[MOAB-dev] r3431 - MOAB/trunk
Tim Tautges
tautges at mcs.anl.gov
Mon Jan 18 12:00:54 CST 2010
Whew, thanks. There goes my thought of how to implement unit tests. I though other codes did this sort of thing too -
what do you do about unit tests in msq?
- tim
kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2010-01-18 11:52:33 -0600 (Mon, 18 Jan 2010)
> New Revision: 3431
> Modified:
> MOAB/trunk/Tqdcfr.cpp
> MOAB/trunk/Tqdcfr.hpp
> Log:
> Fix memory corruption in tqdcfr test (two redundant fixes for the same problem).
> The problem:
> Tqdcfr.cpp contains both the implementation of MOAB's cub file reader and
> some test code. The test code is wrapped within a #ifdef TEST_TQDCFR
> block. When the test is compiled and linked to libmoab.so the resulting
> executable ends up with two copies of the Tqdcfr implementation: one from
> MOAB and one from the test .o file. When libmoab is a static library this
> isn't a problem. The linker will never pull in MOAB's Tqdcfr.o from the
> static library because it doesn't require it to resolve any symbols (all
> symbols already defined in the test .o.) This is not the case for a shared
> library, where the .so is either used entirely or not at all. The duplicate
> code isn't really an issue in that case either as long as both copies are
> the same. However, Tqdcfr also declares some static instances of std::string.
> That's where things go wrong. The resulting test executable ends up with
> two instances of the static string with the same symbol name and two registered
> exit handlers to clean up the statics (one form the .so and one from the
> main.) These both end up trying to free the same instance of the static
> string, resulting in memory corruption.
> The 1st implemented solution: Use const char* defined in .cpp file rather
> than std::string for string constants so no exit-time cleanup is required.
> The 2nd implemented solution: Wrap main body of Tqdcfr.cpp in
> #ifndef TEST_TQDCFR to avoid object code duplication.
> The best solution (not implemented) is probably to just put the test code in
> its own .cpp file.
> Modified: MOAB/trunk/Tqdcfr.cpp
> --- MOAB/trunk/Tqdcfr.cpp 2010-01-16 00:07:47 UTC (rev 3430)
> +++ MOAB/trunk/Tqdcfr.cpp 2010-01-18 17:52:33 UTC (rev 3431)
> @@ -16,12 +16,16 @@
> #include "Tqdcfr.hpp"
> #include "MBCore.hpp"
> #include "MBRange.hpp"
> +#include "FileOptions.hpp"
> +#include <iostream>
> +#ifndef TEST_TQDCFR
> #include "MBReadUtilIface.hpp"
> #include "GeomTopoTool.hpp"
> #include "MBTagConventions.hpp"
> #include "MBCN.hpp"
> #include "MBInternals.hpp"
> -#include "FileOptions.hpp"
> #include "HigherOrderFactory.hpp"
> #include "exodus_order.h"
> @@ -29,7 +33,6 @@
> #include "MBmpi.h"
> #endif
> -#include <iostream>
> #include <sstream>
> #include <assert.h>
> @@ -91,8 +94,8 @@
> // moab_conn[ cub_hex27_order[i] ] = cubit_conn[ i ];
> const int* const* const* const cub_elem_order_map = exodus_elem_order_map;
> -std::string Tqdcfr::BLOCK_NODESET_OFFSET_TAG_NAME = "BLOCK_NODESET_OFFSET";
> -std::string Tqdcfr::BLOCK_SIDESET_OFFSET_TAG_NAME = "BLOCK_SIDESET_OFFSET";
> +const char *const BLOCK_NODESET_OFFSET_TAG_NAME = "BLOCK_NODESET_OFFSET";
> +const char *const BLOCK_SIDESET_OFFSET_TAG_NAME = "BLOCK_SIDESET_OFFSET";
> #define RR if (MB_SUCCESS != result) return result
> @@ -400,7 +403,7 @@
> // set, we don't need to convert
> unsigned int nodeset_offset, sideset_offset;
> MBTag tmp_tag;
> - MBErrorCode result = mdbImpl->tag_get_handle(BLOCK_NODESET_OFFSET_TAG_NAME.c_str(),
> + MBErrorCode result = mdbImpl->tag_get_handle(BLOCK_NODESET_OFFSET_TAG_NAME,
> tmp_tag);
> if (MB_SUCCESS != result) nodeset_offset = 0;
> else {
> @@ -408,7 +411,7 @@
> if (MB_SUCCESS != result) return result;
> - result = mdbImpl->tag_get_handle(BLOCK_SIDESET_OFFSET_TAG_NAME.c_str(),
> + result = mdbImpl->tag_get_handle(BLOCK_SIDESET_OFFSET_TAG_NAME,
> tmp_tag);
> if (MB_SUCCESS != result) sideset_offset = 0;
> else {
> @@ -2571,7 +2574,8 @@
> return mdbImpl->create_meshset( flags, h );
> -#ifdef TEST_TQDCFR
> +// #ifdef TEST_TQDCFR
> +#else
> #include "testdir.h"
> Modified: MOAB/trunk/Tqdcfr.hpp
> --- MOAB/trunk/Tqdcfr.hpp 2010-01-16 00:07:47 UTC (rev 3430)
> +++ MOAB/trunk/Tqdcfr.hpp 2010-01-18 17:52:33 UTC (rev 3431)
> @@ -336,9 +336,6 @@
> Tqdcfr(MBInterface *impl);
> - static std::string BLOCK_NODESET_OFFSET_TAG_NAME;
> - static std::string BLOCK_SIDESET_OFFSET_TAG_NAME;
> MBErrorCode create_set( MBEntityHandle& h, unsigned int flags = MESHSET_SET );
> private:
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
