end() &&
+           MBCN::Dimension(TYPE_FROM_HANDLE(*entity_iter)) != this_dim)
+      entity_iter++;
+    if (entity_iter != dummy_range.end())
+      std::copy(entity_iter, dummy_range.end(), mb_range_inserter(*(matset_data.elements)));
+    assert(matset_data.elements->begin() == matset_data.elements->end() ||
+           MBCN::Dimension(TYPE_FROM_HANDLE(*(matset_data.elements->begin()))) == this_dim);
+      // get the matset's id
+    if(mbImpl->tag_get_data(mMaterialSetTag, &(*vector_iter), 1, &id) != MB_SUCCESS ) {
+      mWriteIface->report_error("Couldn't get matset id from a tag for an element matset.");
+    matset_data.id = id;
+    matset_data.number_attributes = 0;
+      // iterate through all the elements in the meshset
+    MBRange::iterator elem_range_iter, end_elem_range_iter;
+    elem_range_iter = matset_data.elements->begin();
+    end_elem_range_iter = matset_data.elements->end();
+      // get the entity type for this matset, verifying that it's the same for all elements
+      // THIS ASSUMES HANDLES SORT BY TYPE!!!
+    MBEntityType entity_type = TYPE_FROM_HANDLE(*elem_range_iter);
+    end_elem_range_iter--;
+    if (entity_type != TYPE_FROM_HANDLE(*(end_elem_range_iter++))) {
+      mWriteIface->report_error("Entities in matset %i not of common type", id);
+    int dimension = MBCN::Dimension(entity_type);
+    if( dimension > highest_dimension_of_element_matsets )
+      highest_dimension_of_element_matsets = dimension;
+    matset_data.moab_type = mbImpl->type_from_handle(*(matset_data.elements->begin()));
+    if (MBMAXTYPE == matset_data.moab_type) return MB_FAILURE;
+    std::vector<MBEntityHandle> tmp_conn;
+    mbImpl->get_connectivity(&(*(matset_data.elements->begin())), 1, tmp_conn);
+    matset_data.element_type =
+        ExoIIUtil::get_element_type_from_num_verts(tmp_conn.size(), entity_type, dimension);
+    if (matset_data.element_type == EXOII_MAX_ELEM_TYPE) {
+      mWriteIface->report_error("Element type in matset %i didn't get set correctly", id);
+    matset_data.number_nodes_per_element = ExoIIUtil::VerticesPerElement[matset_data.element_type];
+      // number of nodes for this matset
+    matset_data.number_elements = matset_data.elements->size();
+      // total number of elements
+    mesh_info.num_elements += matset_data.number_elements;
+      // get the nodes for the elements
+    mWriteIface->gather_nodes_from_elements(*matset_data.elements, mEntityMark, mesh_info.nodes);
+    if(!neusets.empty())
+        // if there are neusets, keep track of which elements are being written out
+      for(MBRange::iterator iter = matset_data.elements->begin();
+          iter != matset_data.elements->end(); ++iter)
+        unsigned char bit = 0x1;
+        mbImpl->tag_set_data(mEntityMark, &(*iter), 1, &bit);
+    matset_info.push_back( matset_data );
+    //if user hasn't entered dimension, we figure it out
+  if( mesh_info.num_dim == 0 )
+      //never want 1 or zero dimensions
+    if( highest_dimension_of_element_matsets < 2 )
+      mesh_info.num_dim = 3;
+    else
+      mesh_info.num_dim = highest_dimension_of_element_matsets;
+  MBRange::iterator range_iter, end_range_iter;
+  range_iter = mesh_info.nodes.begin();
+  end_range_iter = mesh_info.nodes.end();
+  mesh_info.num_nodes = mesh_info.nodes.size();
+    //------dirsets--------
+  vector_iter= dirsets.begin();
+  end_vector_iter = dirsets.end();
+  for(; vector_iter != end_vector_iter; vector_iter++)
+    WriteCCMIO::DirichletSetData dirset_data;
+    dirset_data.id = 0;
+    dirset_data.number_nodes = 0;
+      // get the dirset's id
