[MOAB-dev] MOAB check for *x86* failed.
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Thu Dec 17 14:40:43 CST 2009
I upgraded libc recently on my workstation, but did not update the error
suppressions for valgrind.  This resulted in the tests failing due to
valgrind "errors" within libc.
- jason
On 12/17/2009 03:12 AM, Nightly Test wrote:
> make  check-recursive
> make[1]: Entering directory `/home/jason/moab/test/x86'
> Making check in mhdf
> make[2]: Entering directory `/home/jason/moab/test/x86/mhdf'
> make[2]: Nothing to be done for `check'.
> make[2]: Leaving directory `/home/jason/moab/test/x86/mhdf'
> Making check in .
> make[2]: Entering directory `/home/jason/moab/test/x86'
> make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test exodus_test gmsh_test nastran_test stl_test mbcn_test bsp_tree_poly_test kd_tree_tool kd_tree_time
> make[3]: Entering directory `/home/jason/moab/test/x86'
> make[3]: `homxform_test' is up to date.
> make[3]: `scdseq_test' is up to date.
> make[3]: `tqdcfr' is up to date.
> make[3]: `test_adj' is up to date.
> make[3]: `seq_man_test' is up to date.
> make[3]: `geom_util_test' is up to date.
> make[3]: `xform_test' is up to date.
> make[3]: `obb_test' is up to date.
> make[3]: `vtk_test' is up to date.
> make[3]: `adaptive_kd_tree_tests' is up to date.
> make[3]: `bsp_tree_test' is up to date.
> make[3]: `file_options_test' is up to date.
> make[3]: `kd_tree_test' is up to date.
> make[3]: `var_len_test' is up to date.
> make[3]: `var_len_test_no_template' is up to date.
> make[3]: `tag_test' is up to date.
> make[3]: `mesh_set_test' is up to date.
> make[3]: `cub_file_test' is up to date.
> make[3]: `exodus_test' is up to date.
> make[3]: `gmsh_test' is up to date.
> make[3]: `nastran_test' is up to date.
> make[3]: `stl_test' is up to date.
> make[3]: `mbcn_test' is up to date.
> make[3]: `bsp_tree_poly_test' is up to date.
> make[3]: `kd_tree_tool' is up to date.
> make[3]: `kd_tree_time' is up to date.
> make[3]: Leaving directory `/home/jason/moab/test/x86'
> make  check-TESTS
> ==15064== Conditional jump or move depends on uninitialised value(s)
> ==15064==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==
> ==15064==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==
> ==15064==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==
> ==15064==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==
> ==15064==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15064==
> Size of mConnMap = 10512
> Size of mUpConnMap = 59904
> Size of MBCN = 1
> MB TEST PROGRAM:
>     mb_adjacent_vertex_test: Success
>     mb_adjacencies_test: Success
>     mb_adjacencies_create_delete_test: Success
>     mb_upward_adjacencies_test: Success
>     mb_vertex_coordinate_test: Success
>     mb_vertex_tag_test: Success
>     mb_bar_connectivity_test: Success
>     mb_tri_connectivity_test: Success
>     mb_quad_connectivity_test: Success
>     mb_tet_connectivity_test: Success
>     mb_temporary_test: Success
>     mb_hex_connectivity_test: Success
>     mb_mesh_sets_set_test: Success
>     mb_mesh_sets_list_test: Success
>     mb_mesh_set_parent_child_test: Success
>     mb_mesh_set_set_appends: Success
>     mb_mesh_set_list_appends: Success
>     mb_mesh_set_root_appends: Success
>     mb_mesh_set_set_replace_test: Success
>     mb_mesh_set_list_replace_test: Success
>     mb_mesh_set_flag_test: Success
>     mb_tags_test: Success
>     mb_dense_tag_test: Success
>     mb_sparse_tag_test: Success
>     mb_write_mesh_test: Success
>     mb_delete_mesh_test: Success
>     mb_meshset_tracking_test: Success
>     mb_higher_order_test: Success
>     mb_bit_tags_test: Success
>     mb_entity_conversion_test: Success
>     mb_forced_adjacencies_test: Success
>     mb_canon_number_test: Success
>     mb_poly_test: Success
>     mb_range_test: Success
>     mb_range_erase_test: Success
>     mb_topo_util_test: Success
>     mb_split_test: Success
>     mb_range_seq_intersect_test: Success
>     mb_poly_adjacency_test: Success
>     mb_memory_use_test: Success
>     mb_skin_curve_test: Success
>     mb_skin_curve_adj_test: Success
>     mb_skin_surface_test: Success
>     mb_skin_surface_adj_test: Success
>     mb_skin_volume_test: Success
>     mb_skin_volume_adj_test: Success
>     mb_skin_surf_verts_test: Success
