[MOAB-dev] hdf5 file read
    Lukasz Kaczmarczyk
    likask at civil.gla.ac.uk
    Tue Nov 17 08:14:44 CST 2009
I tracked error to that point:
Breakpoint 2, ReadHDF5::create_tag (this=0x100877460, info=@0x101080522, handle=@0x7fff5fbfe680, hdf_type=@0x7fff5fbfe68c) at ReadHDF5.cpp:2640
2640	                                  hid_t& hdf_type )
3: info.size = 1
2: info.type = mhdf_FLOAT
1: info.storage = 1
(gdb) c
Continuing.
Breakpoint 3, ReadHDF5::create_tag (this=0x100877460, info=@0x101080522, handle=@0x7fff5fbfe680, hdf_type=@0x7fff5fbfe68c) at ReadHDF5.cpp:2818
2818	                                handle, info.default_value );
3: info.size = 1
1: info.storage = 1
(gdb) s
MBCore::tag_create (this=0x100866980, name=0x1010811f2 "AREA_FE", size=8, storage=MB_TAG_SPARSE, data=MB_TYPE_DOUBLE, handle=@0x7fff5fbfe680, def_val=0xfffffffffffd1000, use_existing=false) at MBCore.cpp:1771
1771	  if (def_val && MB_VARIABLE_LENGTH == size)
(gdb) n
1774	  MBErrorCode rval = tagServer->add_tag( name, size, storage, data, handle, def_val );
(gdb)
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0xfffffffffffd1000
0x00007fffffe007bf in __memcpy ()
On 17 Nov 2009, at 01:33, Lukasz Kaczmarczyk wrote:
> Hello
> I have problem with reading attached file in moab format. I created file with
> mbImpl->write_file(file, "MOAB" , "PARALLEL=WRITE_PART", &PostProcTrefftzMeshSet,1)
> Couple days ago, before svn update everything works ok. Can someone help me find the problem,
> <AAA.h5m>
> I made quite big analysis, and I could not open hdf files with results. I hope that I don't have to recompute it once again.
> Kind regards,
> Lukasz
Lukasz Kaczmarczyk
Lecturer
Department of Civil Engineering,
University of Glasgow,
GLASGOW, G12 8LT
Tel: +44 141 3305348
email: likask at civil.gla.ac.uk
web: http://www.civil.gla.ac.uk/~kaczmarczyk/
web: http://code.google.com/p/yaffems/