+    if(mbImpl->tag_get_data(mDirichletSetTag,&(*vector_iter), 1,&id) != MB_SUCCESS) {
+      mWriteIface->report_error("Couldn't get id tag for dirset %i", id);
+    dirset_data.id = id;
+    std::vector<MBEntityHandle> node_vector;
+      //get the nodes of the dirset that are in mesh_info.nodes
+    if( mbImpl->get_entities_by_handle(*vector_iter, node_vector, true) != MB_SUCCESS ) {
+      mWriteIface->report_error("Couldn't get nodes in dirset %i", id);
+    std::vector<MBEntityHandle>::iterator iter, end_iter;
+    iter = node_vector.begin();
+    end_iter= node_vector.end();
+    int j=0;
+    unsigned char node_marked = 0;
+    MBErrorCode result;
+    for(; iter != end_iter; iter++)
+      if (TYPE_FROM_HANDLE(*iter) != MBVERTEX) continue;
+      result = mbImpl->tag_get_data(mEntityMark, &(*iter), 1, &node_marked);
+      if (MB_SUCCESS != result) {
+        mWriteIface->report_error("Couldn't get mark data.");
+        return result;
+      if(node_marked == 0x1) dirset_data.nodes.push_back( *iter );
+      j++;
+    dirset_data.number_nodes = dirset_data.nodes.size();
+    dirset_info.push_back( dirset_data );
+    //------neusets--------
+  vector_iter= neusets.begin();
+  end_vector_iter = neusets.end();
+    WriteCCMIO::NeumannSetData neuset_data;
+      // get the neuset's id
+    if(mbImpl->tag_get_data(mNeumannSetTag,&(*vector_iter), 1,&id) != MB_SUCCESS)
+    neuset_data.id = id;
+    neuset_data.mesh_set_handle = *vector_iter;
+      //get the sides in two lists, one forward the other reverse; starts with forward sense
+      // by convention
+    MBRange forward_elems, reverse_elems;
+    if(get_neuset_elems(*vector_iter, 0, forward_elems, reverse_elems) == MB_FAILURE)
+    MBErrorCode result = get_valid_sides(forward_elems, 1, neuset_data);
+      mWriteIface->report_error("Couldn't get valid sides data.");
+      return result;
+    result = get_valid_sides(reverse_elems, -1, neuset_data);
+      return result;
+    neuset_data.number_elements = neuset_data.elements.size();
+    neuset_info.push_back( neuset_data );
+MBErrorCode WriteCCMIO::get_valid_sides(MBRange &elems, const int sense,
+                                        WriteCCMIO::NeumannSetData &neuset_data)
+    // this is where we see if underlying element of side set element is included in output
+  unsigned char element_marked = 0;
+  for(MBRange::iterator iter = elems.begin(); iter != elems.end(); iter++)
+      // should insert here if "side" is a quad/tri on a quad/tri mesh
+    result = mbImpl->tag_get_data(mEntityMark, &(*iter), 1, &element_marked);
+      return result;
+    if(element_marked == 0x1)
+      neuset_data.elements.push_back( *iter );
+        // TJT TODO: the sense should really be # edges + 1or2
+      neuset_data.side_numbers.push_back((sense == 1 ? 1 : 2));
+    else //then "side" is probably a quad/tri on a hex/tet mesh
+      std::vector<MBEntityHandle> parents;
+      int dimension = MBCN::Dimension( TYPE_FROM_HANDLE(*iter));
+        //get the adjacent parent element of "side"
+      if( mbImpl->get_adjacencies( &(*iter), 1, dimension+1, false, parents) != MB_SUCCESS ) {
+        mWriteIface->report_error("Couldn't get adjacencies for neuset.");
+      if(!parents.empty())
+          //make sure the adjacent parent element will be output
+        for(unsigned int k=0; k<parents.size(); k++)
+          result = mbImpl->tag_get_data(mEntityMark, &(parents[k]), 1, &element_marked);
+            return result;
+          int side_no, this_sense, this_offset;
+          if(element_marked == 0x1 &&
+             mbImpl->side_number(parents[k], *iter, side_no,
+                                 this_sense, this_offset) == MB_SUCCESS &&