>     mb_skin_vol_verts_test: Success
>     mb_skin_surf_verts_elems_test: Success
>     mb_skin_vol_verts_elems_test: Success
>     mb_skin_poly_test: Success
>     mb_skin_higher_order_faces_test: Success
>     mb_skin_higher_order_regions_test: Success
>     mb_skin_adj_higher_order_faces_test: Success
>     mb_skin_adj_higher_order_regions_test: Success
>     mb_skin_faces_reversed_test: Success
>     mb_skin_adj_faces_reversed_test: Success
>     mb_skin_regions_reversed_test: Success
>     mb_skin_adj_regions_reversed_test: Success
>     mb_skin_faces_subset_test: Success
>     mb_skin_adj_faces_subset_test: Success
>     mb_skin_regions_subset_test: Success
>     mb_skin_adj_regions_subset_test: Success
>     mb_skin_faces_full_test: Success
>     mb_skin_adj_faces_full_test: Success
>     mb_skin_regions_full_test: Success
>     mb_skin_adj_regions_full_test: Success
>     mb_read_fail_test: Success
>     mb_enum_string_test: Success
>     mb_merge_update_test: Success
>     mb_merge_test: ---Starting Merge Tests---
> ---Testing:"test/cell1.gen"---
> Loaded test/cell1.gen
> ---Testing:"test/cell2.gen"---
> Loaded test/cell2.gen
> num hexes = 28
> fl = 68 rl = 0
> nodes.size() = 72
> ---Success---
> coin_nodes.size() = 13
> TIME: 1254.04 seconds.
> Success
>     mb_stress_test:     Beginning Stress Test . . .
>          Reading elements
>          Read 256000 entities in 3.4 seconds
>          at 75294.1 elements per second.
>          Transforming and copying elements
>          Transformed and created 256000 entities in 12.6 seconds
>          Creating meshset
>          Created meshset with 512000 entities in 0 seconds
>          Writing 512K element file . . .
>          Wrote file with 512000 entities in 26.04 seconds
>          Total time: 42.06 seconds.
> Success
> MB TEST SUMMARY:
>     Number Tests:           72
>     Number Successful:      72
>     Number Failed:          0
> FAIL: moab_test
> ==15071== Conditional jump or move depends on uninitialised value(s)
> ==15071==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==
> ==15071==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==
> ==15071==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==
> ==15071==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==
> ==15071==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15071==
> All tests passed.
> FAIL: homxform_test
> ==15078== Conditional jump or move depends on uninitialised value(s)
> ==15078==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==
> ==15078==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==
> ==15078==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==
> ==15078==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==
> ==15078==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15078==
> All tests passed.
> FAIL: scdseq_test
> ==15085== Conditional jump or move depends on uninitialised value(s)
> ==15085==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==
> ==15085==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==
> ==15085==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==
> ==15085==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==
> ==15085==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15085==
> Usage: tqdcfr<cub_file_name>
> Success.
> Success.
> FAIL: tqdcfr
> ==15092== Conditional jump or move depends on uninitialised value(s)
> ==15092==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==
> ==15092==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==
> ==15092==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==
> ==15092==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==
> ==15092==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15092==
> FAIL: test_adj
> ==15099== Conditional jump or move depends on uninitialised value(s)
> ==15099==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==
> ==15099==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==
> ==15099==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==
> ==15099==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==
> ==15099==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15099==
> Running test_basic ...
> Running test_lower_bound ...
> Running test_upper_bound ...
> Running test_find ...
> Running test_get_entities ...
> Running test_insert_sequence_merge ...
