[MOAB-dev] buildbot failure in Fathom on moab-par
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Dec  8 16:56:12 CST 2009
Excellent, this is what I wanted to see.  I think it would be helpful to see at least some of the output from the
failing build; is there a way to get a tail of the output?  I've found it annoying when I have to browse the web just to
find simple failures, so I think this is relevant even after the web links work.
- tim
James Porter wrote:
> For those of you who are interested in that sort of thing, this is the default message that gets sent when the new buildbot encounters a failure. For those of you who don't have access to ANL's network, sorry, but the links won't work (we're working on that).
> If you have suggestions for what the emails should contain (keep in mind that the links will be usable in the near future), let me know.
> - Jim
> From: buildbot at mcs.anl.gov
> Date: Tuesday, December 8, 2009 12:05 am
> Subject: [MOAB-dev] buildbot failure in Fathom on moab-par
> To: moab-dev at mcs.anl.gov
>> The Buildbot has detected a failed build of moab-par on Fathom.
>> Full details are available at:
>>  http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/17
>> Buildbot URL: http://gnep.mcs.anl.gov:8010/
>> Buildslave for this Build: bot1name
>> Build Reason: The Nightly scheduler named 'nightly' triggered this build
>> Build Source Stamp: HEAD
>> Blamelist:
>> BUILD FAILED: failed test
>> sincerely,
>>  -The Buildbot
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
