[MOAB-dev] r3386 - MOAB/trunk
wilsonp at engr.wisc.edu
Wed Nov 25 08:59:22 CST 2009
Author: wilsonp
Date: 2009-11-25 08:59:22 -0600 (Wed, 25 Nov 2009)
New Revision: 3386
Modified:
MOAB/trunk/ReadABAQUS.hpp
Log:
Add documentation for meta-data of ABAQUS mesh.
Modified: MOAB/trunk/ReadABAQUS.hpp
--- MOAB/trunk/ReadABAQUS.hpp 2009-11-25 14:15:47 UTC (rev 3385)
+++ MOAB/trunk/ReadABAQUS.hpp 2009-11-25 14:59:22 UTC (rev 3386)
@@ -27,6 +27,154 @@
// Owner : Paul Wilson
+/** Implementation of ABAQUS mesh hierarchy and meta-data on MOAB
+This reader processes data written by the ABAQUS computer-aided engineering
+front-end. While that tool writes binary files in its own proprietary format,
+it also writes an ASCII input file that is the fundamental input to the
+ABAQUS solver itself. A published syntax for this format is available from Simulia.
+This reader only supports a subset of the mesh syntax necessary to support
+a basic thermal analysis of solid systems.
+An ABAQUS mesh makes use of the common paradigms of building a
+geometry as an "assembly" of "instances" of "parts".
+A "part" is defined as a set of "nodes" and "elements" connecting
+those nodes. The nodes and elements can be arranged in "node sets" and
+"element sets" and specific "materials" can be assigned to "element
+sets" other features of parts are not currently used by applications
+and are not implemented.
+Overview of supported sructure
+* File:
+ * Heading
+ * Part
+ * Nodes
+ * Elements
+ * Node Sets
+ * Element Sets
+ * Solid Sections
+ * Assembly
+ * Instance
+ * Node Sets
+An "instance" is a full copy of a "part" with a linear geometric
+transformation. To create a full copy:
+• a duplicate set of nodes is created by copying the coordinates of
+ the part nodes and applying a linear geometric transformation - the
+ new coords are used to define the new nodes
+• a new node set is created for each node set in the part and the set
+ of nodes among the duplicates are assigned to the new node set
+• a duplicate set of elements is defined by creating a new element
+ with a connectivity made up of the duplicate nodes that correspond
+ to the appropriate original element
+• a new element set is created for each element set in the part and
+ the set of elements among the duplicates are assigned to the new
+ element set; the corresponding material is also assigned go the new
+ element sets
+In order to provide convenient access to the data and mesh structures
+the following data model is used:
+• MBEntitySet file_set
+ • tags
+ • NONE
+ • members
+ • all nodes of all parts and all instances
+ • all elements of all parts and all instances
+ • all assembly_sets
+ • all part_sets
+• MBEntitySet part_set
+ • tags
+ • mSetNameTag (opaque=char*)
+ name of entitity set
+ • members
+ • part nodes
+ • part elements
+ • part node sets
+ • part element sets
+• MBEntitySet assembly_set
+ • tags
+ • members
+ • instance_sets
+ • instanec element_sets
+ • instance node_sets
+ • instance nodes
+ • instance elements
+• MBEntitySet instance_set
+ • tags
+ • mPartHandleTag (handle)
+ pointer to part from which this instance was generated
+ • mAssemblyHandleTag (handle)
+ pointer to assembly in which this instance exists
+ • mInstancePIDTag (int)
+ ordinal number indicating which instance of this part
+ • mInstanceGIDTag (int)
+ ordinal number indicating which instance in this assembly
+ • members
+ • instance nodes
+• MBEntitySet node_set
+ • tags
+ pointer to part in which this node set exists
+ • mInstanceHandleTag (handle)
+ pointer back to instance set in which this node set exists
+ (NULL if this node_set is not in an instance)
+ pointer to assembly in which this node set exists
+ (NULL if this node_set is not in an assembly)
+ • members
+ • nodes
+• MBEntitySet element_set
+ • tags
+ pointer to part in which this element set exists
+ pointer back to instance set in which this element set exists
+ pointer to assembly in which this element set exists
+ • mMatNameTag (opaque=char*)
+ name of material in these elements
+ • mMaterialSetTag (integer)
+ material id in these elements
+ • members
+ • elements
+• MBEntity node
+ • tags
+ • mLocalIDTag (int)
+ numerical ID of node in local scope (part, instance)
+ pointer back to instance set in which this node exists
+ (NULL if this node is not in an instance)
+• MBEntity element
+ • tags
+ numerical ID of element in local scope (part, instance)
+ pointer back to instance set in which this element exists
+ (NULL if this element is not in an instance)
#ifndef READABAQUS_HPP
#define READABAQUS_HPP