> Running test_insert_sequence_nomerge ...
> Running test_remove_sequence ...
> Running test_replace_subsequence ...
> Running test_erase ...
> Running test_find_free_handle ...
> Running test_find_free_sequence ...
> Running test_is_free_sequence ...
> Running regression_svn1952 ...
> Running regression_svn1958 ...
> Running regression_svn1960 ...
> ALL TESTS PASSED
> FAIL: seq_man_test
> ==15106== Conditional jump or move depends on uninitialised value(s)
> ==15106==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==
> ==15106==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==
> ==15106==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==
> ==15106==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==
> ==15106==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15106==
> Running test_box_plane_overlap ...
> Running test_box_linear_elem_overlap_tri ...
> Running test_box_linear_elem_overlap_tet ...
> Running test_box_linear_elem_overlap_hex ...
> Running test_box_tri_overlap ...
> Running test_box_tet_overlap ...
> Running test_box_hex_overlap ...
> Running test_ray_tri_intersect ...
> Running test_closest_location_on_tri ...
> Running test_closest_location_on_polygon ...
> Running test_segment_box_intersect ...
> Running test_closest_location_on_box ...
> FAIL: geom_util_test
> ==15113== Conditional jump or move depends on uninitialised value(s)
> ==15113==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==
> ==15113==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==
> ==15113==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==
> ==15113==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==
> ==15113==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15113==
> FAIL: xform_test
> ==15120== Conditional jump or move depends on uninitialised value(s)
> ==15120==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==
> ==15120==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==
> ==15120==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==
> ==15120==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==
> ==15120==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15120==
> FAIL: obb_test
> ==15127== Conditional jump or move depends on uninitialised value(s)
> ==15127==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==
> ==15127==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==
> ==15127==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==
> ==15127==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==
> ==15127==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15127==
> Testing edge2...
> Testing edge3...
> Testing tri3...
> Testing tri6...
> Testing quad4...
> Testing quad8...
> Testing quad9...
> Testing polygon...
> Testing tet4...
> Testing tet10...
> Testing hex8...
> Testing hex20...
> Testing hex27...
> Testing wedge...
> Testing wedge15...
> Testing pyramid...
> Testing pyramid13...
> Testing structured_points_2d...
> Testing structured_grid_2d...
> Testing rectilinear_grid_2d...
> Testing structured_points_3d...
> Testing structured_grid_3d...
> Testing rectilinear_grid_3d...
> Testing scalar_attrib_1_bit...
> Testing scalar_attrib_1_uchar...
> Testing scalar_attrib_1_char...
> Testing scalar_attrib_1_ushort...
> Testing scalar_attrib_1_short...
> Testing scalar_attrib_1_uint...
> Testing scalar_attrib_1_int...
> Testing scalar_attrib_1_ulong...
> Testing scalar_attrib_1_long...
> Testing scalar_attrib_1_float...
> Testing scalar_attrib_1_double...
> Testing scalar_attrib_4_bit...
> Testing scalar_attrib_4_uchar...
> Testing scalar_attrib_4_char...
> Testing scalar_attrib_4_ushort...
> Testing scalar_attrib_4_short...
> Testing scalar_attrib_4_uint...
> Testing scalar_attrib_4_int...
> Testing scalar_attrib_4_ulong...
> Testing scalar_attrib_4_long...
> Testing scalar_attrib_4_float...
> Testing scalar_attrib_4_double...
> Testing vector_attrib_bit...
> Testing vector_attrib_uchar...
> Testing vector_attrib_char...
> Testing vector_attrib_ushort...
> Testing vector_attrib_short...
> Testing vector_attrib_uint...
> Testing vector_attrib_int...
> Testing vector_attrib_ulong...
> Testing vector_attrib_long...
> Testing vector_attrib_float...
> Testing vector_attrib_double...
> Testing tensor_attrib_uchar...
> Testing tensor_attrib_char...
> Testing tensor_attrib_ushort...
> Testing tensor_attrib_short...
> Testing tensor_attrib_uint...
> Testing tensor_attrib_int...
> Testing tensor_attrib_ulong...
> Testing tensor_attrib_long...
> Testing tensor_attrib_float...
> Testing tensor_attrib_double...