+             this_sense == sense) {
+            neuset_data.elements.push_back(parents[k]);
+            neuset_data.side_numbers.push_back(side_no+1);
+            break;
+      else
+        mWriteIface->report_error("No parent element exists for element in neuset %i", neuset_data.id);
+MBErrorCode WriteCCMIO::get_gids(const MBRange &ents, int *&gids,
+                                 int &minid, int &maxid)
+  int num_ents = ents.size();
+  gids = new int[num_ents];
+  MBErrorCode result = mbImpl->tag_get_data(mGlobalIdTag, ents, &gids[0]);
+    mWriteIface->report_error("Couldn't get global id data.");
+    return result;
+  minid = *std::min_element(gids, gids+num_ents);
+  maxid = *std::max_element(gids, gids+num_ents);
+  if (0 == minid) {
+      // gids need to be assigned
+    for (int i = 1; i <= num_ents; i++) gids[i] = i;
+    result = mbImpl->tag_set_data(mGlobalIdTag, ents, &gids[0]);
+      mWriteIface->report_error("Couldn't set global id data.");
+      return result;
+    maxid = num_ents;
+MBErrorCode WriteCCMIO::write_nodes(CCMIOID rootID, const MBRange& nodes,
+                                    const int dimension, int *&vgids)
+    // get/write map (global ids) first
+  const int num_nodes = nodes.size();
+  int minid, maxid;
+  MBErrorCode result = get_gids(nodes, vgids, minid, maxid);
+  if (MB_SUCCESS != result) return result;
+  CCMIOID mapID;
+  CCMIOError error;
+  CCMIONewEntity(&error, rootID, kCCMIOMap, "Vertex map", &mapID);
+  CCMIOWriteMap(&error, mapID, CCMIOSIZEC(nodes.size()),
+                CCMIOSIZEC(maxid), vgids,
+                CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
+    // get the vertex locations
+  double *coords = new double[dimension*num_nodes];
+  std::vector<double*> coord_arrays(3);
+  coord_arrays[0] = coords;
+  coord_arrays[1] = coords+num_nodes;
+  coord_arrays[2] = (dimension == 3 ? coords+2*num_nodes : NULL);
+  result = mWriteIface->get_node_arrays(dimension, num_nodes, nodes,
+                                        mGlobalIdTag, 0, coord_arrays);
+  if(result != MB_SUCCESS)
+    delete [] coords;
+    return result;
+    // transform coordinates, if necessary
+  result = transform_coords(dimension, num_nodes, coords);
+    delete [] coords;
+    return result;
+    // write the vertices
+  CCMIOID verticesID;
+  CCMIONewEntity(&error, rootID, kCCMIOVertices, "Vertices", &verticesID);
+  CCMIOWriteVerticesd(&error, verticesID,
+                     CCMIOSIZEC(dimension*num_nodes), 1.0, mapID, coords,
+                     CCMIOINDEXC(1), CCMIOINDEXC(dimension));
+  if (error != kCCMIONoErr) {
+    mWriteIface->report_error("CCMIOWriteVertices failed.");
+    return result;
+    // clean up
+  delete [] coords;
+MBErrorCode WriteCCMIO::transform_coords(const int dimension, const int num_nodes, double *coords)
+  MBTag trans_tag;
+  MBErrorCode result = mbImpl->tag_get_handle( MESH_TRANSFORM_TAG_NAME, trans_tag);
+  if( result == MB_TAG_NOT_FOUND ) return MB_SUCCESS;
+  double trans_matrix[16];
+  result = mbImpl->tag_get_data( trans_tag, NULL, 0, trans_matrix );
+    mWriteIface->report_error("Couldn't get transform data.");
+    return result;
+  double *tmp_coords = coords;
+  for( int i=0; i<num_nodes; i++, tmp_coords += 1) {
+    double vec1[3] = {0.0, 0.0, 0.0};
+    for( int row=0; row<3; row++ ) {
+      vec1[row] += ( trans_matrix[ (row*4)+0 ] * coords[0]);
+      vec1[row] += ( trans_matrix[ (row*4)+1 ] * coords[num_nodes]);
+      if (3 == dimension) vec1[row] += ( trans_matrix[ (row*4)+2 ] * coords[2*num_nodes]);
+    coords[0] = vec1[0];
+    coords[num_nodes] = vec1[1];
