[MOAB-dev] Question about moab.make
    Jed Brown
    jed at 59A2.org
    Mon Dec 14 00:37:08 CST 2009
On Sun, 13 Dec 2009 19:53:19 -0600, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> I'm writing some parallel benchmarking tests for moab as MOAB-based
> stand-alone applications
> (similar to tools like mbperf etc).
> My question is what the standard build process for these should be?
> It appears that a Makefile for MOAB-based apps could be constructed by
> simply including ${MOAB_PREFIX}/lib/moab.make,
> where ${MOAB_PREFIX} is the install prefix specified at configure time.
> However, the first two lines of moab.make seem a little puzzling to me:
> MOAB_LIBDIR = /home/karpeev/sharp/moab/trunk/.libs
> MOAB_INCLUDEDIR = /home/karpeev/sharp/moab/trunk
> -I/home/karpeev/sharp/moab/trunk
> In particular, they refer to the source tree under 'trunk' and, as I
> understand it, this is subject to change according to other
> configurations etc.
> Am I missing anything?
That crap is just hanging around, it's not actually being used because
the last two lines of that file replace those variables with paths in
$PREFIX.
Jed