> Testing subset...
> 67 tests passed
> FAIL: vtk_test
> ==15134== Conditional jump or move depends on uninitialised value(s)
> ==15134==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==
> ==15134==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==
> ==15134==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==
> ==15134==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==
> ==15134==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15134==
> Running leaf_iterator_test ...
> Running test_build_tree_bisect_triangles ...
> Running test_closest_triangle ...
> Running test_sphere_intersect_triangles ...
> Running test_ray_intersect_triangles ...
> Running test_tree_merge_nodes ...
> Running test_leaf_volume ...
> Running test_leaf_sibling ...
> Running test_leaf_intersects_plane ...
> Running test_leaf_intersects_ray ...
> FAIL: adaptive_kd_tree_tests
> ==15141== Conditional jump or move depends on uninitialised value(s)
> ==15141==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==
> ==15141==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==
> ==15141==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==
> ==15141==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==
> ==15141==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15141==
> Running test_set_plane ...
> Running test_iterator ...
> Running test_box_iterator ...
> Running test_tree_create ...
> Running test_box_tree_create ...
> Running test_leaf_containing_point_bounded_tree ...
> Running test_leaf_containing_point_unbounded_tree ...
> Running test_merge_leaf ...
> Running test_box_iter_neighbors ...
> Running test_leaf_volume_box ...
> Running test_leaf_volume_gen ...
> Running test_leaf_splits_intersects ...
> Running test_box_leaf_intersects_ray ...
> Running test_gen_leaf_intersects_ray ...
> Running test_leaf_polyhedron ...
> FAIL: bsp_tree_test
> ==15148== Conditional jump or move depends on uninitialised value(s)
> ==15148==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==
> ==15148==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==
> ==15148==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==
> ==15148==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==
> ==15148==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15148==
> FAIL: file_options_test
> ==15155== Conditional jump or move depends on uninitialised value(s)
> ==15155==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==
> ==15155==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==
> ==15155==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==
> ==15155==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==
> ==15155==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15155==
> FAIL: kd_tree_test
> ==15162== Conditional jump or move depends on uninitialised value(s)
> ==15162==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==
> ==15162==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==
> ==15162==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==
> ==15162==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==
> ==15162==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15162==
> Running test_valid_struct ...
> Running test_inline ...
> Running test_non_inline ...
> Running test_resize_ii ...
> Running test_resize_in ...
> Running test_resize_ni ...
> Running test_resize_nn ...
> FAIL: var_len_test
> ==15169== Conditional jump or move depends on uninitialised value(s)
> ==15169==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==
> ==15169==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==
> ==15169==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==
> ==15169==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==
> ==15169==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15169==
> FAIL: var_len_test_no_template
> ==15176== Conditional jump or move depends on uninitialised value(s)
> ==15176==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==
> ==15176==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==
> ==15176==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==
> ==15176==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==
> ==15176==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15176==
> Running test_create_tag ...
> Running test_invalid_tag_size ...
> Running test_get_set_sparse_int ...
> Running test_get_set_dense_int ...
> Running test_get_set_dense_double ...
> Running test_get_set_bit ...
> Running test_get_by_tag ...
> Running test_get_by_tag_value ...
> Running test_mesh_value ...
> Running test_get_pointers_sparse ...
> Running test_get_pointers_dense ...
> Running test_set_pointers_sparse ...
> Running test_set_pointers_dense ...
> Running test_get_entity_tags ...
> Running test_delete_sparse_tag ...
> Running test_delete_dense_tag ...
> Running test_delete_mesh_tag ...
> Running test_delete_sparse_data ...
> Running test_delete_dense_data ...
> Running test_delete_bit_data ...
> Running test_create_variable_length_tag ...
> Running test_get_set_variable_length_sparse ...
> Running test_get_set_variable_length_dense ...
> Running test_get_set_variable_length_mesh ...
> Running test_get_ents_with_default_value ...
> Running test_bit_tag_big ...
> Running regression_one_entity_by_var_tag ...
> Running regression_tag_on_nonexistent_entity ...
> FAIL: tag_test
> ==15183== Conditional jump or move depends on uninitialised value(s)
> ==15183==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==
> ==15183==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==
> ==15183==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==
> ==15183==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==
> ==15183==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15183==
> Running test_add_entities_ordered ...