+    coords[2*num_nodes] = vec1[2];
+MBErrorCode WriteCCMIO::write_matsets(MeshInfo & /* mesh_info (commented out to remove warning) */,
+                                      std::vector<WriteCCMIO::MaterialSetData> &matset_data,
+                                      std::vector<WriteCCMIO::NeumannSetData> &/* neuset_data  */,
+                                        // (commented out to remove warning)
+                                      MBRange &verts,
+                                      const int *vgids)
+  std::vector<int> connect;
+  CCMIOID rootID, cellMapID, topologyID, id;
+    // don't usually have anywhere near 31 nodes per element
+  connect.reserve(31);
+  MBRange::const_iterator rit;
+  MBRange all_elems;
+  for (unsigned int i = 0; i < matset_data.size(); i++)
+    all_elems.merge(*(matset_data[i].elements));
+  const int num_elems = all_elems.size();
+  int *egids, minid, maxid;
+  result = get_gids(all_elems, egids, minid, maxid);
+    // Write the cells
+  CCMIOError error;
+  CCMIONewEntity(&error, rootID, kCCMIOMap, "Cell map", &cellMapID);
+  CCMIOWriteMap(&error, cellMapID, CCMIOSIZEC(all_elems.size()),
+                CCMIOSIZEC(maxid), egids,
+  CCMIONewEntity(&error, rootID, kCCMIOTopology, "Topology", &topologyID);
+  CCMIONewEntity(&error, topologyID, kCCMIOCells, "Cells", &id);
+    // get cell types
+  int *ctypes = new int[all_elems.size()];
+  int i = 0;
+  rit = all_elems.begin();
+  for (; i < num_elems; i++, rit++) {
+    ctypes[i] = ccm_types[mbImpl->type_from_handle(*rit)];
+    assert(-1 != ctypes[i]);
+  CCMIOWriteCells(&error, id, cellMapID, ctypes,
+                  CCMIOINDEXC(1), CCMIOINDEXC(num_elems));
+  delete [] ctypes;
+    // Write the faces
+    // first, allocate a tag of length 6 (max # faces per region, except
+    // for polyhedra)
+  MBTag mark_tag;
+  short int def_val = 0;
+  result = mbImpl->tag_create("__mark", 1, MB_TAG_DENSE, MB_TYPE_OPAQUE,
+                              mark_tag, &def_val);
+    mWriteIface->report_error("Couldn't create mark tag.");
+    return result;
+    // now faces
+  unsigned char markt;
+  std::vector<MBEntityHandle> tmp_face_cells, storage;
+  std::vector<int> iface_connect, iface_cells;
+  std::vector<int> eface_connect, eface_cells;
+  MBEntityHandle tmp_connect[MBCN::MAX_NODES_PER_ELEMENT]; // tmp connect vector
+  const MBEntityHandle *connectc; int num_connectc; // cell connectivity
+  const MBEntityHandle *connectf; int num_connectf; // face connectivity
+  i = 0;
+      // if not polyh, get mark
+    MBEntityType etype = TYPE_FROM_HANDLE(*rit);
+    if (MBPOLYHEDRON != etype && MBPOLYGON != etype) {
+      result = mbImpl->tag_get_data(mark_tag, &(*rit), 1, &markt);
+        return result;
+      // get connect
+    result = mbImpl->get_connectivity(*rit, connectc, num_connectc, false, &storage);
+      mWriteIface->report_error("Couldn't get entity connectivity.");
+      return result;
+      // if polyh, write faces directly
+    bool is_polyh = (MBPOLYHEDRON == etype);
+    int num_faces = MBCN::NumSubEntities(etype, 2);
+      // for each face (from MBCN)
+    for (int f = 0; f < num_faces; f++) {
+        // if this face marked, skip
+      if (!is_polyh && ((markt >> f) & 0x1)) continue;
+        // get face connect
+      if (!is_polyh) {
+          // (from MBCN)
+        MBCN::SubEntityConn(connectc, etype, 2, f, tmp_connect, num_connectf);
+        connectf = tmp_connect;
+      else {
+          // get face connectivity
+        result = mbImpl->get_connectivity(connectc[f], connectf, num_connectf, false);
+          mWriteIface->report_error("Couldn't get polyhedron connectivity.");
