[MOAB-dev] Detecting file types
    Steve Jackson
    sjackson at cae.wisc.edu
    Wed Nov 25 17:42:04 CST 2009
Dagmc loads a file by calling MBInterface::load_file().  For several
reasons, dagmc wants to know what type of file is thus loaded, but
MBInterface does not provide an obvious way to find out.
Here is a roundabout way to test whether a file is handled by a given
reader (in this case, the native MOAB reader):
> // variables in scope: MBInterface* MBI, char* filename
> // cast MBInterface to MBCore and extract reader-writer set
>   MBReaderWriterSet* rwset = (dynamic_cast<MBCore*>(MBI))-
> >reader_writer_set();
> // get the MOAB handler
>   MBReaderWriterSet::iterator moab_reader  = rwset->handler_by_name
> ("MOAB");
> // get the read handler for our file
>   MBReaderWriterSet::iterator cfile_reader = rwset-
> >handler_from_extension( rwset->extension_from_filename( filename ),
> true, false );
>   if( moab_reader == cfile_reader ){
>     ... special code for MOAB files ...
I have three questions:
1) Is the code above the best way for a MOAB client to check file
types?  Is there a better way?
2) Should we wrap up this functionality into a more convenient
function?  Perhaps something like
MBReaderWriterSet::handler_name_from_filename(), or even
MBInterface::detect_file_type().  (I realize the latter would be a
substantial interface change, but it does express the operation I am
looking for.)  Another option would be to provide a new optional
argument to load_file, which would return a value indicating the file
type that was loaded.
3) Handler names are currently specified by strings given directly in
the code (e.g. "MOAB" in the above).  A handler name is initially
passed to the MBReaderWriterSet::register_factory method; right now
all calls to this method are found within MBReaderWriterSet.cpp.
However, if we want to use these handler names to distinguish file
types outside of the implementation of MBReaderWriterSet, it might
make sense to #define the strings somewhere.  Would such defines be
appropriate, and if so, where should they go?
Paul, Tim, and I discussed this earlier today, and we would value the
input of Jason and any other interested users.  I'm happy to do the
necessary implementation work, if we can agree on an approach.
Happy weekend to all,
~S