> Running test_add_entities_set ...
> Running test_add_entities_ordered_tracking ...
> Running test_add_entities_set_tracking ...
> Running test_remove_entities_ordered ...
> Running test_remove_entities_set ...
> Running test_remove_entities_ordered_tracking ...
> Running test_remove_entities_set_tracking ...
> Running test_entities_by_type_ordered ...
> Running test_entities_by_type_set ...
> Running test_entities_by_dim_ordered ...
> Running test_entities_by_dim_set ...
> Running test_subtract_set_set ...
> Running test_subtract_set_ordered ...
> Running test_subtract_ordered_set ...
> Running test_subtract_ordered_ordered ...
> Running test_subtract_set_set_tracking ...
> Running test_subtract_set_ordered_tracking ...
> Running test_subtract_ordered_set_tracking ...
> Running test_subtract_ordered_ordered_tracking ...
> Running test_itersect_set_set ...
> Running test_itersect_set_ordered ...
> Running test_itersect_ordered_set ...
> Running test_itersect_ordered_ordered ...
> Running test_itersect_set_set_tracking ...
> Running test_itersect_set_ordered_tracking ...
> Running test_itersect_ordered_set_tracking ...
> Running test_itersect_ordered_ordered_tracking ...
> Running test_unite_set_set ...
> Running test_unite_set_ordered ...
> Running test_unite_ordered_set ...
> Running test_unite_ordered_ordered ...
> Running test_unite_set_set_tracking ...
> Running test_unite_set_ordered_tracking ...
> Running test_unite_ordered_set_tracking ...
> Running test_unite_ordered_ordered_tracking ...
> Running test_contains_entities_ordered ...
> Running test_contains_entities_set ...
> Running test_clear_ordered ...
> Running test_clear_set ...
> Running test_clear_ordered_tracking ...
> Running test_clear_set_tracking ...
> ALL TESTS PASSED
> FAIL: mesh_set_test
> ==15190== Conditional jump or move depends on uninitialised value(s)
> ==15190==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==
> ==15190==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==
> ==15190==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==
> ==15190==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==
> ==15190==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15190==
> Running test_vertices ...
> Running test_edges ...
> Running test_quads ...
> Running test_hexes ...
> Running test_geometric_topology ...
> Running test_geometric_sets ...
> Running test_blocks ...
> Running test_side_sets ...
> Running test_node_sets ...
> Running test_tri6 ...
> Running test_tri7 ...
> Running test_quad5 ...
> Running test_quad8 ...
> Running test_quad9 ...
> Running test_tet8 ...
> Running test_tet10 ...
> Running test_tet14 ...
> Running test_hex9 ...
> Running test_hex20 ...
> Running test_hex27 ...
> Running test_multiple_files ...
> FAIL: cub_file_test
> ==15197== Conditional jump or move depends on uninitialised value(s)
> ==15197==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==
> ==15197==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==
> ==15197==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==
> ==15197==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==
> ==15197==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15197==
> Running test_types ...
> Running test_read_tri6_side ...
> Running test_read_shell_side ...
> Running test_read_shell_edge ...
> Running test_read_hex20_side ...
> Running test_read_block_ids ...
> Running test_read_sideset_ids ...
> Running test_read_nodeset_ids ...
> FAIL: exodus_test
> ==15204== Conditional jump or move depends on uninitialised value(s)
> ==15204==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==
> ==15204==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==
> ==15204==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==
> ==15204==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==
> ==15204==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15204==
> Running test_read_nodes ...
> Running test_read_quads ...
> Running test_read_material_set ...
> Running test_read_geom_set ...
> FAIL: gmsh_test
> ==15211== Conditional jump or move depends on uninitialised value(s)
> ==15211==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==
> ==15211==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==
> ==15211==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==
> ==15211==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==
> ==15211==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15211==
> Running test_read_tets ...
> Running test_read_prisms ...
> Running test_read_hexes ...
> Running test_read_material_set1 ...
> Running test_read_material_set2 ...
