[MOAB-dev] Entity picking
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Dec 14 09:29:35 CST 2009
Roman Putanowicz wrote:
> Hi Everybody,
> I would like to ask you for advice.
> The task is: given a point position find mesh cell containing
> that point (or cells in case of boundary point). I understand
> that there is a delicacy in the above due to the inexact nature
> of geometric queries in double precision arithmetic, but approximate
> solution based on some arbitrary tolerance will do.
> The question is how the above could be solved using MOAB?
> Looking at the class list I noticed MBOrientedBoxTreeTool,
> MBAdaptiveKDTree, MBBSPTree classes which probably could be used
> for that purpose. (MBCoupler??). The answer depends for sure on
> the context -- at the moment I need to pick elements in medium
> to small size, unstructured polygonal meshes in 2D.
MBAdaptiveKDTree is likely the best choice for this. However, it currently
doesn't work for general polygons (it will work for triangles and
quadrilaterals). The box_elem_overlap function in MBGeomUtil.cpp needs to
handle the general polygon case.
> I will be grateful for any advice or code snippet if somebody has any.
// build tree
MBRange polygons;
MBErrorCode rval;
rval = moab_instance->get_entities_by_type( 0, MBPOLYGON, polygons );
if (MB_SUCCESS != rval) ...
MBAdaptiveKDTreeTool tool( moab_instance );
MBEntityHandle tree_root;
rval = tool.build_tree( polygons, tree_root );
// get some polygons near a point P
MBEntityHandle poly_set;
rval = tool.leaf_containing_point( tree_root, P, poly_set );
// or perhaps:
// std::vector<MBEntityHandle> poly_sets;
// rval = tool.leaves_within_distance( tree_root, P, epsilon, poly_sets );
if (MB_SUCESS != rval) ...
polygons.clear();
rval = moab_instance->get_entities_by_handle( poly_set, polygons );
// test each polygon to see if it contains the point
std::vector<double> coords;
for (MBRange::iterator i = polygons.begin(); i != polygons.end(); ++i)
const MBEntityHandle* conn;
int len;
rval = moab_instance->get_connectivity( *i, conn, len );
coords.resize( 3*len );
rval = moab_instance->coords( conn, len, &coords[0] );