+          return result;
+        // get adj cells from face connect
+      tmp_face_cells.clear();
+      result = mbImpl->get_adjacencies(connectf, num_connectf, 3, false, tmp_face_cells);
+      if (MB_SUCCESS != result || tmp_face_cells.empty()) {
+        mWriteIface->report_error("Error getting adj hexes.");
+        return result;
+      bool is_internal = (tmp_face_cells.size() == 2);
+      if (!is_polyh && is_internal) {
+          // make sure 1st is forward sense
+        int side_num, sense, offset;
+        MBCN::SideNumber(etype, connectc, connectf, num_connectf,
+                         2, side_num, sense, offset);
+        if (sense == 1 && tmp_face_cells[0] != *rit) {
+          assert(2 == tmp_face_cells.size());
+          MBEntityHandle tmph = tmp_face_cells[0];
+          tmp_face_cells[1] = tmp_face_cells[0];
+          tmp_face_cells[0] = tmph;
+        // get ids of cells in all_elems
+      std::vector<int> *fcells_ptr, *fconnect_ptr;
+      fcells_ptr = (is_internal ? &iface_cells : &eface_cells);
+      fconnect_ptr = (is_internal ? &iface_connect : &eface_connect);
+      fcells_ptr->push_back(egids[all_elems.index(tmp_face_cells[0])]);
+      if (is_internal) fcells_ptr->push_back(egids[all_elems.index(tmp_face_cells[1])]);
+      fconnect_ptr->push_back(num_connectf);
+        // get indices of face vertices, add one
+      for (int fv = 0; fv < num_connectf; fv++)
+        fconnect_ptr->push_back(vgids[verts.index(connectf[fv])]);
+          // mark other cell for this face, if there is another cell
+        MBEntityHandle other_cell = tmp_face_cells[0];
+        const MBEntityHandle *connecto; int num_connecto;
+        if (other_cell == *rit) other_cell = tmp_face_cells[1];
+        result = mbImpl->get_connectivity(other_cell, connecto, num_connecto,
+                                          false, &storage);
+          mWriteIface->report_error("Couldn't get other entity connectivity.");
+          return result;
+          // get side number
+        MBCN::SideNumber(TYPE_FROM_HANDLE(other_cell), connecto, connectf, num_connectf,
+          // set mark for this face
+        short int tmp_mark, tmp_mark2;
+        result = mbImpl->tag_get_data(mark_tag, &other_cell, 1, &tmp_mark);
+          mWriteIface->report_error("Couldn't get mark data for other cell.");
+          return result;
+        tmp_mark2 = 0x1 << (unsigned int)side_num;
+        assert("mark for this side on other entity shouldn't be set already" &&
+               !(tmp_mark & tmp_mark2));
+        tmp_mark |= tmp_mark2;
+        result = mbImpl->tag_set_data(mark_tag, &other_cell, 1, &tmp_mark);
+          mWriteIface->report_error("Couldn't set mark data for other cell.");
+          return result;
+      } // !is_polyh
+    } // loop over faces in elem
+  } // loop over elems
+  int num_ifaces = iface_cells.size()/2,
+      num_efaces = eface_cells.size();
+    // write internal faces
+  CCMIOID mapID;
+  CCMIONewEntity(&error, rootID, kCCMIOMap, NULL, &mapID);
+    // set gids for internal faces
+  if ((int)all_elems.size() < (num_ifaces + num_efaces)) {
+    delete [] egids;
+    egids = new int[num_ifaces + num_efaces];
+  for (int i = 1; i <= (num_ifaces+num_efaces); i++) egids[i-1] = i;
+  CCMIOWriteMap(&error, mapID, CCMIOSIZEC(num_ifaces),
+                CCMIOSIZEC(num_ifaces+num_efaces),
+                &egids[0],
+  CCMIONewEntity(&error, topologyID, kCCMIOInternalFaces, "Internal faces", &id);
+  CCMIOWriteFaces(&error, id, kCCMIOInternalFaces, mapID,
+                  CCMIOSIZEC(iface_connect.size()), &iface_connect[0],