> FAIL: nastran_test
> ==15218== Conditional jump or move depends on uninitialised value(s)
> ==15218==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==
> ==15218==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==
> ==15218==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==
> ==15218==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==
> ==15218==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15218==
> Running test_read_ascii ...
> Running test_write_ascii ...
> Running test_type_option ...
> Running test_detect_type ...
> Running test_endian_option ...
> Running test_big_endian ...
> Running test_little_endian ...
> Running test_detect_byte_order ...
> FAIL: stl_test
> ==15225== Conditional jump or move depends on uninitialised value(s)
> ==15225==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==
> ==15225==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==
> ==15225==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==
> ==15225==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==
> ==15225==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15225==
> Running test_dimension_pair ...
> Running test_type_names ...
> Running test_dimension ...
> Running test_vertices_per_entity ...
> Running test_num_sub_entities ...
> Running test_sub_entity_type_vtx ...
> Running test_sub_entity_type_edge ...
> Running test_sub_entity_type_tri ...
> Running test_sub_entity_type_quad ...
> Running test_sub_entity_type_tet ...
> Running test_sub_entity_type_pyr ...
> Running test_sub_entity_type_pri ...
> Running test_sub_entity_type_knife ...
> Running test_sub_entity_type_hex ...
> Running test_sub_entity_indices_vtx ...
> Running test_sub_entity_indices_edge ...
> Running test_sub_entity_indices_tri ...
> Running test_sub_entity_indices_quad ...
> Running test_sub_entity_indices_tet ...
> Running test_sub_entity_indices_pyr ...
> Running test_sub_entity_indices_pri ...
> Running test_sub_entity_indices_hex ...
> Running test_side_number_tri ...
> Running test_side_number_quad ...
> Running test_side_number_tet ...
> Running test_side_number_pyr ...
> Running test_side_number_pri ...
> Running test_side_number_hex ...
> Running test_opposite_side_tri ...
> Running test_opposite_side_quad ...
> Running test_opposite_side_tet ...
> Running test_opposite_side_hex ...
> Running test_has_mid_nodes_edge ...
> Running test_has_mid_nodes_tri ...
> Running test_has_mid_nodes_quad ...
> Running test_has_mid_nodes_tet ...
> Running test_has_mid_nodes_pyr ...
> Running test_has_mid_nodes_pri ...
> Running test_has_mid_nodes_knife ...
> Running test_has_mid_nodes_hex ...
> Running test_sub_entity_nodes_tri_edges ...
> Running test_sub_entity_nodes_quad_edges ...
> Running test_sub_entity_nodes_tet_edges ...
> Running test_sub_entity_nodes_tet_faces ...
> Running test_sub_entity_nodes_pyr_edges ...
> Running test_sub_entity_nodes_pyr_faces ...
> Running test_sub_entity_nodes_pri_edges ...
> Running test_sub_entity_nodes_pri_faces ...
> Running test_sub_entity_nodes_kni_edges ...
> Running test_sub_entity_nodes_kni_faces ...
> Running test_sub_entity_nodes_hex_edges ...
> Running test_sub_entity_nodes_hex_faces ...
> Running test_ho_node_parent ...
> Running test_ho_node_index ...
> FAIL: mbcn_test
> ==15232== Conditional jump or move depends on uninitialised value(s)
> ==15232==    at 0x440C93C: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==    by 0x44043A0: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==    by 0x4417680: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==    by 0x4401258: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==    by 0x4400816: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==
> ==15232==    at 0x440C983: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==
> ==15232==    at 0x440CD85: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==
> ==15232==    at 0x440C21B: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==    by 0x4404186: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==
> ==15232==    at 0x440C223: (within /emul/ia32-linux/lib/ld-2.9.so)
> ==15232==
> Running test_construct_from_hex ...
> Running test_cut_with_plane ...
> Running test_volume ...
> FAIL: bsp_tree_poly_test
> 25 of 25 tests failed
> make[3]: *** [check-TESTS] Error 1
> make[2]: *** [check-am] Error 2
> make[2]: Leaving directory `/home/jason/moab/test/x86'
> make[1]: *** [check-recursive] Error 1
> make[1]: Leaving directory `/home/jason/moab/test/x86'
> make: *** [check] Error 2
