[MOAB-dev] MOAB nightly snapshots and other Buildbot news
    James Porter
    jvporter at wisc.edu
    Fri Dec 18 16:18:11 CST 2009
On Fri, 2009-12-18 at 13:51 -0600, Tim Tautges wrote:
> On the general note of warnings, going forward let this be notice that we should do whatever we can to remove the
> warnings, even if the resulting expression/statement doesn't seem otherwise necessary.  I can't imagine this costing
> anything in terms of runtime; when I've done this in the code, I usually put a comment to that effect above the
> offending statement or construct.
Note to anyone going on warning-hunts: don't worry too much about the
libtool warnings in moab-distcheck. I'm pretty sure that's just a
consequence of how autotools works, and I'm probably doing to set it to
ignore those warnings.
- Jim