+  CCMIOWriteFaceCells(&error, id, kCCMIOInternalFaces, mapID, &iface_cells[0],
+    // now external faces
+  CCMIOWriteMap(&error, mapID, CCMIOSIZEC(num_efaces),
+                CCMIOSIZEC(num_efaces), &egids[num_ifaces],
+  CCMIONewIndexedEntity(&error, topologyID, kCCMIOBoundaryFaces, 0,
+                        "Boundary faces", &id);
+  CCMIOWriteFaces(&error, id, kCCMIOBoundaryFaces, mapID,
+                  CCMIOSIZEC(eface_connect.size()), &eface_connect[0],
+  CCMIOWriteFaceCells(&error, id, kCCMIOBoundaryFaces, mapID, &eface_cells[0],
+MBErrorCode WriteCCMIO::open_file(const char* filename)
+    // not a valid filname
+  if(strlen((const char*)filename) == 0)
+    mWriteIface->report_error("Output filename not specified");
+    /* template - open file & store somewhere */
+    // file couldn't be opened
+MBErrorCode WriteCCMIO::get_neuset_elems(MBEntityHandle neuset, int current_sense,
+                                         MBRange &forward_elems, MBRange &reverse_elems)
+  MBRange neuset_elems, neuset_meshsets;
+    // get the sense tag; don't need to check return, might be an error if the tag
+    // hasn't been created yet
+  MBTag sense_tag = 0;
+  mbImpl->tag_get_handle("SENSE", sense_tag);
+    // get the entities in this set
+  MBErrorCode result = mbImpl->get_entities_by_handle(neuset, neuset_elems, true);
+  if (MB_FAILURE == result) return result;
+    // now remove the meshsets into the neuset_meshsets; first find the first meshset,
+  MBRange::iterator range_iter = neuset_elems.begin();
+  while (TYPE_FROM_HANDLE(*range_iter) != MBENTITYSET && range_iter != neuset_elems.end())
+    range_iter++;
+    // then, if there are some, copy them into neuset_meshsets and erase from neuset_elems
+  if (range_iter != neuset_elems.end()) {
+    std::copy(range_iter, neuset_elems.end(), mb_range_inserter(neuset_meshsets));
+    neuset_elems.erase(range_iter, neuset_elems.end());
+    // ok, for the elements, check the sense of this set and copy into the right range
+    // (if the sense is 0, copy into both ranges)
+    // need to step forward on list until we reach the right dimension
+  MBRange::iterator dum_it = neuset_elems.end();
+  dum_it--;
+  int target_dim = MBCN::Dimension(TYPE_FROM_HANDLE(*dum_it));
+  dum_it = neuset_elems.begin();
+  while (target_dim != MBCN::Dimension(TYPE_FROM_HANDLE(*dum_it)) &&
+         dum_it != neuset_elems.end())
+    dum_it++;
+  if (current_sense == 1 || current_sense == 0)
+    std::copy(dum_it, neuset_elems.end(), mb_range_inserter(forward_elems));
+  if (current_sense == -1 || current_sense == 0)
+    std::copy(dum_it, neuset_elems.end(), mb_range_inserter(reverse_elems));
+    // now loop over the contained meshsets, getting the sense of those and calling this
+    // function recursively
+  for (range_iter = neuset_meshsets.begin(); range_iter != neuset_meshsets.end(); range_iter++) {
+      // first get the sense; if it's not there, by convention it's forward
+    int this_sense;
+    if (0 == sense_tag ||
+        MB_FAILURE == mbImpl->tag_get_data(sense_tag, &(*range_iter), 1, &this_sense))
+      this_sense = 1;
+      // now get all the entities on this meshset, with the proper (possibly reversed) sense
+    get_neuset_elems(*range_iter, this_sense*current_sense,
+                     forward_elems, reverse_elems);
+  return result;
Added: MOAB/trunk/WriteCCMIO.hpp
--- MOAB/trunk/WriteCCMIO.hpp	                        (rev 0)
+++ MOAB/trunk/WriteCCMIO.hpp	2010-01-29 05:24:00 UTC (rev 3508)
@@ -0,0 +1,196 @@
+// Filename      : WriteCCMIO.hpp
+// Purpose       : ExodusII writer
+// Special Notes : Lots of code taken from verde implementation
