[MOAB-dev] buildbot failure in Fathom on moab-par
    donotreply at mcs.anl.gov
    Sat Dec 12 00:05:03 CST 2009
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/3
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist: []
BUILD FAILED: failed test
LOG EXCERPT:
errmem.h:52: warning: 'void buffer_reserve_(buffer*, size_t, const char*)' defined but not used
errmem.h:61: warning: 'void buffer_free(buffer*)' defined but not used
errmem.h:48: warning: 'void buffer_init_(buffer*, size_t, const char*)' defined but not used
./errmem.h:48: warning: 'void buffer_init_(buffer*, size_t, const char*)' defined but not used
./errmem.h:52: warning: 'void buffer_reserve_(buffer*, size_t, const char*)' defined but not used
./errmem.h:61: warning: 'void buffer_free(buffer*)' defined but not used
sincerely,
 -The Fathomatic
