[MOAB-dev] hdf5 file read
    Lukasz Kaczmarczyk
    likask at civil.gla.ac.uk
    Mon Nov 16 19:33:35 CST 2009
Hello
I have problem with reading attached file in moab format. I created file with
mbImpl->write_file(file, "MOAB" , "PARALLEL=WRITE_PART", &PostProcTrefftzMeshSet,1)
Couple days ago, before svn update everything works ok. Can someone help me find the problem,
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20091117/08d715a0/attachment-0001.obj>
I made quite big analysis, and I could not open hdf files with results. I hope that I don't have to recompute it once again.
Kind regards,
Lukasz