+// Creator       : Corey Ernst
+// Date          : 8/02
+// Owner         : Corey Ernst
+#ifndef WRITECCMIO_HPP
+#define WRITECCMIO_HPP
+#error "WriteCCMIO.hpp isn't supposed to be included into an application"
+#endif
+#include <vector>
+#include <string>
+#include "MBWriterIface.hpp"
+#include "ccmio.h"
+class MBWriteUtilIface;
+class MB_DLL_EXPORT WriteCCMIO : public MBWriterIface
+public:
+   //! Constructor
+   WriteCCMIO(MBInterface *impl);
+   //! Destructor
+  virtual ~WriteCCMIO();
+  static MBWriterIface* factory( MBInterface* );
+    //! writes out a file
+  MBErrorCode write_file(const char *file_name,
+                         const bool overwrite,
+                          const MBEntityHandle *output_list,
+                          const std::vector<std::string>& qa_list,
+                          const MBTag* tag_list,
+                          int num_tags,
+                          int export_dimension);
+//! struct used to hold data for each block to be output; used by
+//! initialize_file to initialize the file header for increased speed
+  struct MaterialSetData
+    int id;
+    int number_elements;
+    int number_nodes_per_element;
+    int number_attributes;
+    ExoIIElementType element_type;
+    MBEntityType moab_type;
+    MBRange *elements;
+//! struct used to hold data for each nodeset to be output; used by
+  struct DirichletSetData
+    int id;
+    int number_nodes;
+    std::vector< MBEntityHandle > nodes;
+    std::vector< double > node_dist_factors;
+//! struct used to hold data for each sideset to be output; used by
+  struct NeumannSetData
+    int id;
+    std::vector<MBEntityHandle> elements;
+    std::vector<int> side_numbers;
+    MBEntityHandle mesh_set_handle;
+protected:
+    //! number of dimensions in this file
+  //int number_dimensions();
+    //! open a file for writing
+  MBErrorCode open_file(const char *filename);
+  //! contains the general information about a mesh
+  class MeshInfo
+  public:
+    unsigned int num_dim;
+    unsigned int num_nodes;
+    unsigned int num_elements;
+    unsigned int num_matsets;
+    unsigned int num_dirsets;
+    unsigned int num_neusets;
+    MBRange nodes;
+    MeshInfo()
+        : num_dim(0), num_nodes(0), num_elements(0), num_matsets(0),
+          num_dirsets(0), num_neusets(0)
+private:
+    //! interface instance
+  MBWriteUtilIface* mWriteIface;
+    //! file name
+  std::string fileName;
+    //! Meshset Handle for the mesh that is currently being read
+  MBEntityHandle mCurrentMeshHandle;
+  MBTag mPartitionSetTag;
+  MBTag mMatSetIdTag;
+  MBTag mEntityMark;   //used to say whether an entity will be exported
+  MBErrorCode gather_mesh_information(MeshInfo &mesh_info,
+                                      std::vector<MaterialSetData> &matset_info,
+                                      std::vector<NeumannSetData> &neuset_info,
+                                      std::vector<DirichletSetData> &dirset_info,
+                                      std::vector<MBEntityHandle> &dirsets);
+  MBErrorCode initialize_file(MeshInfo &mesh_info);
+  MBErrorCode write_nodes(CCMIOID rootID, const MBRange& nodes,
+                          const int dimension, int *&vgids);
+    // get global ids for these entities; allocates gids and passes back,
+    // caller is responsible for deleting
+  MBErrorCode get_gids(const MBRange &ents, int *&gids,
+                       int &minid, int &maxid);
+  MBErrorCode write_matsets(MeshInfo &mesh_info,
+                            std::vector<MaterialSetData> &matset_data,
+                            std::vector<NeumannSetData> &neuset_data,
