[MOAB-dev] buildbot failure in Fathom on moab-32bit
    moab-dev at mcs.anl.gov
    Wed Jan 27 00:14:50 CST 2010
The Fathomatic has detected a failed build of moab-32bit on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-32bit/builds/6
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
 c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I. -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DSRCDIR=. -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c WriteGMV.cpp -o WriteGMV.o
mv -f .deps/WriteGMV.Tpo .deps/WriteGMV.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I.    -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=.  -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c -o WriteGmsh.lo WriteGmsh.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I. -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DSRCDIR=. -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c WriteGmsh.cpp -o WriteGmsh.o
mv -f .deps/WriteGmsh.Tpo .deps/WriteGmsh.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I.    -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=.  -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c -o WriteSTL.lo WriteSTL.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I. -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DSRCDIR=. -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c WriteSTL.cpp -o WriteSTL.o
mv -f .deps/WriteSTL.Tpo .deps/WriteSTL.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I.    -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=.  -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c -o WriteTemplate.lo WriteTemplate.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I. -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DSRCDIR=. -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c WriteTemplate.cpp -o WriteTemplate.o
mv -f .deps/WriteTemplate.Tpo .deps/WriteTemplate.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I.    -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=.  -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c -o WriteVtk.lo WriteVtk.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DIS_BUILDING_MB -I. -I./parallel -I. -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DSRCDIR=. -Wall -pipe -O2 -DNDEBUG -m32 -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c WriteVtk.cpp -o WriteVtk.o
mv -f .deps/WriteVtk.Tpo .deps/WriteVtk.Plo
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -O2 -DNDEBUG -m32   -o libMOAB.la -rpath /usr/local/lib AEntityFactory.lo BitTagServer.lo DualTool.lo EntitySequence.lo ExoIIUtil.lo FileOptions.lo FileTokenizer.lo GeomTopoTool.lo GmshUtil.lo HigherOrderFactory.lo HomXform.lo MBAdaptiveKDTree.lo MBAffineXform.lo MBAlloc.lo MBAxisBox.lo MBBSPTree.lo MBCN.lo MBCartVect.lo MBMatrix3.lo MBCore.lo MBFactory.lo MBGeomUtil.lo MBMeshSet.lo MBOrientedBox.lo MBOrientedBoxTreeTool.lo BSPTreePoly.lo MBRange.lo MBRangeSeqIntersectIter.lo MBReadUtil.lo MBReaderWriterSet.lo MBSkinner.lo MBSysUtil.lo MBUtil.lo MBWriteUtil.lo MeshSetSequence.lo MeshTopoUtil.lo PolyElementSeq.lo ReadGmsh.lo ReadSms.lo ReadSTL.lo ReadVtk.lo ReadIDEAS.lo ReadMCNP5.lo ReadNASTRAN.lo ReadABAQUS.lo ReadTetGen.lo ScdElementData.lo ScdVertexData.lo SequenceData.lo SequenceManager.lo SparseTagSuperCollection.lo SparseTagCollection.lo StructuredElementSeq.lo SweptElementData.lo SweptElementSeq.lo SweptVertexDa
 ta.lo TagInfo.lo TagServer.lo Tqdcfr.lo TypeSequenceManager.lo UnstructuredElemSeq.lo VertexSequence.lo VtkUtil.lo WriteAns.lo WriteGMV.lo WriteGmsh.lo WriteSTL.lo WriteTemplate.lo WriteVtk.lo         -lm
mkdir .libs
ar cru .libs/libMOAB.a  AEntityFactory.o BitTagServer.o DualTool.o EntitySequence.o ExoIIUtil.o FileOptions.o FileTokenizer.o GeomTopoTool.o GmshUtil.o HigherOrderFactory.o HomXform.o MBAdaptiveKDTree.o MBAffineXform.o MBAlloc.o MBAxisBox.o MBBSPTree.o MBCN.o MBCartVect.o MBMatrix3.o MBCore.o MBFactory.o MBGeomUtil.o MBMeshSet.o MBOrientedBox.o MBOrientedBoxTreeTool.o BSPTreePoly.o MBRange.o MBRangeSeqIntersectIter.o MBReadUtil.o MBReaderWriterSet.o MBSkinner.o MBSysUtil.o MBUtil.o MBWriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ReadGmsh.o ReadSms.o ReadSTL.o ReadVtk.o ReadIDEAS.o ReadMCNP5.o ReadNASTRAN.o ReadABAQUS.o ReadTetGen.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o SweptElementData.o SweptElementSeq.o SweptVertexData.o TagInfo.o TagServer.o Tqdcfr.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o VtkUtil.o WriteAns.o WriteGMV.o WriteGmsh.o Write
 STL.o WriteTemplate.o WriteVtk.o
ranlib .libs/libMOAB.a
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
./config.status --version | \
	  sed -e 's/.*options "\(.*\)"/\1/p' -e 'd' | \
	  sed -e "s/'[[:space:]]'/'\n'/g" >moab.config
cd . && /bin/sh ./config.status config.h
config.status: creating config.h
config.status: config.h is unchanged
Making all in test
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-32bit/build/test'
Making all in dual
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-32bit/build/test/dual'
make[4]: Nothing to be done for `all'.
Making all in h5file
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-32bit/build/test/h5file'
Making all in obb
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-32bit/build/test/obb'
Making all in perf
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-32bit/build/test/perf'
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -I. -I../.. -I../../parallel -I../.. -I../../mhdf/include -I../.. -I../../tools/iMesh -I../../tools/iMesh  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -m32 -MT point_in_elem.o -MD -MP -MF .deps/point_in_elem.Tpo -c -o point_in_elem.o point_in_elem.cpp
mv -f .deps/point_in_elem.Tpo .deps/point_in_elem.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -O2 -DNDEBUG -m32   -o point_in_elem point_in_elem.o ../../libMOAB.la -lm
mkdir .libs
c++ -Wall -pipe -O2 -DNDEBUG -m32 -o point_in_elem point_in_elem.o  ../../.libs/libMOAB.a -lm
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.2.4/libstdc++.so when searching for -lstdc++
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.2.4/libstdc++.a when searching for -lstdc++
/usr/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
sincerely,
 -The Fathomatic