+                            MBRange &verts,
+                            const int *vgids);
+  MBErrorCode get_valid_sides(MBRange &elems, const int sense,
+                              WriteCCMIO::NeumannSetData &neuset_data);
+  void reset_matset(std::vector<MaterialSetData> &matset_info);
+  MBErrorCode get_neuset_elems(MBEntityHandle neuset, int current_sense,
+                               MBRange &forward_elems, MBRange &reverse_elems);
+  MBErrorCode transform_coords(const int dimension, const int num_nodes, double *coords);
+  MBErrorCode write_problem_description(CCMIOID rootID, CCMIOID stateID);
+#endif
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2010-01-28 21:02:20 UTC (rev 3507)
+++ MOAB/trunk/configure.ac	2010-01-29 05:24:00 UTC (rev 3508)
@@ -375,6 +375,23 @@
 fi
+#                             CCMIO OPTIONS
+old_LDFLAGS="$LDFLAGS"
+LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
+FATHOM_CHECK_CCMIO
+LDFLAGS="$old_LDFLAGS"
+if test "xno" != "x$HAVE_CCMIO"; then
+  DEFINES="$DEFINES -DCCMIO_FILE"
+fi
+AM_CONDITIONAL(CCMIO_FILE, [test "xno" != "x$HAVE_CCMIO"])
+AM_CPPFLAGS="$CCMIO_CPPFLAGS $AM_CPPFLAGS"
+EXPORT_LDFLAGS="$CCMIO_LDFLAGS $EXPORT_LDFLAGS"
+AC_SUBST(CCMIO_LIBS)
 #                             NetCDF OPTIONS
Added: MOAB/trunk/m4/ccmio.m4
--- MOAB/trunk/m4/ccmio.m4	                        (rev 0)
+++ MOAB/trunk/m4/ccmio.m4	2010-01-29 05:24:00 UTC (rev 3508)
@@ -0,0 +1,73 @@
+# Check for NetCDF library ((C++)
+# Sets HAVE_NETCDF to 'yes' or 'no'
+# If HAVE_NETCDF == yes, then exports:
+#   NETCDF_CPPFLAGS
+#   NETCDF_LDFLAGS
+#   NETCDF_LIBS
+AC_DEFUN([FATHOM_CHECK_CCMIO],[
+AC_MSG_CHECKING([if CCMIO support is enabled])
+AC_ARG_WITH(ccmio,
+[AC_HELP_STRING([--with-ccmio=DIR], [Specify CCMIO location])
+AC_HELP_STRING([--without-ccmio], [Disable support for CCMIO file format])],
+[CCMIO_ARG=$withval
+DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-ccmio=\"${withval}\""
+, [CCMIO_ARG=])
+if test "xno" = "x$CCMIO_ARG"; then
+  AC_MSG_RESULT([no])
+else
+  AC_MSG_RESULT([yes])
+fi
+ # if CCMIO support is not disabled
+HAVE_CCMIO=no
+if test "xno" != "x$CCMIO_ARG"; then
+  HAVE_CCMIO=yes
+    # if a path is specified, update LIBS and INCLUDES accordingly
+  if test "xyes" != "x$CCMIO_ARG" && test "x" != "x$CCMIO_ARG"; then
+    if test -d "${CCMIO_ARG}/linux/64/lib"; then
+      CCMIO_LDFLAGS="-L${CCMIO_ARG}/linux/64/lib"
+    elif test -d "${CCMIO_ARG}"; then
+      CCMIO_LDFLAGS="-L${CCMIO_ARG}/lib"
+    elif test -d "${CCMIO_ARG}/lib"; then
+      CCMIO_LDFLAGS="-L${CCMIO_ARG}"
+    else
+      AC_MSG_ERROR("$CCMIO_ARG is not a directory.")
+    fi
+    if test -d "${CCMIO_ARG}/include"; then
+      CCMIO_CPPFLAGS="-I${CCMIO_ARG}/include"
+    else
+      CCMIO_CPPFLAGS="-I${CCMIO_ARG}"
+    fi
+  fi
+  old_CPPFLAGS="$CPPFLAGS"
+  CPPFLAGS="$CCMIO_CPPFLAGS $CPPFLAGS"
+  old_LDFLAGS="$LDFLAGS"
+  LDFLAGS="$CCMIO_LDFLAGS $LDFLAGS"
+   # Check for C library
+  AC_CHECK_HEADERS( [ccmio.h], [], [AC_MSG_WARN([[Ccmio header not found.]]); HAVE_CCMIO=no] )
+  AC_CHECK_HEADERS( [ccmioutility.h], [], [AC_MSG_WARN([[Ccmio header not found.]]); HAVE_CCMIO=no] )
+  AC_CHECK_HEADERS( [ccmiocore.h], [], [AC_MSG_WARN([[Ccmio header not found.]]); HAVE_CCMIO=no] )
+  CPPFLAGS="$old_CPPFLAGS"
+  LDFLAGS="$old_LDFLAGS"
+  if test "x$HAVE_CCMIO" = "xno"; then
+    if test "x$CCMIO_ARG" != "x"; then
+      AC_MSG_ERROR("Ccmio not found or not working")
+    else
+      AC_MSG_WARN("Ccmio support disabled")
+    fi
+    CCMIO_CPPFLAGS=
+    CCMIO_LDFLAGS=
+  else
+    CCMIO_LIBS="-lccmio -ladf"
+  fi
+fi
+]) # FATHOM_HAVE_CCMIO
